Question about Maxtor (6L250R0) 250 GB Hard Drive
Replacement PCB for my DiamondMax 10 250GB HDD
My Hardrive has no Bad sectors and never had a problem ... Until suddenly It refused to Power up. It seems like one of the switching transistors have blown up ... and need to be replaced on the PCB underneath the drive(Where we Plug in the IDE Cable & teh Power supply). The reason why I feel that is because the HDD seems to be spinning(very Slightly) in intervals every 5 seconds and then stops(While I Boot up the PC. Due to inefficient power supply the drive is now not recognized in the Bios. I may be wrong but would really think I do need a replacement as the 8MB buffer also used to have a hadware Malfunction as I get a BSOOD in windows stating a Problem and Physical Memory Dump ... and I have tried installing brand new RAM Modules in Single and Dual channel modes. Even Re-Installing teh OS ... no luck. Another Samsung Hardrive works perfectly on Both my OLD and New Ram Modules ... Same OS(Win-XP professional). I'm Now looking for that Board to solve my problems. Can you tell me How do I go about finding a replacement board. Thanking you
  • 136 Answers
Best bet would be to look on ebay and buy a working used drive and swap the boards as these surface mount devices are hard to tell what they were when they go nuclear.
Posted on Sep 15, 2007
My computer burned 2 hdd
After i Read your Explaination,i really sure if the Problem is at your Computer POWER SUPPLY.
Change your Power Supply to Higher Watt.
i Recomended to you to Using SIMBADA Power Supply ATX.
and to Fix your HDD bad Sector,Try to use LLF (Low Level Format).
LLF will destroy all data and Partition.So after you Format using LLF,you need to make a New partition at your HDD.
LLF is Working for me to Fix Bad Sector in a So many times.
Jan 18, 2012 | Gigabyte Ga H55m D2h Desktop Motherboard...
Reboot while Formating Hard disk Maxtor diamondmax plus 9 120 gb ata/133 hdd Now my hard disk says it's damaged when i want to format it, can you sugges me some software to repair it ?
you could runthe chkdsk utility click start tpe cmd you are now in dos then type chkdsk/f/r to scan for and attemp to repair any bad files and bad sectors on your hard drive this will schedule to happen on restart of your computer another way of running the chkdsk utility click start click to open you should see your drive C: right click on select tools check now you will see two boxes tick in both again this will schedule to happen on restart if this is your primary hard drive with your operating system on it
hope this helps you
Jul 24, 2011 | Maxtor DiamondMax Plus 9 120 GB Hard Drive
Hi please help me my Intel motherboard D101GGC restart it self any solution?
Sorry very vague , check your power supply , re-seat your memory modules & check that yor hardrive doesnt have bad sectors
memtest86+ good memory test ( create a boot cd from the downloaded iso)
Seagatetools good hdd test cd ( create a boot cd from the downloaded iso)
Reset the Bios ( remove the cmos battery for a couple of seconds , put it back and power on )
May 27, 2011 | Intel D101GGC Motherboard
How can i recover bad sectors in my hdd drive using a startup disk?
Boot from the startup disk.
Run 'CHKDSK' with the '/F' (to "fix") option.
Oct 18, 2010 | Seagate 80GB Maxtor DiamondMax Plus20 Hard...
Hii have a Samsung hdd. Due to some bad sectors not it says that "boot media not recognised....abortretrycancel...". even I tried to fix it with other pc but it is not recognised even there. So how can I...
first run the samsung diagnostics on the harddrive to check the drive integrity weather or not its repairable. Then you can low level format the hardrive to fix any bad sectors
Diags link :
Low level format :
Jun 13, 2010 | Computers & Internet
My hard drive is going bad. So says my HP Compaq dc7100 SFF
Instead of posting here, why don't you look for a dealer.
You can buy hard drives just about anywhere now - and it doesn't have to be Maxtor.
Oct 18, 2009 | Maxtor DiamondMax Plus 8 40 GB Hard Drive
Many Bad Sectors fat32, trying recovery disk
It sounds like your HDD is faulty, usually a hardrive can operate with bad sectors but still a risk.
My best advice would be to get a new HDD and recover back on to the new one, even if you did manage to recover onto your current one you may still have problems in the future.
I usually only allow a HDD to fail S.M.A.R.T tests 3 times over any given period and then I just replace them.
Sep 05, 2009 | Acer Aspire 3000 Notebook
Maxtor DiamondMax Plus 45 7200 RPM 30.7 GB HDD suddenly makes clicking sound when started and will not be recognized by Win XP OS. The drive had been working flawlessly. Any suggestions?
Clicking sounds is an indication that the platters have a bad device internally. Once that happens the hard drive is no good, run the serial# on Maxtors website to see if its still under warranty, gd lk
Aug 01, 2009 | Maxtor DiamondMax Plus 45 (53073H4) 30.7...
Hard disc not working
yah its possible to recover the data from hdd.
just baught a recovery tool cd and recover your data
hdd may has a bad sectores .u run a bad sector recover soft ware .
May 02, 2009 | Computers & Internet
Dead Maxtor drive
the soec of the drive will have to match up in order to get the no pcb to wrok so the heads ,sectors,cylndrs and so forth
Apr 23, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
Maxtor (6L250R0) 250 GB Hard Drive Logo
140 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
