Question about Mtd Troy-Bilt Bronco OHV Tiller
Have an older Troy Bilt Tiller with Tecumseh 8hp and the pull cord (did not break off) came out. I want to replace it but after taking the cover off cannot tell where the cord connects. Does it connect on the underside of the cover or on the housing on the engine itself. If so how does it connect?
landsend
  • 1066 Answers
SOURCE: I just purchased a troy
remove the spark plug.  And pull the cord again.  if the carb float is stuck down or you overfilled the oil you could be hydro-locking the engine.  Check.
Posted on Mar 29, 2009
  • 112 Answers
SOURCE: How to install belt on Troy bilt tiller:
With engine OFF If you put belt on engine pully and driven pulley then work the clutch handle you should be able to see how belt goes so it tightens when clutch is worked.
Posted on Jul 16, 2009
01fordeb
  • 1033 Answers
SOURCE: Engine part for Tecumseh 6hp 195cc
The float and pin can be bought as a repair kit., and replaced.
Posted on Mar 24, 2010
kel1guy2002
  • 3740 Answers
SOURCE: How can I get a Owners Manuel for Troy Bilt Tiller
Hi and welcome to FixYa. I am Kelly. We need the exact model number to be of any help in trying to locate a manual for you.
If you have your model and serial number you can use this link.
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
Thanks for using FixYa.
Kelly
Posted on Apr 23, 2010
emissionwiz
  • 79865 Answers
SOURCE: Troy bilt Bronco tiller Model#
Recheck the pulleys, sand the pulley grooves until they are rough for max grip w/80 grit and do a careful pulley alignment check with a straight edge, don't just eyeball it, then make sure the belts are not to loose, about 1/2" at center run of belt is good enough,
Posted on Oct 19, 2010
Starter rope on Troy Bilt tiller will not pull
Remove spark plug and try to pull. There could be water on top of cylinder. Would replace rope before you beeak as it will be easier to see how it is wound etc. There should be many videos online showing you how.
Nov 18, 2017 | Troy-Bilt Garden
Can't pull starter rope on Troy Bilt tiller
take the spark plug out and see if it will pull then. be sure there is no obstruction in the tines and that they are disengaged.
Can't start my Troy Built Tuffy tiller. I haven't used it for a year, but it started fine last season. I replaced the spark plug, changed the oil and air filter and filled it with fresh gas. When I pull...
First pull your spark plug out reconnect to the plug wire and ground tot he engine body
Pull the starter cord and see if you have a good clean spark that goes to the electrode and not to the side of the spark plug.
If no spark check your off/on switch
Mar 31, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy bilt hasn't been used in 2yrs.; has oil and gas in it but will not electric or pull cord start...
1st I would drain the gas and put new in. It loses octane over time. Then try new spark plug. Also you may need a new diaphram in the carburetor. They are cheap and sell them at most hardware stores.
Dec 20, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at kerryjonjon@yahoo.com and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
Jul 17, 2009 | Troy-Bilt Pony Garden Tiller
I have a Troy Bilt Tuffy Tiller H30-35387S Ser 91330. The only number I can find for the tiller is on the shaft housing between the tines and the wheels and it is X0010527. I need a manual or parts diagram...
You've got the right serial number - it appears you've got one of the older Tuffy's. I'd suggest keeping an eye on Ebay for the manual you're looking for. I find them out there with some regularity. You can't get them from a dealer anymore because this Tuffy was sold by Troy Bilt before they went bankrupt and MTD bought the assets.
Jul 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I can't move my Troy-Bilt tiller unless it's running.
Some Troy Bilt Tillers were designed with a manual "free-wheel". If yours is a Tuffy (and maybe a Junior), you have to pull pins out of the wheels to move the tiller without starting it. The larger tillers, Pony's and Horses, had a lever to shift to release the wheels.
Jun 12, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
May 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Does rear tine tiller run 2 belts
Check the Troybuilt website for specific info on your tiller.
www.troybuilt.com
Mar 22, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Need manual for a Troy-Bilt Tuffy tiller
Your engine number is wrong by only one character. The proper number is H30-35387S you had a 5 instead of the S. You can download the engine manual from Tecumseh. I don't know about The rest of the tiller. (I have the same tiller).
Feb 21, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Mtd Troy-Bilt Bronco OHV Tiller  Logo
389 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
