Question about Boating
Basic maintenance, having not run for a while
Hi! I have a 1980 Evinrude 25hp Outboard: E25ELCSA E - Evinrude 25 - 25 horse power E - Electric Start L - 20 inch shaft length CS - built in 1980 A - Model run or sufix It hasn't run for about 2 years. I had it completely serviced just before it last run. I have just given it a proper clean with a pressure washer and now I want to get it running again - I have a new battery ready to be fitted. So my questions are: 1. what is the ideal fuel mixture to run? ( I read a previous response for a 4hp motor) 2. should I remove the spark plug and replace with a new one? if so, any advice welcome. 3. is there anything else I should clean/ change? filters etc (how would I check them first? they should have had very little use) thanks in advance for any/ all the advice.
  • bencottman Apr 14, 2009
    some hands-on advice from someone who services thier own outbaord motors would be really appreciated.
    thanks for the advice - is it a pair of plugs used in outboards this size?
    I didn't actively drain the fuel, so I suppose there must have been some fuel in the system.
    I'll check for loose parts - good idea.
    thanks.
    Top Expert:
  • 76,164 Answers
LEAVE THE FUEL MIXTURE ALONE, IT IS SET UP ON A FLOW BENCH BY THE FACTORY AND SHOULD NEVER NEED ADJUSTMENT, YES A NEW SET OF PLUGS, CHECK ALL THE FILTERS AND REPLACE THEM AS NECESSARY. DID U LEAVE FUEL IN THE ENGINE WHILE IT WAS STORED, WAS GAS STABILIZER ADDED?? LOOK FOR ANY LOOSE PARTS, THEY TEND TO VIBRATE LOOSE.
Posted on Apr 14, 2009
  • yadayada
    yadayada Apr 14, 2009
    YOU WILL NEED TO GET THE PLUGS FROM THE AUTHORIZED PARTS DISTRIBUTOR FOR YOUR ENGINE, MOST BOAT SALES AND REPAIR SHOPS FOR BOATS CAN GET THEM FOR U OR WILL HAVE THEM IN STOCK.
  • yadayada
    U CAN ALSO GIVE THEM THE NUMBER OFF YOUR OLD PLUGS AND THEY CAN CROSS IT OVER TO A NEWER NUMBER (IF THERE IS ONE), THAT IS MOST LIKELY THE BEST WAY, DO A GOGGLE SEARCH OF THE PLUG NUMBER FOR A BETTER PRICE.
    Genius:
  • 1,605 Answers
Go to a marine store, pickup all the supplies. they would assist you as to what you need.
plug, gas from fulling station. do a turn-up as you would with a car.
1997 3cyl 25HP Evinrude outboard Would changing the carbs to 35HP carbs make this a 35HP motor?
Depends if the bore and stroke are the same, if they are not, adding larger jetted carbs can result in always running rich. The mixture would be incorrect for the amount of air the cylinders take in.
Feb 02, 2017 | Cars & Trucks
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
I need an owners manual for an Evinrude 2 HP outboard motor model 2402E.
http://shop.evinrude.com/category/342499/Literature?brand=27153&horsepower=6955&year=27400&n=0&x=21&y=20
For Evinrude service manuals or Evinrude Johnson owners manuals for 1999 models and prior, please contact the Ken Cook Company at (414) 466-6060 or click here to be directed to their website Antique Literature. On older literature, original printed copies may no longer be available. When this occurs, an effort will be made to fulfill your order with a machine copy reproduced from a master file.
This says it is 1974
https://www.marineengine.com/manuals/evinrude/#e2hp
http://www.ebay.com/itm/1980-2hp-Johnson-Outboard-Repair-Manual-Evinrude-2-HP-/190470229931
Original outboard product and service manuals for Johnson Evinrude Gale...
Aug 07, 2016 | Boating
How do i fit a rectifier to a 2013 25hp evinrude 2 stroke???? Rectifier-4wires-2go battery & 2 go AC lighting coil system. Need to identify were to connect my 2 coloured wires from rectifier????
This is what Johnson say;
Technical Contact Information
We Take Your Boating Pleasure Seriously!
Your selling dealer has a special interest in your satisfaction and should be consulted first if you have any concerns about your Johnson power product. Your authorized Evinrude dealer is your primary contact for service, product information, and Evinrude and Johnson® Genuine Parts.
Protect your investment. Please read your owners manual for all operation and maintenance information for your engine. It lists all the adjustments and routine maintenance procedures for your motor, including off-season storage and pre-season service. We encourage you to work with your authorized Evinrude dealer for all the services you require.
If you have a concern with your engine that your dealer is unable to resolve, please have your engine model number and serial number available, and contact us.
Ta
Take a look at these videos though.
https://www.google.ca/search?q=25+hp+evinrude+2+stroke+rectifier&rls=com.microsoft:en-US:IE-ContextMenu&source=lnms&tbm=vid&sa=X&ved=0ahUKEwjVu_XQ2ZnLAhVMQCYKHbMwBnoQ_AUICCgC&biw=1600&bih=729
25 hp evinrude 2 stroke rectifier Google Search
Feb 28, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Evinrude serial numbers 18902bc 53303
It looks like you have an old one....?
model # and serial # are on the mounting bracket, port side.
1980 and later, the model number will start with "J25" followed by 5 or 6 characters. there might be another letter in front of the "J".
1956 to 1980, most model #'s begin with the horsepower, before that, it's more random.
Commercial, military and racing versions each have their own model # sequence.
May 18, 2014 | Boating
Size of prop for 1994 evinrude 90 horse power boat
Hi, it would probably need a 17 inch pitch and then water test it and make sure its full throttle revs are between 5200 and 5500. regards Phil.
Aug 16, 2012 | Clymer EvinrudeJohnson Outboard Shop...
I have a 1980 evinrude outboard motor. It is overheating. We have changed out the water pump, took the thermostat out and checked it, it works fine. What else could it be?
I could possibly give you a better explanation if I knew the horse power of the outboard. However hear is what happens to most "tiller" operated outboards. Water pumps are made from a pliable soft rubber which by the way needs water to lubricate it even if you just crank it over to check something, or fire it up for a few seconds on a dry impeller will destroy it. Most often a few pieces will fly off and enter the water cooling system and then lodge in one of the small passage ways blocking water flow. When a new impeller is installed the engine runs pumps water and overheats.
Dec 05, 2010 | Boating
Boating Logo
173 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
