Need to locate parts for purchase for old Admiral washing machine.
I have two problems: 1. I need to purchase a selector knob on my Admiral top loading washing machine (Model No. LNC6747A71, Serial No. 10487797MQ). I need to purchase a hinge for the top loading door.
  • 490 Answers
Http://www.repairclinic.com/SSPartDetail.aspx?s=b101a11c226i1477&PartID=1477 you will find your hinge here
Posted on Apr 14, 2009
My haier thermocool top loader washing machine is not draining water in the wash tube
you need to locate where your pump outlet is on the machine,, it must have something stuck inside it
Oct 18, 2012 | Haier XQBM22-C Top Load Washer
Load size select nob is stuck in small load position & i can't get it to turn
the selector knob has finally taken a dump and needs to be replaced the part number you need is gonna be located on the back of the selector without a model number i have no way of looking it up for you
Jul 23, 2010 | Whirlpool LXR9445JT Top Load Washer
Whirlpool machine fell over and selector knob broken can i buy a new one
A selector knob is a very common part. You should be able to order on line at any of the follwoing websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing. Shop and compare.
The first three sites on the list also include helpful exploded view parts illustrations to assist you in locating the parts you need. Ordering on line can save you a little from the retail mark up you find in parts stores.
If you do not wish to order on line,however, look up the part number on the Sears website since nearly all Sears washers are manufactured by Whirlpool. Take the part number to your nearest appliance parts retailer. This may be a part they carry in their in-store inventory (some selector knobs are commonly carried). If not, they would have to order it for you.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the wash tub rim on a TOP LOADER and around the door facing on a FRONT LOADER). I hope this helps you.
Feb 07, 2010 | Washing Machines
WHDSR209DWW on/off button will not engage to spin the cycle selector dial
The cycle selector is not engaged onto the timer shaft. Need to remove the on/off knob by removing the plastic "U" clip. Remove the cycle selctor knob and check that the steel spring clip on the selector is fully seated. Re-install the cycle selector onto the timer shaft aligning the selector key with the with tthe notch on the timer shaft. Re-install the on/off knob.
The cycle selector and on/off combination is a poor design. Users press the on/off knob in and turn clockwise to set the wash cycle. If you're not gentle this action wears the teeth on the timer shaft and the user has to press harder and harder to set the wash cycle. This pressing causes the cycle selector to be pushed off the timer shaft and you can no longer operate the machine.
VERY IMPORTANT:
Stop using the on/off knob to set the wash cycle. Press on the cycle selector to set the wash cycle. Use the on/off knob only for starting or stopping the machine. Don't press or pull too hard on the on/off knob or you will wind up pushing the cycle selector off the timer shaft.
Jan 12, 2010 | General Electric WHDSR209DWW Top Load...
Selector switch knob for kenmore elite washing machine
At the back of the machine are four screws with safety heads they hold the top on. remove them this will give you access to the screws holding that part holding the switch.
Mar 28, 2009 | Washing Machines
The washer filledup over the limet and inondated
The pressure switch is located on control board. A tube connects from the switch to the bottom of the tub. To answer your question, it's right behind the wash size selector. There are many sites online to buy. If you give me your model # I can help you find one. I did try the model # you listed and said it didn't exist.
Feb 28, 2009 | Admiral AW22 Top Load Washer
How do I remove the selector knob on washer
The main selector control know spins off by turning the selector inner knob counterclockwise. The outer ring will then pull off. The other knobs are held on with friction and should just pull off.
The best way to get behind the front panel is by removing the top panel of the machine. There should be 2 gray/solver tabs at the back of the machine near the top if you remove the 2/4 screws from the top then the whole top panel will slide forward then lift off.
Be sure to unplug the machine first.
Aug 02, 2008 | GE WSXH208A Front Load Washer
Admiral Top load washer won't agitate and squeals
Sounds like the gearbox, unfortunatly this is sealed and is cheaper to replace the machine, presume the machine is quite old.
Jun 28, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
114 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
