Question about Sharper Image Ionic Breeze GP (SI730) Air Purifier
Condensation forms on the top inner ceiling of the refrigerator
My Whirlpool top freezer refrigerator works fine but condensation forms on the top of the refrigerator cabinet
  • Dawn6111 Apr 14, 2009
    Thank you Phil,
    I did that last month and I put 1 1/2 inch copper wire from the coil into the drain hole why did the problem come back?
  • 242 Answers
Very common problem I have repaired many times , The drain is frozen or plugged.
remove the back panel in the freezer section to get to the evap./cooling coil , then check the pan under it , there is a small 1" drain hole at the bottom that may have ice in it or its clogged with something else.
Use hair dryer or similar to remove ice then get a wire or something similar that is firm to use to snake out and clear that drain hole you want to get about 10 inches down into it.
Pour bleach into evap pan and let it sit for a bit. [10 minutes]
Then to know its cleared well pour a cup of water into the evap pan then check the pan under the unit at bottom behind kickplate to ensure the bleach and water has made it to this pan.
If unit is now draining here , wipe remaining water off top of ref. compartment and by the next day it will usually stop.
Let me know if you have any other questions.
Phil
Posted on Apr 14, 2009
  • Phil Brantley
    Phil Brantley Apr 14, 2009
    If it came back there are still particles the blech usaully takes care of , there is a screen like part on some models that is located in the control section inside the fresh food compartment than it drains to the back of the unit , you can take the drain lose on the back as well and clear it from there.
    It just travels down to the evaporation pan after that so the clog must be in the freezer at the pan or in the control area in the fresh food , just take the panel inside the fresh food section down and you will see it.
    Let me know how this goes.
    Phil
This morning, my Frigidaire FFHS2322MS refrigerator had a pond of water in front, the compressor was clearly off and the lights inside were on. No error code of the displays, they were just bla
Have a technician test the start capacitor on the compressor. When they go bad the motor will draw excessive current which trips the thermal overload switch on the compressor. It usually resets itself once the compressor case has cooled down.
Nov 15, 2015 | Frigidaire FFHS2322MS 22.6 cu. ft. Side by...
I have a frigidaire pro FPHS2386L and the freezer is too cold. Any ideas?
George makes a good point but I'd like to add that there is generally a fan that blows the air between the freezer into the fridge area. If there is no obstruction, the fan most likely needs to be replaced. On a few models this can be done with a little patience and a screw driver and the fan part. Check with a Sears Parts distribution store avaiable around the country for the part if the model is carried by Sears. If not, Google the fridge make and model number with Freezer Fan Replacement.
Nov 23, 2014 | Frigidaire FPHS2386L Stainless Steel...
Chemcial taste in water after changing water filter
Well this never happens with me but surely you might get some unusual result.
Chlorinated Solvents Exporters
Sep 12, 2012 | Whirlpool Gold GSS26C4XXB 26.4 cu. ft....
Ice maker not filling with water
Is the arm that checks amount of ice in the down position?
Aug 29, 2012 | Whirlpool UKI1500AXXA Refrigerator Ice...
I have this air conditioning unit where suddenly stops functioning and no power on the indicator. i have thecked the breaker and it is fine and ON with a three phase supply. I've checked the condenser at...
Hi, I will see if I can give you some idea of what may be happening. I work on these on a day to day basis. So, you have a split system with the condensing unit on the roof, or a package unit on the roof? Sounds to me it is the first one.So, you are telling me that the power supply at breaker below is OK, but you should have a power box at the condenser on the roof. When you reset power to the condenser, that's when you here this blast sound? To me from just hearing what you are saying , it would be the sound of the compressor trying to start up, and it has a internal problem making this noise. Tell me, when it makes this noise, does it trip the breaker again? If so, it is definatley the compressor. You can prove this if you are inclined to do this, is to find the 3 different wires going to compressor, and make sure power is off 1st. Disconnect them at the Contactor or remove the plastc cover from compressor and write down which wire goes to each terminal.Tape the ends so they dont touch metal. Turn the condenser back on and see if this blast is gone. If so, the compressor is dead and you will need a new one.You say you have 3 phase power? This is unusuall for a residential unit, 3 phase units are for comercial unit power. They dont use starting componants like Run or start caps because they have enough power to do the job.3 phase would have 3 hot legs of equal voltage unless it was the older 3 phase which will have a stinger leg with higher voltage then the 2 other legs.Maybe this is a commercial a/c. Also, the compressor is reversable on a 3 phase unit by moving 2 of the 3 wires on the load side of the box, like T-2 and T-3. If these are switched if the compressor is locked up, sometimes you can get lucky and break it loose.Please don't do this, I am just explaining to you a little about 3 phase. Try this so you can elimanate the compressor. The only other thing it could be, if this is a gas pack and you are starting the heat, you can be getting blow back premature combustion? But I don't think this is what you have. It has to be the compressor.So, lets prove it by taking it out of the circuit. all should hold and no noise.Still, a faulty compressor is not a good thing. Let me no. Best of Luck and safety first.
Sincerely,
Shastalaker7
Nov 25, 2009 | Air Purifiers
Side by side refrigerator....Maytag
The cover where the parts are located is in the back of the freezer section, you will have to remove the screws and you will be able to gain access to all the parts.
Nov 23, 2009 | Air Purifiers
Can you use honeywell 12k btu air con in a room with no windows
you can, however the heat from the condenser will recirculate back into the evaporator, you need a place to discharge the hot air, and also the drainage from the condensate. I have cut holes in walls to the outside of the room in many applications with no windows, and they work fine. Just a matter of if you have an outside wall, and how much troble it is to cut the hole, frame the inside of the hole out, get power to the unit and secure the unit in the hole. Hope this helps...
Aug 15, 2009 | Air Purifiers
Sharper Image Ionic Breeze  GP (SI730) Air Purifier Logo
357 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
