Waste toner near full?
Kyocera KM-1820 copier says waste toner near full? What to do?
  • 42 Answers
You can empty the waste chamber on the image unit by removing the screw from both ends of the unit, pull the ends off and empty it out. It's a messy job so have a good plastic bag and a toner vacuum if possible. The message might stay on awhile but will disappear with time. The alternative is a new image unit.$$$$$$
Posted on Feb 11, 2010
My photocopier has been displaying this error code message C-7990 a photocopier kyocera KM-1500
C7990 is
Waste toner reservoir overflow problem (when the total number of copies is 100 thousand sheets or more)
• After E31 is displayed, 1,000 sheets are copied. Or waste toner exceeds 5 g.
Defective waste toner sensor or engine board (KP-5061).
Shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be solved, replace the process unit. After replacing the process unit, turn the power switch off and then on. If the problem
cannot be solved, replace the waste toner sensor or the engine board (KP-5061).
I hope this is helpful,
Shawn
Mar 05, 2011 | Kyocera Copystar CS-1820 Black and White...
C-7 980 error code
can you give us the error code?
waitin for your reply.
May 08, 2008 | Kyocera KM-1505 Copier
KM-1820 machine reports "waste toner
You need to replace the procces unit. The waste toner can not be emptyed the unit needs to be replaced, Some times if you remove the proccess unit and gentally shake it left to right several times and place the unit back in the copier the error will clear, if not you will need to replace the process unit which is a PU-102.
Jan 07, 2011 | Kyocera Office Equipment & Supplies
Waste toner full and now message error occured C7980 call service person
remove the drum unit. on the part of the unit that goes first in machine is the is waste toner container. on each side of the container there is a screw, remove one screw and pull out the cover. slant the unit and the waste will come out
Oct 05, 2010 | Kyocera Copystar CS-1820 Black and White...
Sayiing waste toner near full
Turn the machine Off the machine and try to shake it little bit. if its not cleared you have to replace the processing unit.
toner sensor or the engine PWB.
It happens with me serveral times and always solved by replacing the processing unit.
Good luck
The Experts
Aug 16, 2010 | Kyocera Copystar CS-1820 Black and White...
Kyocera KM 1820 Printer - where is the waste toner container?
This is going to be messy, so do it outdoors.
Remove the entire drum unit. Remove toner cart
Remove the chrome screw on the right side and the cap.
Dump.
Install and reset power.
Jun 23, 2010 | Kyocera Copystar CS-1820 Black and White...
ERROR CODE "C7980". I HAVE ALREADY EMPTIED THE TONER WASTE. WHAT DOES IT MEAN AND HOW DO I FIX IT?
Hello sir; The code you display which means waste toner bottle full, just dump it .
May 12, 2009 | Copystar CS-1820 Copier
Where is waste toner on kyocera 1820
TO empty the waste toner on a KM/CS 1820 you have to remove one of the side covers from the drum unit on the machine and vac out the old toner i've had customers try to reuse the toner please do not do this. just vac it out good and your normaly good to go!!
Apr 08, 2009 | Kyocera Copystar CS-1820 Black and White...
My Kyocera KM 1820 is saying there is toner overflow that needs to be emptied?
Open the front cover and locate the waste toner bottle. Empty it out and see if that corrects the problem. If that doesn't work, clean the bottle after emptying it. If the doesn't work, replace the waste toner bottle with a new one.
How does the copy quality look?
Jan 20, 2009 | Ricoh Aficio 250 Copier
Waste toner on Kyocera 1820
open the front cover, pull out the process unit... then unscrew the left side of the waste disposal tank (the opposite end of the toner cartridge)
Oct 14, 2008 | Kyocera Copystar CS-1820 Black and White...
1,582 people viewed this question
k24674
