Question about HP DeskJet F380 All-In-One Printer
Offline it keeps telling me the status of the printer is offline. Sometimes it prints 1 thing, then nothing at all b/c the status is, offline. It's all plugged in, so not sure where the problem lies. Please help me out.
  • 1 more comment
  • Marzee Feb 12, 2008
    My printer says that it's offline and now it isn't printing. I think there might have been too much paper in the tray. I have shut it off and turned it on. I have taken out both ink cartridges and put them back in.
  • Anonymous Feb 14, 2008
    Printer prints one page then says out of paper when it is not.
    it also goes off line at the same time, and says 1 document in queue
    error deleting.
  • Anonymous Apr 16, 2008
    will not print. says off line
    Guru:
  • 731 Answers
Hi, i have come across this kinda issue when i was working with HP for AIO printer Technician, just a simple troubleshooting.Try this below steps.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HO DESKJET F300)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Posted on Feb 09, 2008
You check your data cable and electronic board also
Posted on Sep 19, 2007
I also have the same problem. No idea why or how to solve it.
Posted on Feb 03, 2008
I have the same problem as humming bird and the problem description is also the same. so pls help me in solving this matter
Posted on Jan 30, 2008
Keeps telling me it is off line-how can I correct it so I can print
First check on the device and printer under control panel if the status of your printer is offline or ready. If it is offline check your usb cable if properly connected and if ready state then if you send print job set to offline try to reinstall the driver. hopefully it will help you.
May 13, 2015 | Brother Fax-2840 High Speed Mono Laser Fax
Printer offline
Depends on your OS you need find "printer and faxes" or "printer options on the hardware.
  • Open the Start menu and click on the "Devices and Printers" icon. This will open a window with a list of the printers currently set up on your computer.
  • Double-click on the icon of the printer you want to change to online. The status of the printer will be shown as either "Printer: Ready" or "Printer: Offline."
  • Click on "Printer: Offline" and the Printer menu will appear. Click on "Printer" in the menu bar and uncheck "Use Printer Offline." This action will change the printer from offline to online.
May 12, 2013 | Office Equipment & Supplies
Print jobs are completed with no problems sometimes, other times the print queue shows the job being printed, but nothing happens. Printer status shows "offline", but if I click on the...
Reason behind "offline" is communication between printer & system got interrupted,check weather printer is restarting it self ? check with another USB cable,check firm ware if low version up load it, check printer USB port on formatter is it dry solder? if no check the voltage in connector 17, between pin 1 & 20 is it 5V? if not check power supply connector J201 pin1, is it 5V? if not replace Power supply PCA.
If 5V showing between pin 1& 20 replace formatter.
Sep 09, 2011 | HP LaserJet 3050 All-In-One Printer
Keeps showing offline even though I put in new cartridges and it cleans. When I test print, I have to do it manually and the paper comes out blank. When I check the ink status for some reason it shows...
First unplug your printer from the computer then uninstall you installed driver . After that plug it to the computer and install driver again. Then restrat your computer after successfully instalation. If still now ggive the problem then install driver from the below link and install it.
http://download.cnet.com/Brother-MFC-240C-USB/3000-2110_4-99329.html
hopefully it will be work. Other wise go to the servicing center.
May 04, 2011 | Computers & Internet
My HP officejet 4315 v All-in One is set as my default but the status shows offline, how do I turn the status to ready and to be able to print from the computer?
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Feb 06, 2011 | HP Officejet 4315 All-in-One Printer
Printer status-offline unable to print
Jan 14, 2011 | HP DeskJet F380 All-In-One Printer
I have a Canon Pixma MX330 color printer. It gets used only occasionally, usually to print brochures and the like. I recently switched it to copy mode by pressing the "copy" button on the front; now it...
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 05, 2010 | Canon PIXMA MX330 Multifunction InkJet...
When trying to print nothing happens just a green
please check ur printer connections
check the printer statuse offline or online keep it online
if its not working please install printer driver
Sep 29, 2009 | Office Equipment & Supplies
My HP Officejet J4540 All-in-one printer is showing Offline. I have checked all connections and all appears ok. Could you tell me how to change that status to Ready?
It shows offline if the printer is not communicating. Initially open printers folder and right click the printer icon and check if "use offline" option is not ticked.if its ticked then un-tick it. if everything looks fine then:
1)first try unplugging printer from main power cord for a minute and then plug back in and check after refreshing if it becomes ready.
2)other thing to do is to remove the usb cable from behind the printer and plug back in after 45 seconds.
3)it is also quite possible that the usb port or cable might have gone faulty.in that case try replacing usb cable and check.
thanks ,keep updated and accept the solution.
Sep 02, 2009 | Office Equipment & Supplies
Nothing happens when i tried to print from my computer the status is offline what is wrong
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
575 people viewed this question
Clive
Clive
