Question about Envision EN7410 17" LCD Monitor
Pulsating screen. I have an envision 7410c flat screen, it was dropped and since then has a pulsating screen, it shows a perfect picture but it pulsates.
  • 64 Answers
Due to the flourescent lights that are used in this product, i would suggest trying to return the product for a new one, as one or maybe a few of the bulbs may have busted or become loose due to the impact caused by the fall.
Posted on Apr 14, 2009
I have a 42" Envision Flat Screen. It shows the image on the TV didn't look like this yesterday. It showed shadows in magenta, yellow and white. The setting are set to the factory settings.
T'Con board fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 06, 2015 | Envision Televison & Video
My 6 year old 32inch envision tv no longer has picture or sound anymore even after its properly connected to cable
Based on the brand parts may not be available and six years is better than average life for this type of set.
Dec 12, 2012 | AOC Envision L32W461 32 in. LCD HDTV
Monitors
How to Fix the Resolution on Envision Computer MonitorsXll.jpg"> TS Jordan
TS Jordan is an Ohio licensed attorney living and practicing out of the Cleveland area. In addition to his Juris Doctorate, he holds a Bachelors' Degree in Information Systems. He has been writing professionally for less than a year.
By TS Jordan, eHow Contributor
Envision flat-screen computer monitors come with a "native" resolution, which is the resolution that exactly matches the number of pixels included on the monitor. Setting the resolution to the native standard will therefore produce the best image quality. You can utilize the display properties tools in your computer's operating system to fix your Envision monitor's resolution.
Read more: How to Fix the Resolution on Envision Computer Monitors ' eHow.com http://www.ehow.com/how_6666424_fix-resolution-envision-computer-monitors.html#ixzz2DLKKQZ4M
Nov 26, 2012 | Envision Computers & Internet
Envision flat screen tv has 5 channels that don't play volume but show pic
Check the volute settigs to these channles. Check whether system set is compactable with input.
Feb 04, 2012 | AOC Envision L32W461 32 in. LCD HDTV
No Picture on 5 month old tv.
If the screen is just showing white screen, no text, no picture, then the problem cam be in the LCD controller board. I would get this fixed under warranty ASAP, nothing should have gone wrong yet. You may have a lemon, this is not a no name set.
Jan 02, 2010 | Toshiba 26LV610U LCD TV
I have an AOC 32" flat screen. the left hand side of the screen displays vertical lines only. The rest of the picture is perfect. The set is only 1 year old.
Hi my name is Roety,
I can help you with your issue ,
Sorry to say , but these LCD TV Screen do go bad.
There is a board thats part of the screen called the Tcon
You can check the ribbon cables to the tcon board or try to get AOC to warranty the TV under the 1 year warranty.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Dec 01, 2009 | AOC Envision L32W461 32 in. LCD HDTV
Screen Size on my Envision L32W761 TV is cutting off the picture.
Look on the remote for a button labelled ASPECT,P SIZE, ZOOM or FORMAT. Press it until picture is desired size.
Oct 04, 2009 | Envision L32W761 32 in. LCD TV
Envision LCD monitor keeps cycling on and off
davagain, Your stated symptom leads me to believe that L17LCD2 has a problem in it's power supply/electronic CCFT ballast circuit. The primary cause of the on/off, on/off, being that the SMPS is detecting a fault and then going into SHUTDOWN, trying to save it's self from catastrophic failure. This "failure mode" is typical of all brands across the board, not just Envision! And as the age and total number of hours of use grows, the "body count" also increases. I have, with luck, repaired a couple of them that were not of the catastrophic type. So, my advice to you is this. If Envision can't provide a viable solution, then work with a dealer to trade it in for NEW. If COST of new is still an issue, there are other options that may be of intrest to you. With a statement like "known good monitor" and "failed solder joint" I know you are NOT the typical consumer/user type of person. FYI also try search for "failed electrolytic capacitors" and or "swollen capacitors" and "bad caps", which also could be a culprit inside your Envision. In any case I would like to hear back from you on what your plan of action is. I will try to be of some help. Bye for now. lmistyrel@aim
Sep 27, 2009 | Liquid Video L17LCD2 17" Flat Panel LCD...
Envision EN 7100si LCD 17" flat screen
First try auto-adjust with the auto button on the screen
if not worked
Make sure she installed the envision driver. I jus saw it's a discontinued product. Also this product has a maximum resolution of 1280 x 1024.
If installed check her resolution. Right mouse click on desktop>properties>screen. Try alternate resolutions and see what happens but don't set it higher then 1280 x 1024 if possible.
Nov 28, 2007 | Envision EN-7100e 17" Flat Panel LCD...
Envision EN7410 17" LCD Monitor Logo
181 people viewed this question
Top Envision Computers & Internet Experts
Cleverer2
Steve
Martin Murray
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
