Question about Intermatic Malibu 300W Power Pack Transformer ML300RTW
Malibu landscape transformer
The timer won't work. I can manually turn on/off lights. Are there simple checks I need to do before replacing the tranformer?
bernie I have two Malibu transformers. One I set the time to what it is now and moved the pegs to the times I need. No problem
The other one I did the same but the lights stayed on.
I can only turn them off by unplugging the unit. However it is keeping the correct time.
Help
I discovered that I hadn't turned the manual switch to off on the one that wasn't working properly.
Now they both work fine. The instructions that come with the Malibu Transformer is not easy to understand and it does not go into enough detail. There isn't a trouble shooting section which would help.
Posted on Apr 15, 2009
2 Suggested Answers
jeltey
  • 44 Answers
SOURCE: Malibu landscape transformer
If it is keeping time try moving the stops. If it is not keeping time the motor is probably burned out. These transformers don't have a lot of serviceable parts to them.
Posted on Dec 04, 2008
We have a Malibu 300 low wattage transformer for 13- 20 watt landscape lights.
Try connecting a lamp (correct voltage, etc) directly to the transformer. Most likely, the wire from the transformer to your lights is broken... The reset button can't reset anything, if there's nothing wrong there.
Jun 16, 2016 | Intermatic Malibu 300W Power Pack...
Where can I buy a replacement photocell for my Malibu 300W low voltage landscape lighting transformer?
You can buy the Malibu Photocell Low Voltage sensor on eBay. Go to eBay and search "Malibu Photocell Sensor" and you should see it. Or search eBay item number 371829265599
Mar 26, 2016 | Intermatic Malibu 300W Power Pack...
Problem with Malibu Landscape Lights Transformer ML900TW
Use an extension cord to plug the transformer into a different "test" GFCI receptacle, if it holds on the test GFCI you know that the GFCI for the transformer needs replaced. If it doesn't hold, then the transformer is on the way out and should be replaced. Sometimes motors and transformers will "leak" current and still work, but not trip a regular circuit breaker. A GFCI that is doing it's job will catch it though. Don't force a GFCI like that...you can wear it out prematurely.
Apr 24, 2012 | Home
We have an outside landscape light time that has quit working. Model pb115m1. Do you carry these?
Fixya does not sell timers or parts.
Timer system is not identified for certain.
If landscape system still turns on-off with override switch, then you can work around and buy cheap plug-in timer, set landscape to override, and plug landscape system into cheap timer.
Open following link for low voltage transformer resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Add a comment for more help.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 28, 2011 | Hardware & Accessories
I bought a Malibu 300W low voltage landscape transformer to replace a 200W unit that stopped working. It worked for 1 week, then stopped .. the reset **** doen't work. The LED works, I do see a...
I don't know if it burned out, but something is not right.
Malibu products come with 1-5 year warranty.
New product that stopped working should be exchanged for full replacement at place of purchase, except possibly the auction sites.
New Malibu product should work for many years.
Be sure to match bulb voltage with transformer voltage to avoid possible problems.
Mismatched bulb and transformer wattage should not affect a timer in short period such as 1 week.
Another thing to check is outlet polarity. Use circuit analyzer from home center to check outlet.
Jul 20, 2011 | Intermatic Malibu 300W Power Pack...
Need the on/off (red/black) pins to set on/off times on a 9yr. old Malibu landscape lighting transformer. Simple, where I may procure these pins? This is not a trick question.
Yours is a frequently asked question... twice today
I don't see Malibu tripper pins anywhere on the internet or at Malibulights.com
The newest Power packs are digital and don't have tripper pins.
Oct 13, 2010 | Hardware & Accessories
Lights will turn on and off manually only
Just checking, still plugged in, fuse or circuit breaker not tripped that provides power to it? If you can turn it manually, and the dial does not turn when powered up, look for a small on/off switch, other than that, maybe it does need replacement, but they usually last longer that a year, but I have had some timers that just quit working on me too.
Apr 29, 2010 | Intermatic Malibu 300W Power Pack...
Oct 29, 2008 | Malibu ML600TW - Low Voltage Power Pack -...
Intermatic Malibu 300W Power Pack Transformer ML300RTW Logo
2,478 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
