Question about Amana AGDS902 Gas Kitchen Range
Amana Gas Range ARG7200W: The burners work fine but the oven does not ignite. The igniter glows when we turn the oven on but the oven does not come on.
  • trixham May 03, 2009
    We have the same problem; the burners and even the broiler work but the oven will not heat.
bestdarngood
  • 3037 Answers
SOURCE: Oven does not heat but broiler does
The most common cause of this symptom is a defective ignitor. Oven ignitors can glow and allow enough current through to open the oven gas valve but just not produce enough heat to ignite the gas immediately (see the link below).
In that case, replacing the oven ignitor is the usual solution.
http://www.appliance411.com/links/jump.cgi?ID=823
Posted on Mar 22, 2008
SOURCE: Igniter of Gas Burner does not ignite gas
It's called electrode.
Posted on May 08, 2008
  • 67 Answers
SOURCE: Bosch HGS442UC Gas Oven won't light
Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
if this helps please vote me a fix ya
Posted on Jul 18, 2008
jumptrout51
  • 3361 Answers
SOURCE: Amana gas oven not working
The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
Posted on Aug 30, 2009
Testimonial: "Thanks for the good info."
TheMobilian
  • 8220 Answers
SOURCE: Frigidaire FGF316WGSF GAS range oven won't work.
check this out
Posted on Mar 22, 2010
Apparently, the range works fine but the oven fails to fire; my friends son in law has this problem and I have been asked to discover why.....I am believing that the ignitor is the possible problem, any...
This can be caused by a weak/inop hot surface igniter or a defective gas control valve. First you will need to verify that the hot surface igniter is coming on(you should see it glow in the burner compartment). If it is not glowing then you will need to verify that the wiring harness has voltage to it when the oven thermostat is on. Also check the igniter for any cracks or damage and if found then replace the igniter. If it is glowing then one thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on and the igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing after the igniter is fully on. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve sticks again after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad. You can also verify that the oven run-away valve is not closed. This valve will be located at the back bottom of the range at the gas regulator. There will be a tab on the regulator housing where the gas pipe goes to the oven. This tab will lift up to close gas flow to the oven. Sometimes these valves can stick causing the oven to stop working. You can try moving this tab back and forth to see if it loosens any debris in the valve. Move the valve while the oven is on and you will be able to hear the burner come on after moving the valve if that was the problem.
May 08, 2010 | Amana ACS3350AS Gas Kitchen Range
My Amana gas oven won't heat up gas smell strong
Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Aug 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
Oven won't come on
check the ignitor for the oven even it is glowing it may not be pulling enough amps to call for gas this is a very common problem with maytag and amana ranges replace the ignitor and it should work fine
Jul 12, 2009 | Amana RanARG7302 Gas Kitchen Range
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Amana broiler problem
Each burner manifold in the oven has its own igniter. If the igniter is defective, the burner assembly will not light. The igniter has to be functioning properly in order for the gas safety valve to open. This is a designed safety feature that prevents free flowing gas from entering the oven cavity without ignition. This reduces the risk of explosions.
There should be a flame spreader metal plate covering the access over the broiler. You will need to access the broiler so you can view the broiler manifold and igniter. Turn the oven setting to broil and make sure the igniter begins to glow. If the igniter fails to glow, replace it. If the igniter does glow, but you still do not have ignition after 90 seconds, the igniter may be weak and still require replacement. The following link explains oven igniter types, their current potential, and how to replace them:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 29, 2009 | Amana RanARG7302 Gas Kitchen Range
Amana AGDS902 Gas Kitchen Range Logo
338 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
