Question about BenQ DC3400 Digital Camera
AC Power Adepter for Benq DC 3400
My AC power Adepter for the Benq DC 3400 is damaged.. where can i buy it from ...local stores donot have them.. I live in Dibrugarh,Assam, India.
  • Anonymous Apr 01, 2014
    my digi cam model benq DC C850.In battery side the close door is damaged.that door break from the cam any chance to repair
Benq ? ? ?
such a brand that no spares are available in market.
so, say no to Benq.
Posted on Jun 10, 2008
Toshiba satellite won't go on
Hello. It sounds like either...
1. Your power adapter is damaged/not working. Look and see if a LED is illuminating on the power adapter. If it is chances are it is working fine and the problem may lie on your laptop. If not replace it. The easiest way to tell if your power adapter is bad is to go out to Wal-Mart or your local technology store and purchase one of their universal power adapters. They are expensive but you can buy it, try it, and return it if it does not solve the problem.
If you are going to buy a new toshiba ac adapter, you may consider the following toshiba l355 charger:
Replacement Toshiba Satellite L355 AC Adapter 90Watt 19V 4.74A
OR
2. The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50
Dec 01, 2012 | Toshiba Satellite L355-S7811 Notebook
No power,no beepings to detect,only power button light but theres no display.
check ac/dc jack adepter if not normally you can change that
Jul 22, 2011 | Computers & Internet
It has stoped all together no power is there a fuse
Hi there yes internal fuse may damaged or the power transformer is damaged & that;s why its not supply the power to the main circuit board. Also make sure the battery is working condition. How about the DC power ? Is that working on Power Adepter?
Jan 01, 2011 | Panasonic NV-GS17 Mini DV Digital...
Can I use an alternate plug in the Ac port of my notebook.
Hi Al,
A badly repaired AC charger can damage an expensive laptop. For this reason Sony does not distribute the connecctor alone.
You can buy an original power adapter for a low price, see here: 19.5V 7.7A Power supply Charger adaptor Sony.
Alternatively find a local spare seller and buy a DC connector with this specs:
Connecter size:
Internal Diameter: 6mm
External Diameter: 4.4mm
Regards.
May 06, 2009 | Sony VAIO PCG-K35 Notebook
What does umax astra 3400 scanner power adapter looks like/
who cares if it is the proper voltage,amps and plug. . you need a wall wart , the plastic box with two flat blades sticking out that 12volts DC center positive ,700 milliampsfor the non negatine scanner and 1 amp(1000 milliamps) for thr negative scanneer model an AC/DC adapter look around at 2nd hand stores they usually have a selestion or order online from electronics supplier
Jan 13, 2009 | Umax Astra 3400 Flatbed Scanner
WHERE DOWNLOAD
my AC power Adepter for the Benq DC 3400 is damaged...
Jun 29, 2008 | BenQ DC3400 Digital Camera
CHANGE BATTARY BENQ DC 3400
baterry can not be charging . I LIVE HYDERABAD IN INDIA
Jun 24, 2008 | BenQ DC3400 Digital Camera
BenQ DC3400 Digital Camera Logo
121 people viewed this question
Top BenQ Cameras Experts
Daniel Dollive
Daniel Dollive
Edward Talavera
Edward Talavera
Are you a BenQ Camera Expert? Answer questions, earn points and help others
