Question about Compaq Armada E500 Notebook
Compaq Armada Serial Port Broken
I have a Compaq Armada E500 but the pins of the serial port on the back side of the laptop are broken. My question is that if this serial port can be replace or i need to change all the mother board? Thanks a lot
  • SEVETEC Sep 14, 2007
    Thanks a lot Syclar,
    Yes I know you are right but this laptop is not mine is for a costumer so he wants to repair.
    I bought a serial port replacement but i really dont know how is the structure of this port because he just told me about this problem.
    I will suggest him to buy a USB to Serial converter, but the problem is thar sometimes and for some aplications this converter doesnt work.
    Thanks for your help Syclar
    PD. how can i contact you by mail?
  • 57 Answers
Do you really need the serial port? You should be able to find a USB to serial converter fairly cheaply.
Posted on Sep 13, 2007
  • Simon Clarke Sep 17, 2007
    You could download the service manual fromhttp://tinyurl.com/ysjcu4 but I can't really answer the question without disassembling it myself. The manual will at least give you the part no. syclarATcomputerate.co.uk
How do i connect crw-785 to compaq armada e500
This e500 has USB1.0 and transfer rate will be slow. If you use Win 98 then install the USB driver (get on web) first. Install software then plug in the USB lead from the crw-785 and don't forget to plug in the DC adaptor for the drive, (e500 USB port does not have enough power to run external drives other than some older thumbdrives).
Feb 24, 2015 | Compaq Armada E500 Notebook
Can i put pc133 in a compaq armada e500,it turns on but nothing on screen
you can put on compaq e500, because e500 Pentium 3 and use DIMM PC133, but not show on screen you must sure your DIMM no broken.
Apr 08, 2011 | Compaq Armada E500 Notebook
Dell laptop model latitude e5500 serial port one pin is broken. What can i do.
Hello there
Many serial port pins use several of the pins but sometimes not all of them It depends upon how the serial port is wired internally on which pins it uses.
But if yours indeed does not work you will have to have it replaced by a computer repair shop or sombody that is able to unsolder the old one from the board and have a new one resoldered one this generally costs about
100 dollars ok hope this helps
Best regards mike
Jun 18, 2010 | Dell Latitude D600 Notebook
What is the port number for the 9 pin serial connection. If greater than 2 how do I designate it as 1 or 2. Compaq Armada E500 laptop.
I've found it is highly unlikely to run an old DOS program in Win2000 so I have decided to setup an old computer with Win 3.1 and use it for my DOS software.
Jan 26, 2010 | Compaq Armada E500 Notebook
My usb port of my Compaq Armada E500 Laptop no
the usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
Jun 03, 2009 | Compaq Armada E500 Notebook
Broken Lcd hinges
No,you can't fix the hinges if they become slack, you wll have to replace the hinges,it's not too difficult on the E500.
Jan 21, 2009 | Compaq Armada E500 Notebook
Compaq armada e500 and webcam
The exceeding power cannot be fixed, the port are only allotted and capable of a certain power range. If the ports are faulty, they will need to be replaced, some are removable and some are soldier directly to the motherboard.
Jul 31, 2008 | Compaq Armada E500 Notebook
Compaq armada 500 (touch pad not working)
look at the ribbon/connector again, make sure it's not broken.
Sounds like a broken ribbon or bad connector.
May 23, 2008 | Compaq Armada E500 Notebook
Compaq Armada E500 PC Notebook usb port problem
If the usb connector / port is only damaged it should be a fairly easy task.
Your going to need a few screwdrivers to get the laptop open
and a soldering iron, to remove the port or ports connector(s)
from the motherboard then replace it with a new connector.
if the motherboard is damaged you would most likely have to replace the whole motherboard and that would be way too much money for a few usb ports.
the usb connector only has 4 pins
http://wolfstone.halloweenhost.com/Audio/mpg016_ConnectorUSB.bmp
Mar 30, 2008 | Compaq Armada E500 Notebook
HP Pavillion ze2000 serial ports not working
What type of peripheral have you tried to plug in?
Jan 03, 2008 | Compaq Armada E500 Notebook
Compaq Armada E500 Notebook Logo
218 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
