Question about HP Designjet 5500 (42 in.) InkJet Printer
Hp5500 designjet needs belt replaced.
GURU LISTED SOME HELPS FROM SERVICE MANUAL OF HP5500 TO TAKE OFF CARRIAGE BELT. NEED DIAGRAMS AND EXPLAIN WHAT TENSIONER ASSEM. IS . MARK BRANT 419-203-6828
  • 2 more comments
  • wilprint09 Apr 15, 2009
    antiochpc provided service manual 20 steps for changing belt . we have hp5500 designjet torn apart but still need print head removed to access belt and put new on. diagrams you sent are being examined but do not appear to be for hp 5500. Please send manual diagrams and or helps for removing belt. Thanks .
  • wilprint09 Apr 16, 2009
    HP5500 designjet 42" wide format uv printer . need manual or diagram for removing carriage belt. 145 # machine, not little deskjet! Mark
    HP5500 DESIGNJET WIDE FORMAT UV PRINTER NEEDS BELT REPLACED. ONLY INFO DIAGNOSTICS HAS BEEN GIVEN.
    NEED CARRIAGE BELT REMOVAL DIAGRAM AND HOW TO REMOVE BELT FROM PRINTHEAD AND/OR REMOVAL OF PRINTHEAD.
    PLEASE RESPOND. MARK
  • wilprint09 Apr 20, 2009
    The HP5500 wide format printer belt still needs replaced .. All web sites, repair dealers and pictures you referred me to have already been visited by us . No new info has been provided. Thanks for the effort. Will have to call service direct. Mark
    no fees will be excepted.
  • 10,515 Answers
Hi mark,
  Thanks for your patience.We are here to offer help in any way and we already offered you text information.Regardsing diagrams, it's not available with any of the experts as it's illegal to distribute copyright service manuals here.
  Usually HP recommends that you should not open Hp 5500 design jet printer, However as you already did that...We can offer you link for service manual as we never deal with it.
i don't believe so its under warranty as you opened it , anyway if so you have already voided the warranty.The lin would be :-
http://www.partshere.com/HPPartsList/hpdesignjet.asp
http://computers.shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=service+manual+hp+5500+designjet&_sacat=58058
I advise to purchase it from ebay...Its cost effective and also helps you for future problems.
Thanks for using Fixya.
Do rate the solution.
Posted on Apr 17, 2009
  • taran_2005
    taran_2005 Apr 20, 2009
    Hi Wilprint09,
    These are not common machines. You could hardly find the explanatory diagrams with any of the experts.
    I have checked the links once again. All are working. I do agree there is a cost effective charge for the manuals, However, that's the only option we have.
    I can explain everything . However, i do not have any diagrams.
    Any further help, let me know.
    Sergeant:
  • 291 Answers
On the back of the carriage there is a slight latch in which the belt is fitted ,and the two sides of the belt are fitted on the gears at the left and right sides respectively.to see the exact picture as on which gear the belt is fitted click this link the picture is given. http://www.computercarefiles.com/TWI_Docs/bpp90211/default.html
keep up dated. thanks.please do rate the solution if helped. thanks.
Posted on Apr 16, 2009
    Novelist:
  • 133 Answers
Removing the Carriage belt is a long process and is as follows:
I know this would not be easy to read the instructions and follow however if you want the service manual.. here is the link:
http://www.arbikas.com/view/locator/5500.pdf
Its free :)
From the service manual:
1. Remove the Left Hand Cover
2. Remove the Right Rear Cover
3. Remove the Right Hand Cover
4. Remove the Tensioner Assembly
5. Pull out Printhead Cleaner Carriage
6. Slide Carriage Assembly to position shown.
7. Lift up the Carriage Cover and remove ALL the Printheads and close the Carriage Cover.
8. Slide the Carriage along the Printer to the position shown.
9. Push in the 2 retaining clips either side of the Printhead Tube Connector.
10. Pull the Printhead Tube Connector towards you.
11. Push the button to release the Printhead Tubes in the Carriage.
12. Release the retaining clip by pulling it away from the holding brackets.
13. Pull the Printhead Tube Connector up between the two Tube Guides.
14. Slide the Carriage to the left side of the Printer.
15. Unclip and remove the Carriage Cover to access the Trailing Cable in the Carriage.
16. Carefully disconnect the Trailing Cable from the connectors in the Carriage PCA. NOTE Remove Trailing Cable
Ferrites if they fall into the Carriage.
17. Remove the Trailing Cables from the Trailing Cable Holder.
TIP Press the Trailing Cables firmly in the center to release.
18. Slide the Trailing Cable Guide out of the Carriage.
19. Slide the Carriage (including the Belt) to the left and out of the Printer.
20. Remove the Belt from the Carriage by releasing it from the retaining clips underneath the Carriage.
A Tensioner is a device that applies a force to an object to maintain it in tension.. Exactly what would you like to know about Tensioner assembly?
Regards,
Srinivas
Posted on Apr 15, 2009
  • Srinivas Dhulipala
    Srinivas Dhulipala Apr 15, 2009
    OOPS .. that was a repetition .. Sorry for that. Your comment was not visible during my answer.
    The previous one was more of a sort of part list .. here is the actual service manual:
    www.4shared.com/file/58478279/f3e98e92/HP_Color_LaserJet_5500-5550_SM.html
    Scholar:
  • 123 Answers
try this link to get diagram and explanation
http://downloads.maxcessintl.com/pdf/Figure%20Sheets/1-xxx/1-366.pdf
Posted on Apr 14, 2009
HP Designjet 800ps 24". How
Instructions are usually supplied with the belt, however if you are looking for the manual, you can find it here!
Jul 05, 2011 | HP DesignJet 800ps InkJet Printer
On my HP 1050C Designjet I am getting the error 'Check printhead path Type 2. Then it says to switch off.
Hello. The "Check Print Head Path" error is usually a worn out carriage belt on printers more than 5 years old. Open the top cover and examine the area under the belt and look for debris that looks like pencil erasure crumbs. Other possible problems could be the tube system catching on something as the carriage moves, the encoder strip being very dirty or extreme friction between the carriage bushings and the rails they move on. If the belt needs to be replaced, a replacement kit can be purchased at: http://www.lpscomputer.com/c-790-hp-designjet-belt-replacement-kits.aspx
Hope this helps.
Bob
Jan 26, 2011 | HP DesignJet 1050c plus InkJet Printer
Need instructions to replace carriage belt for hp designjet 500, specifically how to remove and replace on the carriage assembly
When you order the belt from hp it will come with the instructions, if not email me and I will send it to you.
Jul 12, 2010 | HP DesignJet 500 InkJet Printer
How can I replace the belt for the ink carriage
Here is an HP Support Forum where a user has posted a detailed procedure for the belt replacement.
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=846691
The Service Manual is needed. It's available at:
http://www.hylink.com/PrinterManual.html
Designjet 430, 450, 455C - Service Manual
DesignJet 430, 450C, 455CA - Quick Reference Service Manual
As mentioned, it's a delicate and time consuming operation. I replaced my belt two years ago with little problem. (Be sure to clean the old degraded belt gunk off the drive pully too!)
It's not a job for "Beginners". More like "Intermediate" or "Advanced".
Good Luck!
This is the part I ordered. It was $15
WARNING: THIS IS FOR THE "E-SIZE" MACHINE.
If you have the smaller one, you must research the part number for that.
Carriage belt (E-size) - Long/wide belt attached to the carriage 15.00 0.00 15.00 1 15.00
Oct 21, 2009 | HP DesignJet 450c InkJet Printer
DESIGNJET 755cm ERROR MESSAGE: TURN OFF PLOTTER CHECK PAPER PATH. THERE IS NO OBVIOUS BLOCKAGE TO PAPER PATH
If there is no obvious obstruction in the print head path, the most likely problem is a worn carriage belt. Open the front lid and check for rubber crumbs under the carriage belt. If there are crumbs, the belt is disintegrating and needs to be replaced.
The service manual can be downloaded from: www.lpscomputer.com/ec/manuals.htm and the parts are available at: http://www.lpscomputer.com/c-736-designjet-1050c-belt.aspx
Oct 10, 2009 | HP DesignJet 1050c InkJet Printer
There's an error appears. It was error number 86
86.01 can be a couple of issues pertaining to the movement of the carriage assembly.
1. Too much friction in the Slider Rod. Lubricate the slider rod.
2. The Carriage is bumping into the Service Station. If the carriage
is stuck at the right hand side of the Printer and cannot be moved
out to the center of the Print Platen it is because the Service
Station cannot uncap the Printheads. In this case replace the
Service Station/Aerosol Fan Assembly.
3. Check the carriage belt for wear. Check the carriage path for debris. If the belt is worn, replace the belt. Also, clean the teeth on the carriage drive motor, the debris from the belt will accumulate on the teeth.
Sep 28, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
Carriage belt replacement
Use the carriage replacement procedure in the service manual. Download here: www.lpscomputer.com/ec/manuals.htm
Aug 10, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
Replacement carriage belt for HP DesignJet 800
The part number is; C7769-60182 runs at around $70.00.
This component needs to be installed by a service technician. You can seriously damage this plotter if you remove the carriage ribbon connectors and do not install them properly. You will fry the pca board (a $1,100 mistake).
Nov 19, 2008 | HP DesignJet 500ps (42 in.) InkJet Printer
HP Designjet 5500 (42 in.) InkJet Printer Logo
271 people viewed this question
Seeker5211
Seeker5211
