Question about Dell M991 19" CRT Monitor
Dell Monitor My Dell Monitor seems to have quite working. There is a light on the front of the monitor that is usually green when all is working correctly but now it stays orange the entire time. I am wondering if it is time to buy a new monitor or if this is something I can fix. The monitor is about 4 years old and is on pretty much all the time
  • fayb1 Feb 28, 2009
    When I push the power button it goes to green and makes a noise like it's turning on, the light goes to green and then immediately another clicking noise and it goes to amber and a black screen.
Send me schematic power supply form Dell M991 thanks
Posted on Jun 23, 2008
My dell gx260 ligth come green if i turn it on but for a few mins time it turn orange why
Do you mean the monitor's power light starts green and then turns orange when you turn it on? Most monitors will go to a power saving mode when they do not get a signal from the computer.
The Dell GX260 has a green power light when on. When the computer is off, the light is off. If it is green and blinking, then the computer is in a power saving mode.
Diagnosis: start with the obvious: is the monitor cable plugged into both the computer and the monitor (if not permanently connected to the monitor)? Are you connected to the active port? (You can add a video graphics card in most desktops. The motherboard video port usually needs to be disabled to use the card ports. If you plug in the monitor cable to the disabled port, it won't work.) Is the monitor set to the correct input? (This applies if the monitor has several ports. In that case, there will be a Source or Input button on the monitor.) Is the computer on? The GX260 has the power button on the front. (Other computers have the power button on the top.) There is also the power supply switch on the back which needs to be on.
Next try a different data cable between the monitor and the computer (if you can). Try a different monitor. If a second monitor works, than the monitor has a damaged main board. If the second monitor doesn't work, then the video graphics adapter has probably failed. Replace the add-on card, if in use, then boot in the safe mode to remove the old graphics driver. Then install the correct driver for the graphics adapter.
Note: the computer and the monitor should both be off when you connect the cables. Then turn on the monitor first and set it to the correct source before turning on the computer.)
I hope this helps.
Aug 21, 2011 | Dell OptiPlex GX260 PC Desktop
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Sep 30, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell228wfp on start up pwr on is green screen
Either the cable is not connected to the proper port or the display-source is not configured properly.Here's what you can try.
  • Ensure that you have connected the VGA/DVI cable in the correct port. If you have an extended graphics card in your computer, use a DVI cable(Digital input) else the VGA would be the only option available.
  • If the cable seems to be plugged at the right place, press the first button from the left on the front panel of your monitor (Button 1 shown in the front view: http://support.dell.com/support/edocs/monitors/E228WFP/En/ug/about.htm#Front_View), once. This toggles the digital mode to analog mode of your monitor, and vice versa.
  • If the first two steps do not work, its not an issue with the monitor. It could be a failing cable or a defective video card, or the system itself is not completing the POST.
Thanks,
Abhishek
Feb 06, 2010 | Dell E228WFP LCD Monitor
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
Monitor goes black............
try checking the cables first.
May 28, 2009 | Dell E176FP 17" LCD Monitor
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Monitor problems
It seems that you are trying to use a graphic mode that your monitor doesn't support.
Restart windows in safe mode, go to Control Panel. Click on Display. Select settings and change to a resolution that is supported by your monitor (I don't know your model, but 1024x768 is a safe bet).
Restart the computer.
It should be working by now.
Dec 21, 2008 | Relisys RLT1720 17" LCD Monitor
Computer monitor won't tur on
check the connector to the pc from the monitor. it may have come loose. if you have a mouse, try moving it and see if the light on the monitor turns to green. it is possible the video has failed.
Dec 02, 2008 | Dell Dimension 2400 PC Desktop
MONITOR WILL NOT TURN ON AFTER POWER OUTAGE
I am sorry about this but the correct repair for this issue is replacement of 4 transistors on the main power board inside the monitor I just completed a repair on a dell 17 inch monitor it now works flawlessly. the process can be found on the internet and it is very delicate work. if you can all their service center you used then by all means call them,
And just fyi TYPING IN ALL CAPS IS THE SAME ASSCREAMING AT THE TOP OF YOUR LUNG SOO PLEASE STOP AND USE CORRECT NETTIQUET.
you have a nice day now.
Oct 27, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell monitor dead
If all your lights are on on the front on the 2000FP then the logic board is bad and the eeprom at49bv8192at will need to be replaced and reprogrammed. Check out www.lcdrepair.us for Instruction videos on the 2000fp as well as parts
http://www.lcdrepair.us/Installation.html
Nov 29, 2007 | Dell 2000FP 20.1" LCD Monitor
Dell M991 19" CRT Monitor Logo
166 people viewed this question
Alun Cox
