Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Need to replace the control cable on a wind tunnel upright.
What do I need to take off or loose to get down to the cable pivot arm to replace the control cable?
Thanks for your help.
Mike
  • 281 Answers
Phillips screwdiver once you get the cover off there will be 4 screws that hold the motor to the base 2 on each side of the upright.its where te upright swivals
Posted on Apr 23, 2009
Where is belt located on Hoover wind tunnel vacum. And how to replace it. My brushes are not spinning.
Its usually located underneath the body of the unit, turn it upside down and you should see the beater brush. You need to open the bottom cover to get at the brush and drive belt.
Mar 25, 2015 | Hoover U8126-900 Wind Tunnel Dual V...
Hoover wind tunnel won't self propel
There are really two reasons why the self-propelled wouldn't work. It could either be the belts on the vacuum cleaner are stretched or broken. The belts on this model control both the self-propelled transmission, as well as the brush roller. Here's a video that shows you how to inspect the roller brush and belts to make sure that they are installed properly and working. Try this repair first, as this is the easier one to fix.
The other problem if the belts are installed properly that would cause the self-propelled wouldn't work would be the self-propelled actuator arm. There is a cable that starts at the handle of the vacuum, and runs all the way down to the floor head of the vacuum that controls the transmission. As you pull backwards on the handle of the vacuum, the cable pulls this actuator arm backwards, which then turns the wheels backwards, and when you push forward it turns the wheels forward.
The problem with the way it's designed however, is that if you pick up the vacuum cleaner by the handle of the machine rather then using the carrying handle on the back of the vacuum, it causes too much tension on the actuator arm, and will cause the cable to rip right out of the arm.
This is a VERY common problem on this model. To check and see if this part is broken on your vacuum, step on the handle release pedal so that the handle is in the vacuuming position, push the pedal a second time so the machine lays flat on the floor.
Now if you look right behind the height adjustment switch, and the rug / floor switch where the floor part meets the upright part, you should see a cable that connects into the actuator arm. Pull up and down on the handle and look for movement. Is the cable loose with only a nut attached to it, or is it resting in the actuator arm?
Here's a very helpful link that shows you exactly how to replace the actuator arm:
How to Replace the Actuator Arm on Hoover Self-Propelled Windtunnel
If this didn't help you, and the problem is still happening, please just use the add a comment form here on Fixya and let me know that you're still having problems. I'd be honored to go through and do some more advanced diagnosing with you.
I hope this we helpful to you. If you did find this helpful, please be so kind and leave feedback for me. This is why repair professionals like myself continue to come back and give free repair advice, to get the recognition of a job well done.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 17, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Where is reset button on Hoover Wind Tunnel vacuum?
Hello my good friend, this cleaner doesn't have a reset button or anything, it resets by itself after cooling down, it takes about 30 minutes to cools down.
Nov 07, 2009 | Hoover Company Wind Tunnel U53019 Upright...
How to change the V belt on hoover wind tunnel U6435-900 ?
Below I have listed a link to the manual which has instructions and a link to the V belt you need.
Windtunnel Manual
Windtunnel Replacement Belts
Nov 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Self Propelled does not work
if you look below the headlamp of your vac you will find a cable that attach's to a piece called the actuator arm. either this piece is likely broke or the cable itself. always work the power drive smoothly or things will break. also could be that the smooth belt is stretched and will cause the same problem. belts should be replaced every 4 months. good news is all parts above should be under $5. dont let anyone tell you that you need a power drive assy, that usually isnt the case. good luck!!!
Sep 24, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover wind tunnel upright self propelled. U6473-900. Brush does not work. Heard it was a 'brush controller' problem and can be fixed. Please tell me how.
Most likely the flat belt has stretched enough so as to not turn the pulley that in turn turns the brush roll using a V belt. Also there is a small idler wheel, if hook up, then it won't engage the V belt.
May 20, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover wind tunnel
A clog or partial clog is what causes the motor to overheat, then a thermo protector will cut off and the motor will stop until it cools down. So either you do have a clog, in the hose or down by the brush roll. If they are clear, and the filters are clean, then maybe the thermo protector is bad and needs to be replaced.
Mar 08, 2008 | Hoover 5416-900 WindTunnel Bagged Upright...
Hoover Self Propelled wind tunnel vacuum U6433-900
please go to thehooverstore on the web. they'll have an exploded diagram of how your machine goes together. I'm sure you'll find your solution there.
Sep 02, 2007 | Hoover Ultra U6430-900 WindTunnel Bagged...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
206 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
