Question about Philips Magnavox DVD/VCR Dual Player
No display on tv when using remote control
My granddaughter was playing with the dvd/vcr remote and hit some of the buttons - now I don't get a display on the tv screen so that I can set the timer to record or even set the timer.
Check it is getting power or not.
Posted on Apr 14, 2009
Installing a dvd. how do i swithch the signal from tv to dvd
THE COMBO WHEN YOU HIT PLAY SHOULD BE AUTOMATIC AND DISPLAY PICTURE AND SOUND ON THE SCREEN---THIS IS LISTED AS A TV-VCR COMBO SO IF dvd hooked to one of the rear inputs (some are also on front on some models) in the menu you select that input and should see the picture and hear the sound from the DVD.
Mar 19, 2012 | Sylvania SRC22134 13 in. TV/VCR Combo
How to reprogram a universal remote control?
http://www.youtube.com/watch?v=fXDdeXmJjfM
http://www.remotecentral.com/features/remotes.htm
Instructions
    • 1 Find the brand of the universal remote you own on Internet sites like Remote.com (see Resources below).
    • 2 Click on your universal remote brand on the website to find the code list for that remote.
    • 3 Check to see if your remote is preprogrammed to operate your TV, VCR, or Cable Box using the following codes: TV - 000, VCR - 000, Cable Box - 000, AUX - use VCR code 037.
    • 4 Manually turn on your device. Hold down the "Code Search" button on your remote, then press and release the device button you want to set up until it flashes.
    • 5 Push the power button repeatedly until the device turns off, then hit "Enter."
    • 6 Press any other button while the device is on to see if the device responds. If it does, you don't need to do any other programming. If it doesn't, repeat steps 4-6.
Read more: How to Reprogram a TV Remote ' eHow.com http://www.ehow.com/how_4454612_reprogram-tv-remote.html#ixzz1mji7B48P
Feb 17, 2012 | Sony DVD/VCR Combo Player
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
Can't see "Setup" screen, or any other screens on t.v. monitor
There should be a tv vcr button on the remote control. What you done was you accidently shut off the VCR function. If you hit that button again the tv vcr button it will come back on.
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
VHS won't work
Had the same problem on my JVC vcr/dvd combo unit.
You need to turn off the timer function. I did this by making sure my remote was in the "VHS" mode...turn the swith from TV to the right (found on the remote in the upper left corner...an then hit the "vcr" button. Then point the remote at the VCR unit and hit the No. 4 button (timer turns off). Your unit should not have the red timer displayed and you should be able to play your tapes okay.
Hope this helps.
Jun 11, 2009 | JVC HR-XVC27U DVD Player/VCR
Toshiba 62hmx84
Does your Tv have Input on the remote? if so maybe she hit the input button by mistake. The newer tvs have a few different inputs into them. Like HDMI or regular cable or vcr or dvd. i would try that to see if that helps. Hope you get it figured out.
Jun 27, 2017 | Toshiba 62HMX84 62" Rear Projection HDTV
Need instruction to program the remote RCA 450
took me awhile but I figured it out
ok
Put your TV/DVD/VCR on
hold in what you want to program TV/DVD/VCR BUTTON
(you dont need codes or anything)
then while holding in what you want to program (TV, DVD, VCR) hold in ON/OFF
both at the same time
when the light comes on and stays on
keep hitting ON/OFF BUTTON
do it slow, when the TV turns off hit the STOP button at the bottom
then hit the button you just programed
then hit the ON/OFF button, the TV/DVD/VCR will turn on
if it doesnt work, repeat. make sure you hit the stop button when the TV/DVD/VCR shuts off, if you hit it an extra time while the TV/DVD/VCR is off it wont work.
took me about 30 mins to figure it out.
I lost my codes too, but I wanted to help all you other people too.. now since I helped you.. check my band out... www.myspace.com/jumpercablenj
Nov 21, 2007 | RCA RCR450 Remote Control
Need codes for the RC450 remote
ok
Nov 13, 2007 | RCA RCR450 Remote Control
How to record from KS 4110 DVD payer to VCR
Connect your DVD player to your VCR ( the out put from the dvd player is connected to the input of the vcr) then connect your vcr to the tv( the output from the vcr is connected to the tv)
Set your tv to what ever channel you connected your vcr to and hit the tv/vcr button on your vcr remote until you get the vcr displayed on the tv.(ensure your vcr is on when doing that)
now when you get your vcr displayed on the tv , turn on your dvd player and set your vcr to what ever channel you got the dvd player connected to(e.g INPUT 1 etc)
you dvd player should now be visable on your tv
simply insert a blank vcr tape and play your dvd and hit record on your vcr
Aug 26, 2007 | Koss KS4110 DVD Player
DVD/VCR combo player won't work
I had a similar problem and corrected it with a solution found on another site. Try hitting the I/P button on the remote which controls whether "Interlaced" or "Progressive Scan" is used to display the image on the TV. Mine worked when "Interlaced" was used. but no picture was displayed when "Progressive Scan" was used. The I/P button toggles between the two settings.
Dec 19, 2006 | Apex Digital ADV3800 DVD Player/VCR
Philips Magnavox DVD/VCR Dual Player Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
