Question about Refrigerators
FAN NOT RUNNING - Refrigerators
  • 242 Answers
Ohm the motor out to check if its bad , if not it could be a defrost board. send me the model number if you still need help.
Phil
Posted on Apr 14, 2009
How do I fix the Convection Fan not running/working
Make sure that the fan motor is being energized. If so, and it does not run then the fan needs to be replaced.
Apr 20, 2016 | Breville The Smart Oven Convection Toaster...
Tip
Suzuki Grand Vitare 2.0l. How to check why heater fan is not running
If the heater fan is not running;
1. Check the fuse first of all.
2. Check if the fan is running when connecting 12VDc directly to the fan.
If not running . Replace Fan.
3. If Fan OK - check the voltage on the connector from the fan between red and Black wire. Must be 12V
If no 12V - Supply voltage is missing - probably fuse defect.
4.If 12V = OK - measure the voltage on the Violet wire in the connector.
When button on dashboard is set to "Fan active" You must measure a voltage here close to 10VDc. If OK Fan Resistor/Regulator defective.
5 If no voltage (10V) on the wire (violet) when set to "Fan active" controlboard behind the dashboard defective.
on Jan 31, 2011 | Suzuki Grand Vitara Cars & Trucks
Why will 2005 Polaris Magnum 330 fan not stop running when the ignition is turned off? The running fan drains the battery.
replace the faulty fan relay or check for a problem wire from the ignition to the sensor to the relay
Mar 03, 2016 | Polaris 2005 Magnum 330 4X2
My air conditioner has stop working its blowing air inside but the fan is not spinning outside .....
If the fan is not running is the compressor not running also...if neither is running the possible reasons are 1..no power to outside unit...2..bad contactor on outside unit.is this buzzing if it is this indicates no power...3 bad capacitor,do both compressor and fan humm then quit humming and hum some more...4 high pressure switch has shut unit down because fan wasnt running if compressor was running but not fan....if your unit has this there will be a manual reset button where the lines come out of unit...if compressor was running and fan was not...1 bad fan...2 bad capacitor.. if you do not have any electrical knowhow i would recommend calling a hvac tech to come and fix unit...Thanks
Feb 01, 2011 | Samsung AS18A6RB Air Conditioner
My fan is not running
Which fan is not running? Case fan, CPU fan, PSU fan? CPU fans will cause the computer to shutdown automatically usually with in a few seconds of boot. If it isn't running at all, simply replace it. They are measured in milometers 40, 60 , 80, 90, 120 and some 200mm form factors. Just replace with the same size fan size and you should be up and running again.
Comment if you need more help.
Aug 14, 2010 | Dell (6F858) Cooling Fan
Compessor is running hot, fan is not running
need to know brand and model. which fan was replaced ( evap or cond ) . if evap fan it may be the door sw as some model only run fan wth door closed. if it's the cond (fan) motor then ck wiring at compressor . or borken wire. in or about the compresser area .. hope thes help . mm
Jul 05, 2010 | Refrigerators
Was vacuuming coils/bottom of fridge and my brush hit the fan and now fan is not spinning. Does the fan always spin or only when called for??? HELP HELP
If the compressor...the black can in the back...is running then the fan should be running...
if it is not running when it should be, check the fan baldes, you may have bent one or more of the blades and now the fan is stuck because it cannot turn...
If so, just bend the fan blades back stright so they do not hit anything...
heatman101
Apr 25, 2010 | Refrigerators
If the weather outside is cold and you are running the heatpump/aircondition. Is the fan motor on the outside suppose to stop running. I notice the there is heat coming from the unit after it as been...
yes the fan will shut down during the defrost cycle. But the fan only shuts down during this cycle....other than defrost the outdoor fan motor should be running during a call for heat.
Jan 07, 2010 | Amana Heating & Cooling
My condensor fan is not running. I looked in the
Hi, Check voltage to the fan. The fan will only run when the compressor is running. If you have voltage to the fan whilr the compressor is running, replace the fan.
I hope this helps. If I can assist you further, please let me know.
Thanks
Vic
May 14, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
