Question about Whirlpool GEW9250P Electric Dryer
Whirlpool Duet Dryer GEW9250P (electric)
Controls are locked. hou to unlock it?
  • Anonymous Nov 27, 2007
    controll is locked
  • Anonymous Jan 02, 2008
    can not get control lock to unlock
    President:
  • 331 Answers
Here is a list of possible causes. NONE OF THE LEDS LIGHT... Check to make sure that ribbon connectors P3 and P4 are inserted all the way into the machine control electronics board. (To access the machine control, pull the dryer away from the wall and remove the three screws from the top panel on the back. Slide the top panel rearward about 1/2" and lift. The machine control is on the left hand side. P3 and P4 are the "ribbon" connectors going into the board.) A PARTICULAR GROUP OF LEDS DOES NOT LIGHT... A group or combination of LEDs share a common electronic connection. If this connection is open, all of the LEDs in the group will be disabled. If this occurs, replace the entire console electronics and housing. ONE LED DOES NOT LIGHT... Press the button associated with the LED several times. If the LED does not light, the LED has failed. Replace the entire console electronics and housing. NO BEEP SOUNDS... If the associated LEDs do light up, the beeper circuit may have failed on the machine control electronics board. NO DRYER FUNCTION IS ACTIVATED WHEN A PARTICULAR PUSHBUTTON IS PRESSED... If the associated LEDs do light up, the machine control electronics board may have failed. AN E3 ERROR CODE IS DISPLAYED... An E3 error code means that there is a user interface or a software mismatch. It can also mean that a component on the console electronics,or the machine control electronics board has failed. Hope this little tutorial gets you where you need to go. Let us know how it turns out, will ya?
Posted on Sep 14, 2007
SOURCE:
Control locked light is on? whirlpool duet dryer-mod GEW9250PW1.
Hi
Press and Hold the End of Cycle Signal button for 15 seconds, this will unlock the control. Hope this helps...please post back for further assistance.
Daniel
Sep 15, 2011 | Whirlpool GEW9250P Electric Dryer
Whirlpool duet dryer says control locked what do i do?
Hi
Press and Hold the End of Cycle Signal Button for 15 seconds, this will unlock the control lock of your Whirlpool Duet. Hope this helps...please post back for further assistance.
Daniel
Sep 14, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My whirlpoolduet dryer is on control lock how do I unlock it model # gew9200lw1
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet however, your whirlpool duet needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Apr 17, 2011 | Whirlpool GEW9200L Electric Dryer
Control lock is on on my dryer and it will not come on...
Press and Hold the end of cycle for 3 seconds. It will get unlocked
Feb 27, 2011 | Whirlpool GEW9250P Electric Dryer
My control keys are locked
The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
May 16, 2010 | Whirlpool WED6400S Electric Dryer
I need to replace a door switch on my Whirlpool Duet dryer. How?!
look toward the bottom the screws are recessed upward to hide them then it should open up like a car hood and there are spring clips at the top
Oct 31, 2009 | Whirlpool GEW9250P Electric Dryer
Whirlpool Duet Dryer GEW9250P (electric)- how do i unlock dryer?
its a botton to the far right that says child lock,,,press and hold for 3 seconds,,if this doesnt work un plug it for a minute..than replug
Dec 19, 2008 | Whirlpool GEW9250P Electric Dryer
Whirlpool Duet Dryer has a mind of it's own, cannot change contro
First of all check to see that the control panel is not locked. There is a lock button assigned on the control panel. It should say it next to one of the buttons. Not door locked. You have to hold that button in for 5 - 10 seconds to unlock the panel. If not, you may need a new panel, happens often, its part # 8558753 depending on the color. Thanks Dave www.washermd.com
Dec 12, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Dryer GEW9250PW0
the control panel is bad / it is also called a user interface
Nov 20, 2007 | Whirlpool GEW9250P Electric Dryer
Whirlpool GEW9250P Electric Dryer Logo
461 people viewed this question
Top Whirlpool Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
