Question about JVC BR-DV600U Mini DV VCR
VTR won't play
I recently purchased a used JVC DV600U. I digitized one tape and when I went to do a second one the machine would not play. The rewind still works. I tried to use the head cleaner but since the play doesn't work I had no luck. Any suggestions or should I take it into the shop? Thx
    Genius:
  • 1,139 Answers
I would take a look at the loading machanism to see if it is properly loading the tape, usually on these type of machines if the tape is not being loaded properly the tape will not play. The rewind working indicates that the motor is still working so what you may also have is a gear problem, in which you will have to look at the gear system as the tape is loading and trying to go into play mode. This looks more like a mechanical problem then an electronics issue. However I would not rule out have to take voltage measurements to confirm that the electronics are ok (you will need a schematic for this, and a multimeter).
Posted on Sep 15, 2007
Videorecorder videodrum replaced
I would say that it's because you haven't used the original test tape. Where the recordings that play up done on the model before the problems started? If so then that would prove that the tape is just slightly off. I can't see it being a fake head, nobody would make any money doing fake VHS heads these days!
May 19, 2013 | Televison & Video
Video on my Sony VCR (SLV-780HF) goes gray after playing a tape a few seconds. What could be the problem?
The only real cure will be to clean the video head. If that doesn't work then I'm afraid that whatever recorded you EP mode tape was not set up well tracking wise. So other machines struggle to track the tape. Some VCR's will only playback SP or LP tapes and don't have EP mode. In which case you should check to see if these VCR's can play the EP tape and if they can't find one that can.
Dec 06, 2012 | Sony Televison & Video
Mini DV Tapes are not playing back. Nothing but blue screen when I try to view tape...no time code...nothing. Recently recorded footage plays back fine though?????
If recently recorded plays back ok, and there's no warning about low rf or head clogging problems,it seems to be electronic problem in vtr board,but usually is head problem,which is not so expensive.
Jul 30, 2009 | Panasonic AG-HVX200 Mini DV Digital...
JVC GR-D870 digital camera, how to transfer Min Div tape to PC
Hi, You need to use 4 pin firewire cable to connect to the PC. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | JVC Cybercam GR-D200US Mini DV Digital...
Cannot view playback!!!!
First thing to determine is if your (Playback Mode) is set for Auto or Hi 8 / 8. Select VTR setting and then select Menu. Scroll to PB Mode and select Auto. Now try playback.
Oct 25, 2008 | Sony Handycam DCR-TRV820 Digital-8 Digital...
No sound when playing back video footage
If there is an external microphone jack on the camera, it would help if you tried recording with an external microphone. Also, the mini DV's will mute the sound if the tape guides are slightly out of adjustment. You can tell if they have moved by trying a known good sound tape in the machine. If that plays with no sound also, the tape guides have moved out of alignment.
Sep 16, 2008 | JVC GR-DX97 Mini DV Digital Camcorder
Help With My Digital Video Camera!
You try it with proper connection using a new or working wire if you have used a vcr to play back.
Play the tape with any other camera.Bcoz your monitor may be fault.
Play the head cleaning tape in the camera, and try
May be the recording head of your camera is clogged
Mar 29, 2008 | Photography
VTR mode controls are not working properly
Hi, You need to replace the switch block control whic has all you play and zoom functions. Or, you could use your remote control to do these functions instead.
mr cicmo
Dec 29, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
Tapes won't play
This is an indication that both data heads are dirty. In a digital camcorder both heads need to be operating correctly to obtain a full picture. Insert a new cleaning tape and run it for only 10 seconds or less, this should clear up the problem. Avoid using the tape that caused the problem. Do not use the cleaning tape for regular maintenance, this will damage the drum surface. Good luck to you! Joe Weibel Custom Electronics (customelectronics.org)
Feb 14, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Tapes not in 24p play for 2 seconds than stop, WHY?
The BR-DV3000 DV deck has LP inhibit function which is set in the operations menu. JVC does not recommend the use of LP mode and therefore locks this mode out by default. You can change this setting to allow operation in LP mode if you like but I don't recommend it. Using LP mode on DV tape causes the error rate to escalate due to the narrower track width produced by the slow moving tape. Good Luck, this is a nice machine! Joe Weibel Custom Electronics (customelectronics.org)
Feb 13, 2007 | JVC BR-DV3000U DV/Mini DV VCR
JVC BR-DV600U Mini DV VCR Logo
154 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
