Question about Epson PowerLite® 1700c LCD Projector
Green spot in middle of image as though a spot light was shinning on the screen. I've replaced the lamp
I have dual projectors in a small auditorium. The image on one of the projectors has a green circle in the middle as if someone is shining a spot light on the screen. I have replaced the lamp but the spot is still there.
    Champion:
  • 205 Answers
Welcome to LCD 101, the blue device is dying in the projector. Replace product with dlp brand and it will last a lifetime. good luck
Posted on Jul 07, 2009
    Problem Solver:
  • 6 Answers
This is due to color filter problem, You need to replace the filter.
Regards,
prakasam
Posted on Jul 08, 2009
  • 22 Answers
I need more info on this spot as to its description so i can help you more, also is it green and not yellow?
Marc Engineer
Posted on Jun 17, 2009
SOURCE: Won't turn on, only flashes red light
Probably the filter is blocked. Unplug the power lead at the back and leave for about 30 seconds. Plug back in and it should work. The first opportunity you get, buy some compressed air and give it a good clean.
Posted on Nov 18, 2007
dhiman
  • 115 Answers
SOURCE: projector problem - Epson EMP-S1H Multimedia Projector,
try to reset lamp by using menu, up, down and enter buttons. also reset the filter and try again.
Viren
Posted on Nov 27, 2007
zabolyx
  • 38 Answers
SOURCE: images has a blue color across the center
Wow, 3 in a row. As described on 2 other projector issues this is very similar to those others. I'll repeat the info here.
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the blue color has gone out. The image is made up of red, green and blue images layered upon the screen. If the blue panel has gone out then there is nothing filtering out the red light in the image.
It looks like yours has just a secone of the panel dying or comming loose from it's connector.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Posted on Apr 01, 2009
SOURCE: Wonderwall projector has black spot in middle of screen
My guess is that you have the projector flat on something? I did that and got the spot right away. The directions says NOT to lay flat, you must use the arm/handle so it will not overheat. Next time you get the spot pick the projector up and it should go away in about 10 seconds. It is overheating. Use the arm/handle, if you need it to sit level place a wii game or something similar size in the back to level it out.
Posted on Dec 26, 2009
projdoc
  • 2237 Answers
SOURCE: When turned on the projector has a pink spot
you have a fried polarizer on one of the lcd panels due to excessive dust and heat. may need to replace the whole optical engine.
Posted on Jan 27, 2010
I have sanyo projector model PDG-DSU20E. Few white spots appeared on the right side of the screen. Gradually the spots has filled the right side about 1 feet is width till bottom of the screen. Now few...
1,white spots appeared on screen,means the DMD is broken,you need a new DMD.
2,the projector running off after only a few minutes,means the Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Sep 11, 2013 | Optoma PRO250X Projector
Dark spot in middle
A plastic prism between the lens and the lamp is melted. can't find part no. PLNS-A056WJN2
Jun 30, 2013 | Sharp XR-10X Multimedia Projector
Infocus IN24 Projector has large Dark Grey/Black Spot in the middle of the image.Lamp has 600 hours,Installed my spare "NEW" Lamp,still the same,Bulb makes no difference.Was watching a movie...
There is a lens(looks like a small magnifying glass) made out of plastic that the light shines through to focus the light on the mirror before it hits the DLP chip, that lens is Melted in the center. I unfortunately had the same thing happen to me, and I am unable to find a replacement part.
Jan 16, 2011 | InFocus Work Big IN24 DLP Projector
Projecting in green.
lamp may be on it's way out. if the mercury vapor burns at a different temperature than it's designed to, you will get a different color. also check the lamp for bulges, black spots or fogging. if it has any of those, replace it. if the lamp is ok, replace the ballast.
Dec 16, 2009 | NEC NP100 Projector
My EPSON EX70 flashes green when turned on then
the lamp may not be striking. check the lamp for bulges and/or black spots inside. if there are, replace the lamp. if the lamp is ok, replace the ballast.
Nov 29, 2009 | Epson EX70 LCD Projector
Black dot appears in middle of screen when watching a movie
we changed out the light buld... now it works fine.. funny thing was projector was brand new just out of box... you could see first thing there was a brown spot in the center of the buld creating the spot apparently after it heated up.... thanks again
Aug 05, 2009 | Sharper Image 1617293 Projector
I have an Mitsubishi X490U Multimedia Projector - it hangs inverted in our church auditorium. The image on the screen looks okay with bright images projected, but dark images appear to look green...
This unit needs a new Optical block, most likely more than a new projector
check out projectorsuperstore.com for a replacement
by the way, your $10,000 projector only has 2600 lumens, a new/refurbished unit will have 4000 lumens for less than 25% of the cost of your unit
Jul 11, 2009 | Mitsubishi X490U Multimedia Projector
Images has a blue color across the center
Mar 14, 2009 | Epson PowerLite® S4 LCD Projector
Projector Problems
There is some problem in your LCD Panels. Service the optical unit ant retry.
regards
Viren
Jun 30, 2008 | Office Equipment & Supplies
Epson PowerLite® 1700c LCD Projector Logo
1,617 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
