Question about Epson Stylus Photo R800 InkJet Printer
Carriage stuck in charge position
I tried using continuous ink supply system for about a fortnight then I had a message that said "parts inside the printer are near the end of their service life". I took that system out and replaced it with compatible inks that I have faith in. The ink heads required cleaning then the darn thing stuck and still is. I took out the cartridges. The printer is a year old next month but Epson will have nothing to do with it as I used ciss and compatibles.
  • Norrie Sep 15, 2007
    The carriage is stuck in, I think,the position it would rise to if it was charging or cleaning the print heads. I will certainly try all you suggest over this weekend and try to obtain a rsscue kit.
  • lillia Dec 23, 2007
    carriage is stuck and will not move. tried pulling it out
Thanks Inky, problem solved with Rescue kit as suggested.
Posted on Sep 27, 2007
  • Epson Master
  • 705 Answers
The "Parts Inside Your Printer..." message related to the Ink Over Flow Protection Error and means the internal counter within the firmware has reached it's pre determined limit. You will need to reset the counter within the firmware with a special bit of software. You will also need to clean out the waste ink pads. You should be able to get a Rescue Kit for this problem from http//www.TheServiceManualShop.com Regarding the carriage - in what way is it stuck? If it is in it's home position, you should be able to release it by pushing the head lock back with your finger. It is located (I think) just to the left of the carriage on the vertical rail. A small white piece of plastic protruding from the rail. You may need to push the head to the RIGHT a little. If the head is stuck elsewhere and will not move in either direction by hand then look to see if the drive belt has jumped off the pulley. Also look to see that the head lock has not come forward and is preventing the carriage from returning home. Move the head to the left end (if you can) and look near the home position for the white piece of plastic protruding from the rail. Let me know if you still have problems
Posted on Sep 14, 2007
SOURCE:
HP 1610 Carriage Jam
Remove the ink jet, make sure you removed any pckg. material and the contacts cover on it.
Nov 10, 2017 | HP PSC 1610 All-In-One InkJet Printer
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson r220 carriage jammed
Had the same problem.
Took alot of work but I fixed it.
Frist thing you need to know that error means your ink waste pad is full. Its a $75.00 to replace but there is a work around it.
You will need this free app. SSC service utitlty.
http://inkjetprinterhelp.us/epsonSSC.html Its a great app.
Instrusctions are on the website there.
You will also have to Open the access panel on the rear of the printer (remove screw) and look inside carefullly with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad.
Use a piece of coat hanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel.
Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won’t come apart or lose connection if the printer is moved.
If you wish you can make a hole or notch in the access panel cover so it can be replaced.
Feb 12, 2009 | Epson Stylus Photo R220 InkJet Printer
Kodak 5500 All In One Printer set up problem
If you are getting a 'carriage jam' error as soon as you turn on your Kodak printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam: Open Door, clear carriage jam, and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck. Manually move the carriage toward the opposite side. Check the paper path and remove any piece of paper or any other object that is stuck in the path. Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t2952766-kodak_all_in_one_printer_paper_jam
Jan 02, 2009 | Kodak 5500 ALL-IN-ONE PRINTER
Epson 1280 ink carriage making noise and not printing
hello there. try re-seating the cartridge. Take it out, then put it back in.
Nov 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson CX2900 problem
HI,
Try to reset it :
SSC Utility has the latest version SSC Utility 4.30... This time it can now reset the Epson Stylus CX2900...
Download the latest version and Install it...
Under Configuration...
Select Installed Printer (EPSON Stylus CX2900 Series)
Under Printer Model
Select EPSON Stylus CX2800...
I hope this will help you. Link
Aug 02, 2008 | Epson Stylus C84 InkJet Printer
Epson 1280 Solid red mainteance light
Hi-
Is iot on the position where you can install the ink cartridge? try turning it off and unplug it from power supply then after 10mins replug and turn it back on. keep me posted, but if it will do the same thing chances are there is something wrong with the belts on it, better have it fix or have it check. Thanks for using fixya!!
Jun 26, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus Photo R800 InkJet Printer Logo
219 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
