Question about ASUS PR-DLSW Motherboard
Memory stick problems!!
Hi everyone i have a huge problem i would totally be in awe if someone,anyone can help me.
is it possible to retrive the lost files if a memory stick is supposedly broken my expert brother's diagontis' is the little wire soldered to the other compartments is broken is there anything i can do at all to save bacically my whole life? meaning my memory stick???HELP???
    Scholar:
  • 85 Answers
It depends on how good you are with a soldering iron HA :) just kidding.
the two main problems that I get on broken flash drive are:
1. the usb plug has broken off the little board. (you broke the connector off)
2. The chip has came away from the board (you bent it and popped the chip)
The quick and dirty fix for this is get a giant flat pink eraser (the width of your thumb) and some thick rubber bands. If the chip is loose then strap it to its board with some rubber bands making sure they connect back as they should while using the big pink eraser as a backing and support. attach a short usb extension cable so that you will not have to move it to plug it in once you have it strapped in.
If the usb plug is broken off then use the same process attach the usb
extension to the plug remnants and then lay the two pieces as they should be on the eraser and rubber band them together.sometimes it helps to put a little wad of paper under them to make them fit snug. plug it up and away you go.
at this point windows will most likely see the drive and can copy off your files.
HOWEVER( it may complain its not formatted, make sure that you do NOT format it) download recuvia at http://www.recuva.com/ and have it chew on the drive usually I can get something off the drive occasionally all the files. Just make sure that you have it restore the files to another drive (like your C: drive) that is good. Good luck.
the correct way involves a stereo microscope and micro soldering tools.
and you just "fix" it by soldering it back together.
Posted on Sep 11, 2009
  • 32 Answers
It depends how it is broken, if it is physically broken then it might be possible. Often thumd drives break at the point where the usb connects to the circuit board in the usb drive. So if you plug it into the computer and put pressure up or down on the drive, it might make a good enough connection to get your files off.
If you have someone who can solder you can also just repair the connections.
If the stick is not physically broken you might be able to use something like getdatabackntfs to get the data off it. FIrst i wiould run a checkdisk from inside windows on the drive and see if it sees anything wrong.
Posted on Sep 12, 2009
I lost my nokia handset. Model is nokia1100. i have the IMEI number359534016718756. can u guys help me in tracing it or atleast retriving the data from the phone memory. in fact it would be very great if u...
Hello thanks for using fixya
If your cell phone is lost or stolen,it is not possible to trace it unless you ring your cell phone number and someone answers it and returns it to you.But you can inform your network provider with yours IMEI number who can then put the serial number on a shared database.This list stops this particular phone from registering on any network and will be useless for anyone even if the mobile phone's SIM card is changed
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Jan 22, 2011 | Cell Phones
Memory upgrade problem
Try each stick one at a time in each slot and if one doesnt work, then thats the bad stick.
Is it dual channel?
How many slots total do you have?
Feb 04, 2009 | Intel Motherboard, 945GC, Core 2 Duo,...
My radio is locked out
OK I know everyone likes a free answer but unfortuantly something like this requires a fee.
go to radio-code.com
they have a small charge but in depth procedures to retrive code
Jan 22, 2009 | 1999 Pontiac Montana
I deleted photos from the memory card accidentally how to retrive
hi reddy,
yes u can.
do not use ur card anymore. dont format it or paste something new
on it
use the following software: http://www.4shared.com/file/38961610/e1ff450f/getdataback332_fatentfs_c.html?s=1
download it.
the file system for your card is FAT or FAT32.
so use the FAT one.
good luck!
Jan 07, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Memory stick locked
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Jan 06, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
AMD Athlon 64x2 can't install, help!
which version update did you do?
only after 0804 will work
FAQ from ASUS
My system may refuse to boot under AMD Althon64 x2 6000+ CPU (OPN :ADX6000IAA6CZ) with 2x DDRII-800 memory combination.
The same problem does not happen with other CPUs, nor would it happen with memory modules of any lower specifications.
How can I solve this problem?
Please kindly update motherboard BIOS to version 0406 or later to resolve this problem.
BIOS 0406 can be downloaded form the link below:
ftp://ftp.asus.com.tw/pub/ASUS/mb/socketAM2/M2N-MX%20SE/M2N-MX-ASUS-SE-0406.rar
Dec 02, 2007 | ASUS M2N-MX Motherboard
Problem accessing memory stick
I had the same problem. I bought a 2 gig memory pro-duo with the adapter and it gave me that error even though it fit just fine. I then tried a 512 memory stick and a 1 gig memory stick and neither one worked it gave me the C:13:01 error code. So I found out the hard way that the camera will not read it. The Sony DSC-S85 will not take memory above a 128. Try the Lexar 64MB memory stick. I just bought 4 and they work perfectly fine.
Nov 02, 2007 | Sony Cyber-Shot DSC-S85 Digital Camera
ASUS PR-DLSW Motherboard Logo
88 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
