Question about Frigidaire FES367 Electric Kitchen Range
The cooktop and oven won't come on and seem to have no power. The clock still works.
  • 4 Answers
You only get one juice from one one of the two hot wires. Or both of your hot wires are of the same phase, which is unlikely if it is worked before.
Measure the voltage of each hot terminal and across both terminals. Each one should get about 120v and 240v across. If it looks good, open the back of the stove. Measure the voltage along the way up to the dial switches, when all the burners are in off positions.
In the back of each dial switch for each burner, there is two hot wires. Do you get 240v across it? If you do, then it is not stove. It is in the outlet to the service panel. Something get disconnected as more current is drawn. Perhaps, one of the wires get partially corroded.
Posted on Apr 15, 2009
Multi purpose oven won't work after power cut have reset clock, light won't work. Is making all the right sounds just won work
power supply from clock damaged not by power cut but voltage spike when power resumed the oven thinks its in auto mode permanentley thats why it wont come on ,new clock or power board needed.
Feb 03, 2017 | Neff Ovens
Model # 79094320300 the clock and oven does not work on my Kenmove flattop stove, what can I do about it?
The clock runs on 110 volts and the oven at 220 volts. If the cook top is on, the issue is in the stove. Best left to a qualified technician.
If the cooktop is also not functioning, check the breaker.
Jun 19, 2014 | Kenmore 30 in. 42701 / 42702 / 42709...
Burners work on top of stove, but oven and clock not working
Make sure the clock is not set to "auto" function or on "timer" mode. The oven will not start until the correct time has come up. If the clock is not working , this is likely to be the problem. See if there is a manual operation control or switch. You may have to get a new clock or arrange for the clock to be bypassed so the oven can work without it. Most electronic clocks can stop an oven from working if they fail.
After a power failure, the clock face went out and there is no power to the duel ovens on a Maytag gemini electric oven. All four burners on the glass flat top work though.
try turning power off at electrical main switchboard for a minute, then back on. reset clock and see how it goes.
otherwise > call the repair man.
Oct 20, 2013 | Maytag Gemini Electric Double Oven Range...
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
The power went out and then the elements and oven would not work but there was power to the clock?
This solution only really applies to oven elements only. I haven't experienced it with hotplate elements as they are not normally controlled by the timer. When you have an electronic timer and there is a blackout the timer normally reverts to auto. function when the power comes back on. You have to set it back to manual before the oven will work. Turn the oven element to ON and the set it to manual. The oven element indicator light will light and the oven will work.
Feb 06, 2011 | Stoves 23 in. Premier TC600I Electric...
Jenn- Air cook top oven sve47500b has error # F7 and the oven will not work
F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Oct 25, 2010 | Jenn-Air JED8430 Electric Cooktop
GE JBS55W0J3WW Electric oven will not heat up. None of the 4 elements on the top or the bake or broil elements will power on. The clock, oven light, timer, hot cooktop and oven on lights all power on as...
Check to make sure you have 240v at your receptacle. Lights, clock, timer, will still work with 120v, while the elements need 240v. Start by checking your breakers to make sure that one of the two breakers feeding your oven hasn't tripped.
Apr 13, 2009 | GE JBS55 Electric Kitchen Range
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Frigidaire FES367 Electric Kitchen Range Logo
146 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
