Question about Acer Aspire 5500 5570-2609 Laptop
Blue screen poping up
A blue screen pops up and says something about a crash dump what does this mean?
Memory dump blue screen
Sounds like you are having an audio driver problem try using a different driver for your sound card
Jul 01, 2017 | Computers & Internet
When I start my computer a blue screen pops up then it crashes. It has text on it but I don't get a chance to read it.
download Microsoft Debugging tool here
just select the version of your computer (OS and if it is 32bit or 64)
install it.
then check this link on how to use the windows debugging tool
click here
Every time that there is a blue screen error or a stop error, windows generates a dump file that has the details about the crash error. the dump file is located in this folder
C:\windows\minidump
you have to run the debugger, click on file, select ran deugger for crash error then after that browse to that folder and lod the minidump file.
in order for you to fully understand how to user the windows debugger, you have to read the link that i posted above.
the result of debugging will give you a detailed analysis on the problem, it could be driver issue, or the device or the OS itself
Sep 14, 2010 | HP Pavilion zd8000 Notebook
Blue screen & A message pop-up on my ToshibaSatellite A105-S4011:
try removing some unwanted programs. run disk cleanup, then defrag
Apr 04, 2010 | Toshiba Satellite A105-S4011 Notebook
Blue screen error message (Crash Dump)
kernell has over run the memory....
some corrupt registries may also cause this issue...
u can try to run a registry cleaner (Tuneup Utilitis or Registry defrag etc can do the job...search in google)
else
do a clean install of OS after data backup
Dec 14, 2009 | Computers & Internet
A blue screen pops up something about a crash dump
sounds liek you installed some hardware the pc did not like. plossibly memory that is not supported or video card that is not supported (some thing that a core item to the pc operation).
If this is not the case, one of these core items is faulty it sounds like. Another possibility might be some corrupted software like the OK throwing up kernal errors (blue screens). I would try to boot in safe mode to see if it happens there. If so, you will either have a hardware issue or OS one.. try the repair installation to see if it helps any. after that is looks like some hardware swapping.. hope that helps
Stan Skaggs
Nov 24, 2009 | Compaq Computers & Internet
My computer (HP Pavilion Entertainment laptop) keeps giving me a blue screen saying it is "crash dumping". This happens mainly when I try and download something. It won't allow me to download any...
This could be caused by a corrupted operating system, a virus or a faulty memory card. You may first try to restore your computer to a date when you think it last allowed you to download something. See if it works.
To run system restore, go to start>all programs>accessories>system restore.
Apr 30, 2009 | HP Pavilion dv6000z Notebook
How to slved the bule screen problem
The best way to solve a blue screen problem is to look at the dump file and get the bucket id from the dump file.
This is the best article i have come accross to analise dump files is this http://www.networkworld.com/news/2005/041105-windows-crash.html?page=1
once the have the bucket id it should tell you what caused the crash
Feb 19, 2009 | Microsoft Windows Vista Ultimate Edition
Blue screen
hi daget200;
can you post the exact error message? its located at the top few lines so that we will know whats causing it. have you inserted a new hardware recently? when does the error occur? intermittent? does it happen when you are playing games or something? pls expound. thanks
Jun 07, 2008 | Computers & Internet
Crash dump blue screen
If warranty - call it in. Otherwise it sounds like a classic case of bad ram. Find a friend with similar ram in his/her laptop and do a test swap to see if symptoms repeat. Then replace the ram. Far more common in HP's then Toshiba, but it happens for no reason. Basically it's a page in or out error with the ram causing windows to "freak out".
You can get a good selection of ram from Tigerdirect.com or newegg.com.
Apr 28, 2008 | Toshiba Satellite® P105-S6084 PC Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
