Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Leaky fridge why is my fridge leaking water inside?
  • 297 Answers
Can the water get out the normal way by that little defrostchannel hole in the back and down to the vaporizationplate on the compressor?. If not clean. If not possibly defrost totally because clogged witth ice already. takes longer then one hour .....
Posted on Apr 14, 2009
If my heater core was leaking,why wouldnt i have water on my cabin floorboard? how do i tell if heater core is leaking?
Scott, do you see external leaks on the ground? Where? if so, that's not a leaky core, but something else,
When you turn on your defrosters the anti freeze may vaporize and cause a film to form on the inside of the windshield. Take a cloth and wipe the inside of the windshield to see if it smudges. If it does, it IS leaky core inside the box. If not, it still could be a leaky core, but it is not enough to get blown around yet. The heater core box is acting like a bucket. Pull the carpet back by the passenger's feet at the firewall. look to see if it is soaked under the carpet. Pull back the Driver's carpet. Antifreeze travels. Do you see external leaks on the ground? Where? if so, that's not a leaky core, but something else, Lastly, does it smell like antifreeze inside the car? Check all this out and let us know your outcome, Scott. (A heater core in a modern care is not for the faint of heart or limited skill levels.)
Jan 01, 2015 | Cars & Trucks
Water leaking on the floor from fridge
That might be a leaky water valve connection Or it could be bad door gaskets.
Feb 15, 2010 | Refrigerators
Turned Whirpoll ED22PE off and moved to install new flooring. Put back to previous location, connected water and elect...would not make ice. Someone said it has a temp sensor and must be 10 deg b4 making...
If the water valve is leaking a bit, it will cause freezeup, as will a flow restriction. The 'water splashed inside freezer' sounds like leaky shut-off valve.
Sometimes those 'saddle pirecing' water shutoff valves get restricted, so you are not getting enough pressure.
Also, if you had things disconnected, a little bit of grit may be in the filter or shut-off valve, causing issues.
I would:
a) check the house water pressure, to make sure it's normal
b) check/clean/replace fridge water filter
c) inspect/replace saddle valve and look for kinked water feed line
d) backflush water out of fridge, if possible, and look at clean/inspect/replace water valve.
Although they do make add-on heater kits for water maker feed lines, your issue just sounds like a water flow issue...either a leaky valve or a flow restriction.
Nov 02, 2009 | Whirlpool GS6NBEXR Side by Side...
Fridge constantly dripping wet
water inside, too much condensation from humid air entering fridge from bad seals. replace the seals. could also be that the condensate drain is clogged. if it's leaking from the bottom of the fridge, make sure the tubing is still inside the condensate pan underneath the fridge.
Aug 24, 2009 | Whirlpool Freezers
GE side by side leaks water onto floor, no ice
There is a pipe that runs up the back of the appliance and feeds the ice maker , if this freezes inside then it canpush the fitting off the back of the appliance and cause water to go everywhere. Usual problem is a leaky watervalve causeing water to drip into the pipe which freezes and builds up until it is totally blocked.
Aug 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaky ice maker
Could be that the supply tube is frozen inside the freezer compartment, so the water is finding its way out of of the inlet line. Try thawing the supply tube with a hair dryer.
The primary cause of frozen supply tubes is either 1) a leaky water valve that allows water to keep dripping into the supply line even when the valve is shut -- or -- 2) a restricted airflow to the back of the fridge, usually caused by an accumulation of dirt around the base of unit. First check under the fridge - if it's filthy (as many often are) clean it well with a vaccuum cleaner. Then thaw the supply tube and see if that fixes it. If not, you'll need to check the supply valve. Not hard, but beyond the scope of this reply. Check out this link http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Jul 17, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
