Question about Koss CDR200 2-Disc CD Recorder
Recording why don't it record? Does it record lp's and cassetes? Does it record on cdr's and cdrw's? thanks.
  • Anonymous Apr 11, 2008
    my turntable is connected to my amp. but I have the same problem , can't get the burner to record.
    Scholar:
  • 103 Answers
It will record any line level source (CD, MD, tape, tuner). You can only record vinyl records if you have a phono pre-amp.
The best way to use a CD recorder is to use the "tape loop" on your amp/receiver. Does your amp/receiver have a "tape in" and a "tape out"? If it does you should connect your CD recorder to these in/outputs. That way, whatever your amp or receiver is set to listen to, is what you'll be recording.
Shout if you need more help!
Posted on Jan 09, 2008
  • Gary Christer
    Gary Christer Jan 09, 2008
    Oh, and yes you can use CDR or CDRW but be aware that most CD players will not play CDRWs.
    And, the discs you use must be dedicated audio discs, not data ones.
SOURCE:
Will not burn a CD
Have you checked which CDR media the device can use.
This may be as simple as using a CD-R rather than a CD+R or vice versa,
Also check if you may be burning to a CDRW or CDR.
Apr 03, 2014 | Marantz CDR420 CD Recorder
What type of disc do you need to record, I bought DVD+RDL but it keeps ejecting
What are you trying to record on.First you need a recorder.You cannot just put a cd or dvd in a player to record.They are play back only.Now what media are you putting in your recorder.If it is a cdr it will not record on dvd.What you said is you are using a dvd+rdl which is a dvd+ media with double layer (meaning 9.4 gig instead of 4.7 data).Any dvd recorder can handle the dl media.Look on the facinfg of the carriage and it will tell tell you the media intened to be used. cdr/cdrw or dvd/dvd-dl.Hope this helps
Apr 29, 2011 | Televison & Video
Displays 'data disk' when i try to record live audio or duplicate a CD
it sounds to me like you are using a blank CDR/CDRW that you would use in a computer rather than a CDR Audio. The two types of discs are different and although you can use either in a PC to record on, on these "Home Burners", they will only record on the other type.
Try it .....
Jan 08, 2011 | Sony RCD-W500C 5-Disc CD Recorder
I cant burn any dvd, but cd r or rw are capable . mayber the driver is out of date..please help me.
hi
perhaps the CD media you purchased is not compatible with your CDROM drive ..?
what is the model number oif the CDROM ? what computer model is used in ?
Nov 15, 2010 | Computers & Internet
How can record?
This model is not capable of recording. It will play CDR and CDRW, this printed on the machine might have missled you to belive that it can record when in fact its just telling you the types of disks that can be played.
Jun 20, 2010 | Sony DVP-NS50P DVD Player
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
Not able to record cd get message unreadable cd
I found out that memorex cds that have on the package (for use in audio recorders)work every time.They're red label packaging,I hated buying cds only to find out they dont work. Dont forget READ THE LABEL look for (use in audio recorders)
Dec 24, 2009 | RCA CDRW120 2-Disc CD Recorder
Does anyoe know how to record from LP to cd?
Use your tape out, or another line out signal from your preamp.... if possible - OR Sometimes you can pull out some connectors on the back of your amp (a Metal joint kindathing ;), to break signalpath between preamp and poweramp if its an integrated amp -
Use preamp out signal to feed your cdr ( Main purpose is to equalize out, the RIAA correction on a record)
Have you tried to google your question ? Lots of fine guides out there!!!
Jan 14, 2009 | Harman Kardon CDR2 2-Disc CD Recorder
Mavica CD500
Make sure you have a CDRW disk and not a CDR. (CDRW- CD Re-Writeable)
(CDR - Record Once)
Oct 29, 2008 | Sony Mavica MVC-CD500 Digital Camera
RECORD DROP OUT
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
IMPORTANT:
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Oct 02, 2007 | Philips CDR570 CD Recorder
Koss CDR200 2-Disc CD Recorder Logo
324 people viewed this question
Top Koss Audio Players & Recorders Experts
Steve Allison
Steve Allison
Steven Wander
Steven Wander
Ekse
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
