Question about Whirlpool Duet GHW9150P Front Load Washer
Will top lift up on top loaded washer? A ring fell down to bottom of washer.
There are two clips in the front, the seam between the top and front. use a putty knife, or butter knife to unclip as you pull up, one side at a time. be careful not to let the top fall backwards
Posted on Apr 14, 2009
How do you remove inner drum on top loading LG Washer WT5170HV?
The whole top of machine must be removed.
unplug electronics and hoses remove upper splash ring remove cap in center of agitator remove bolt holding down remove .
remove inner tub Nut center tube should lift up and out.
next step if your changing shaft is all from bottom.
lot more down there. Take picture b4 and as you remove for ref. to resemble
Jul 03, 2016 | LG Wave WT5170HV 27" Top-Load Washer with...
My LTE5243D top load stacked washer is about 10 years old. How do you take the front panel off to access the washer's motor coupling?
To gain access to the washer components, the front panel between washer and dryer must be removed first.
Remove the two top screws securing thethis panel to the unit.Tilt the transition panel down and pull itstraight out.Remove the two screws located behind the washer top.Pull the washer top forward to disengage the top locks. Disconnect the washer lid switch harness. Lift the washer top off the unit.Remove the two screws from inside the top of the washer front panel.Lift up on the front panel to release the catches near the bottom of the panel andremove the front panel.
Apr 24, 2012 | Whirlpool LTE5243D Top Load Stacked...
How do I lift the top off the automatic top load washer to replace the little side switch on the right side of the machine were the top sets down in to?
Good day,
You have to remove the front of the cabinet off. There are three places where the screws holding the top consule are located.
Both bottom corners, both bottom corners but hidden by plastic end caps that have to be unclipped, and at the rear bottom.
On the latest models, the consule is held on with the clips built into the consule and must pried forward and then lifted.
Here is an excellent tutorial on changing the switch assembly.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Feb 13, 2010 | Estate TAWX700JQ Top Load Washer
Kenmore Elite Oasis is making a loud banging noise during spin cycle. Also just noticed a small amount of water under the washer. All other cycles appear to be working fine.
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 09, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
A dime fell in between the bottom of the washer and I can't get it out . now making noise.
hello there:
if it a top load unscrew the agaitor and lift it up and you can get your change
Aug 16, 2009 | Washing Machines
Two dollar coin fell into a space between agitator and a drum.
you can pop of the agitaor ( held on by a 7/16 screw to the the inner tub will lift right out, it merely rests upon the spline, youll need to "pop" the main top first by "popping hte release clips. approximately 6 inches form either side between the main lid and the front panel are the clips, use a sturdy putty knife as these are tough to undo, the outer tub ring then simply unsnaps off and youll be able to remove the inner basket with no problem.
Nov 19, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool LSB6300PW2 Won't Agitate or Spin
if you lift andclose the lid do you hear "clicking" noise??? i bet not. simple repair, lift the lid and with a hollow shafted screwdriver(1/4in nutdriver or similliar hollow shaft implement)you fell with your hand the bottom half of the left side lid hinge. as you open and close the lid you can fell the opposing end of hinge under the top no need to dissasemble you can fell it right there. when you find it simply slip the hollow ended shaft over the hinge and apply pressure towardds the rear of unit.While doing this the top will want to close( your pushing against the hinge).. after appling slight pressure youll bend it slightly, enough to activet the lid switch mounted to the rear of the main lid assy.
Nov 13, 2008 | Whirlpool LSB6300PW Top Load Washer
A penny fell underneath the agitator & went underneath inside the tub
remove 2 rubber plugs on each side of lid remove the screws underneath lift top up remove the plactic ring around tub top by pulling up on clips along top edge remove the spring on left attached to ring lift ring off remove agitator again lift inner tub up and out ..when reinstalling inner tub be sure it drops completely in so the center gear drops in place
Sep 07, 2008 | Fisher Paykel EcoSmart GWL15
Kenmore washer
There are a few things that can cause this issue.
1. The counter balance spring broke or the mounting hole for the spring rusted through.
2. One or more snubber pads may have come off.
3. The balance ring may have come loose from the basket or the ring has been damaged and the fluid has leaked out..
Start by removing the shell as follows:
A.) The trim on either side can be pried off from the top, grasp and pull forward to expose to expose a screw.
B.) With console lifted you will find a lid switch connector (white in color). Unplug the switch from the connector.
C.) There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
D.) Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
1.) The counter balance spring is located in the bottom rear. It should be attached between the cabinet and a bracket on the tub.
2.) Inspect snubber and corner pads. May be brown or white in color.
3. Remove tub ring by pushing down then lifting each locking tab.
Inspect balance ring for proper fit and any cracks. By moving/shaking ring you should hear liquid sloshing around.
If you need further assistance, let me know
Regards,
reg501
The FixYa Team.....
Jun 26, 2008 | Kenmore 15864/15862 Top Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
35 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
