Question about RCA TruFlat 27F520T 27" TV
Dark colors Picture going out
Turning on the TV I get a dark tent of color that the adjustments can't fix. After a few minutes the screen flickers. If you can remember how the channels looked like on Cable TV that you did not subsrcibe to but could barely make out a picture, that's what it is doing. It is hooked up to Direct TV. When I change the channel on the TV to another input it looks fine but without a picture. Any ideas? Thanks
  • oldwiseone Sep 14, 2007
    Changed the video input yesterday to the front and everything is back to normal. Perfect picture. Guess it was just the input on the back of the TV. Maybe a plug or something going out.
    Thanks
  • Anonymous Jan 03, 2009
    I have a 1999 Panasonic 62" screen tv and it has worked fine for years - it is suddenly going dark and adjusting the color will not work. It starts out dark but gets progressively darker as the program goes on. The model number is: PT61G54A. Could it be a part that needs replacement? It is connected to direct TV - this television has always had a great picture. Help - don't want to have to purchase a new television!
    Thanks!
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It is hooked up to Direct TV. When I change the channel on the TV to another input it looks fine but without a picture. as you do not see tint in another channel means your color section is ok it is due to video or luminance section.
Posted on Sep 14, 2007
SOURCE:
My mitsubishi 72 inch tv has gotten a very dark picture. What can I do to fix this?
adjust the color go to the menu and change the color meter to darker or lighter and your welcome
Nov 05, 2012 | Mitsubishi Televison & Video
Dark Color on TV. Can't adjust the color correctly
Having same problem now for a second time on a 57T500. First time was a bad green bulb that was covered under warranty. Only lasted 2 years....currently debating wether to fix or buy a new set. Bulbs cost about $300. Set is only 5 years old, so very dissapointed with quality.
Feb 01, 2009 | Hitachi 57F500 57" Rear Projection...
The colors pulsate from light to dark
There was a problem with the sony projection tv's that they called a flicker. Do a google search on your TV and flicker or search sony and flicker. There is all kinds of info about a service bulliten that Sony sent out. There were fixing it at no charge but Im not sure if this fix still applies since the tv's are getting older now.
Jan 01, 2009 | Sony KP-51WS500 51" Rear Projection...
Toshiba Plasma 42
plasma42 color flickers in and out and now its just snow,now its black screen. still have sound.please help me.. what board should i replace??
Dec 29, 2008 | Toshiba Televison & Video
The Contrast and Brightness on tv appears to be dark.
If this is a CRT-based TV and it's been played most of the time, you may have a bad picture tube, especially if strong red colors bleed to the right. CRT's dim with use, unlike LCD or plasma. But it could also be trouble in the video circuits - none of this falls into the DIY category, unfortunately. High voltage involved, unless you're comfortable around it and want to try turning up the screen controls inside the TV. If you do, let me know - but "no response at all" from the external adjustments points to a more serious problem.
Dec 10, 2008 | Toshiba 36AF41 36" TV
TCL TV picture too dark
try turning the light sensor off
Oct 20, 2008 | JVC AV32F476 32" TV
Rca home theatre big screen tv
# 1 above you have covergence problems ,there is a service flash from rca to fix your fault,ask your tv shop. fault # 2 above turn off the color and adjust your screen settings for a grey picture,set brightness and contrast to middle settings. # 3 fault read #1 cause if your auto focus will not correct you require service there is a harness connector that looses connection and causes several fualts on the 52" rca's you can repair the fault but if you miss the harness replacement you will do it again.
Dec 01, 2007 | RCA 32F531T 32" TV
PROJECTION TV Phillips 9P6031c103
this is what convergance looks like;
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
if pix is dark their is 6 adjustments knobs in the front of the tv under the screen and behind the plastic cover. the top three are the brightness bottom three is focus.
Nov 24, 2007 | Toshiba 53H71 53 in. Rear Projection...
JVC AV27320 Screen too dark
Check the lumans circuit. may be jungle IC
Nov 02, 2007 | Samsung HC-P4241W 42" Rear Projection...
Sony tv KP-57XBR10W
Correct ! One set is for RGB focus and the other set is for
RGB screen voltage............................T.
Oct 05, 2007 | Sony KP-57HW40 57" Rear Projection...
RCA TruFlat  27F520T 27" TV Logo
112 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
