Question about Toshiba Satellite A135 Notebook
Toshiba a135-s4487 when on battery the lcd screen flickers and dims considerably.
  • 489 Answers
When it first switches over to battery, you will generally see a flicker. The dimness is normal. Most laptops are configured to display the LCD screen when on battery power to allow longer operation on battery power. This can be overridden in the Control Panel -> Power Options but doing so will reduce the amount of time you will be able to work on battery power. The time before it enters sleep mode is generally shorter as well for the same reasons.
Posted on Apr 14, 2009
Nesecito driver para XP de la toshiba A135-S4487
Here is a link to the driver download page for that laptop model. ToshibaDirect
May 02, 2011 | Toshiba Satellite A135-S4487 Notebook
I have a Toshiba Satellite A135-S4487 laptop, After install Windows XP system operating, only Touchpad is not working. How to repair this problem? Thank you for your support.
We you have installed the operating system (windows xp) but seems like you have not yet installed the drivers
There would be a second disc that you might have got from the manufacturer (application & drivers or Driver and utility CD) please insert the same and try to install the touchpad drivers
Else you can always download the same from the manufacturer website
Oct 03, 2010 | Toshiba Satellite A135-S4487 Notebook
I have a toshiba Satellite a135-s2386. It powers on but nothing on the display. I think I need a new motherboard. But am not for sure. What is the part number for this motherboard. any help will be...
Does the laptop appear to boot up but the screen id blank?
Does the hard disk LED light flash?
If so you may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Dec 09, 2009 | Toshiba Satellite A135-S2386 Notebook
My notebook fan wont come on
Usually the fans only come on when they are extremely hot. The fan will not run alot or it'd kill the battery really fast. You could always get one of those notebook coolers that sits under and connects via usb.
Sep 12, 2009 | Toshiba Satelite A135-S4487 Notebook
I have a toshiba a135. the screen has a red color to it. i replace the power inverter and the lcd screen but nothing changed. I was putting it back togeather and i was moving the lcd screen and the redness...
This could be a faulty CCFL lamp.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 12, 2009 | Toshiba Satellite® A135-S2266 PC Notebook
Toshiba satellite a135 monitor goes black
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S2386 Notebook
Keyboard not working
first check with another external keyboard if it works ok, otherwise remove the keyboard drivers from device manager and then the restart the system
Mar 16, 2008 | Toshiba Satellite A135-S4487 Notebook
Toshiba Satellite A135 Notebook Logo
97 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
