Question about Nikon COOLPIX L4 Digital Camera
Nikon Camera does not accept any memory card
My Nikon CoolPix L1 does not accept any memory card. Whichever card I inseert it gives an error - "This memory card cannot be used".
I was using SD card 512 MB but the same card (after formatting on computer) is not working as well.
Please assist.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Try formatting the card in the camera, not the computer.
Posted on Jun 03, 2010
How do I get the SDGC 8GB memory card to work for my Nikon s4100 coolpix camera?
You may need to format the card prior to first use. This should be in the menu system somewhere. Your manual should point you in the right direction.
Jan 09, 2016 | Nikon COOLPIX S4100 14 MP Digital Camera...
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
Sep 30, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Camera works with standard SD memory card, but not SDHC
There are hardware incompatibilities between SD and SDHC cards. They're upward compatible in that SDHC devices will accept SD cards but not the other way around. You will have to hunt down SD cards, 2GB and smaller.
Apr 28, 2010 | Nikon Coolpix L1 Digital Camera
Nikon coolpix 4600: How to transfer pictures from camera to card?
ok I figured out how to do it! put the memory card into the camera, then go to view the pictures. Then press the menu button and scroll until you see the copy button. Then you will see the option to copy from camera to card, or card to camera. Press the option to copy from camera to card and press select all....(or whichever pictures you want copied...I wanted all pictures copied). Then voila! it takes a few seconds to copy from the camera to the card, and there you have it! :)
Dec 26, 2009 | Nikon Coolpix 4600 Digital Camera
SDHC memory card
The L1 is an old camera, before the SDHC standard. There is no forward compatibility (SD devices can't use SDHC cards), only backward (SDHC devices can use SD cards).
The latest version of the firmware is available at http://support.nikontech.com/app/answers/detail/a_id/13783
That still won't let you use SDHC cards.
Dec 28, 2008 | Nikon Coolpix L1 Digital Camera
Memory Card Capacity for Nikon P4
you can put a 16 gig in without any trouble
Dec 20, 2008 | Nikon COOLPIX P4 Digital Camera
System error showing up on Nikon coolpix 3200
A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
1. Use the memory card that originally came with the camera (or a Nikon approved card)
2. Remove and replace the battery
If the error is still displayed, contact Nikon's Service Department (below). If the above tips do not help the camera must be sent to Nikon Service, there are no user serviceable parts on Nikon Coolpix cameras.
Jun 13, 2008 | Nikon Coolpix 3200 Digital Camera
Nikon Coolpix 5400
look into memory inserting slot if you see a bent pin, I doubt it, most likely something internal failed, as of now fixing the camera is not worth it unles Nikon fix it and most likely they will as this is possibly internal component failure, contact them and send it for a repair, they will give you estimate, if it is free or acceptable let them fix it if not garbage can will gladly accept it and move on.
May 23, 2008 | Nikon Coolpix 5400 Digital Camera
Memory card problem or coolpix problem?
We have the same problem. Seems to be a common problem.
Oct 31, 2007 | Nikon Coolpix 2000 Digital Camera
Coolpix L1 Lens error.
Seem like the AF system doesn't reach the home position, therefore the zoom is not closing. Or may be has been smashed and the zoom block is jammed.
Anyway you need professional help. Problem will be solved after a major srip down.
R. Calla C.
Oct 22, 2007 | Nikon Coolpix L1 Digital Camera
Nikon COOLPIX L4 Digital Camera Logo
728 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
