Question about LaCie (300740) 160 GB Hard Drive
Lacie Drive Locked
I took my Lacie drive over to a studio to get some files and when they tried to put data on it, they called me and said the drive was locked. How can I can I get unlocked? Also I took Lacie drive used on a mac, can I use it on a PC without reformatting it?
  • Anonymous May 10, 2008
    i to
    Novelist:
    Champion:
  • 382 Answers
If your drive was used in the Mac OS environment, it is quite possibly for the drive (depending on ownership) to be locked. Unlocking the drive, is achieved by clicking on the drive once, then going to the top of the FINDER menu and selecting FILE, and on the drop down menu select GET INFO. You can also arrive at this by pressing both the APPLE and letter I key after the drive has been clicked on once to select it. At the bottom of the info column, you will see OWNERSHIP & PERMISSIONS. By pressing the drop down triangle, you will see a second dropdown triangle at DETAILS. Selecting the DETAILS dropdown will allow you to see the padlock, from where selecting that (and knowing a password if there is one-to the drive or user account on the Macintosh being utilized) should unlock the drive and give you further security options. As far as utilizing an external harddrive on both platforms, networking ofcourse works if the drive is stationary. A few other options I could mention would be looking into a solution called MAC DRIVE, a retail software which allows a drive to be read from and written to both platforms, with no issues or having to reformat. Another, is if your computer supports PARALLELS, you can run dual OS and access the drive on both sides that way, depending on how the drive is formatted. Hope this works.
Posted on Sep 18, 2007
  • 44 Answers
By locked, the studio probably is trying to read your mac hard drive on a PC. There isn't a format that you can share between both mac and PC, however, there are a few utilities out there that claim to allow reading of each other's formats. If it helps, I would network the mac and PC and share the drive from the mac across the network. Then, both could write to the drive.
Posted on Sep 15, 2007
SOURCE:
Missing files after using the recover CD
In this case try some data recovery program to see if it can help rescue your data on your external.
May 31, 2010 | LaCie (300728U) 250 GB Hard Drive
'not formated'
That's because your Mac was using a file system called HFSX. Windows uses NTFS. They won't be able to talk to each other without some sort of emulation. Check out http://hem.bredband.net/catacombae/hfsx.html for a free/open source app that you can install on your Windows machine that will read the data on the Mac-formatted drive. If you are just trying to get the drive to work and don't care about the data, right click on it from Windows Explorer, select "Format", then make sure you set it to use the NTFS file system.
Aug 09, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Can an older Lacie drive (2005?) work with an HP tablet?
The native file system for Macs is HFS. If the drive was originally used with a Mac, the current file system on the drive is HFS. Windows uses NTFS and is not compatible with HFS; which is why Windows doesn't recognize the drive as valid.
You can download a data retrieval tool called MacDrive that will give Windows the ability to speak Mac. There is a free trial available and it should be able to help you grab the files off of the drive.
Aug 06, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I was copying a large amount of data - 65GB from the drive to a network drive and the USB cable was disconnected. After reconnecting some of the files sre on the network drive (~ 1/3) some are on the Lacie...
Your copy process was interrupted so you'll need to perform the entire operation again to ensure you have all of your data and to also make sure none of it is corrupted.
Jul 10, 2009 | LaCie 160GB Little Disk USB2/FW400 160 GB...
Lost my data from my imac drive trying to backup to my Lacie.
yes U can recover it... plz download the registered version from the torrent site of software know as DATA DOCTOR RECOVERY .. this software will help you getting back you Data if you did not formated the Hard drive.. thank u for asking Question..
Jun 23, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I need all the start up files for a lacie hard drive
there this great program called Active Boot Disk, you can find it at http://www.ntfs.com/ its a program made to recovery any lost data from both NTFS and FAT32 hard drives, great software you should consider downloading it to restore your lost information.
Apr 16, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
500G drive wont let me open it
if you dont hear any click sound or we called it death sound on HDD, you can still salvage the data or files from your HDD,
Mar 23, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
Locked Folders
One week ago my LaCie external disk has been locked during a system reinstallation process in which the hard drive was plugged in.  The message was that I had no permission to access it. I thought I would loose for ever all the files I have been backed up for years. But finally I have got the solution for that. There is a sofware called MacPilot (I used version 3.2.6, $20, 15-day trial) that fixes it. Once instaled, click TOOLS, then "Files&Folders" at left, then "Unlock File or Folder", press "Choose", it opens FINDER and then you click LacCie Disk. When the padlock symbol at the botton of LACie disapears, you can finally change the permissions to "read&Record". That's all, and I hope it helps.
I recommend that you always unplug external hard drivers during system reinstallation to prevent that.
Feb 22, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
Lacie drive won't mount
I solved the problem. It was a power supply problem. It seems after searching boards on the net, this is a common problem with the lacie hard drives. Just replace the power if your hard drive is clicking and not mounting. I think many people must be throwing the drives away thinking they are lost when it is just the power supply. Try this first before trashing it or spending a lot of money on data recovery programs/
Nov 13, 2007 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Open Questions:
LaCie (300740) 160 GB Hard Drive Logo
1,960 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
