I cant save a scanned picture to my computer
How do i save a picture to my computer once i scan it on an hp officejet 5610v all-in-one?
  • 469 Answers
You should have received desktop software with the scanner, if not check the manufactures website for a down load of the software.
Once the software has been installed it will allow you to select file type, storage location and size.
Some high end paint or draw programs will allow you to address the scanner if all else fails.
Posted on Apr 14, 2009
  • 489 Answers
If you are using the HP Director, when you select you scanning options one of the options is the destination for the resulting scan. You can select e-mail, saving it as a file on your hard disk or network, putting it into the clipboard, etc.
Hp 6210 officejet all in one ... want to test scanner only. Took 16 hour tech assist to download (software was not provided by work associate). Ink cartridges do need to be replaced. Want to test the...
yes, you can test the scanner without inks.
use the hp solution center c01810967.gif installed on the computer Double-click the HP Solution Center icon (c01810967.gif ) on your desktop
  • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
  • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
    For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    • Scan to: Select your scan destination from the drop-down list.
    • File Type: Select the file type from the drop-down list.
    • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
    • Show preview...: Select this check box if you want to see a preview before the actual scan.
      Click Scan
Jun 05, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I got a new dell computer. my hp 5610v allin one printer will not scan, never had any problem before, it wont let me set it up with disc. what do i do????? it copies an prints great. thanks helen
It seems the driver version that you are using is not a full feature software.
Please download the full feature driver and than you should be able to scan.
Thanks
Sep 21, 2010 | HP Officejet 5610 All-In-One InkJet...
My HP Officejet 5610v All-in-One prints and copies but will not scan a document... WHY?
Please reload all software and drivers - once done try it ... it should work.
Thanks
Aug 26, 2010 | HP Officejet 5610v All-In-One InkJet...
How to scan with hp officejet j4680
Please install the printer software and try to scan via the installed software from the computer. Or, start scan using scan button from printer; after installing software.
Regards,
Rizwan
Mar 02, 2010 | HP Officejet J4680 InkJet Printer
How do i scan a document and then email it
If you haven't done so, install the cd that comes with the HP Officejet package. Once correctly install, you should go to "All Programs" and locate "HP Solution Center" Click on HP Solution Center, click "Settings", click "Scan settings and preferences", choose either "scan document" or "scan picture" If word document then under File type: locate "PDF(*.pdf) If document is a picture then under File type: locate "JPEG image(*.jpg), click ok. Step 2 Choose between Scan Picture or Scan Document, click accept Step 3 your file is locate under "My scan" Hope that helps
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
New OS can't find software for Officejet 5610v
Download the driver/software from HP website. Just type the model number of your printer
May 24, 2009 | HP Officejet 5610 All-In-One InkJet...
Cant fax
Are you sure the FAX line is connected to a working phone jack and plugged into the correct jack (line not phone) on the machine?
Step by step FAX instructions can be found here on the HP website.
Jan 07, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp officejet 5610v all-in-one printer
Hi i'm an EX HP employee give the model number and i'll give you the link
you can also go to www.hp.com and selct the option Drivers on the bottom left..
aj10@aol.in
thanks
Jun 04, 2008 | HP Officejet 5610 All-In-One InkJet...
HP OFFICEJET 5610V No scan options
No scan options occur if the digital imaging monitor is not running on the taskbar of the computer. Once check whether the digital imaging monitor is running or not ans try to scan from the HP Solution center. If you are able to scan from HP Solution center, then search for the file hpqtra08.exe and run it and then try to scan from the all-in-one.
May 24, 2008 | HP Officejet 5610 All-In-One InkJet...
If you get the error while trying to scan with your HP 5610v All-In-One, the easy way to scan from your printer is to click on start, go to Paint and then File, the option "From Scanner or Camera" will come up.. click there and poof - you can scan anything you want and save it where you want... Problem solved!! good luck!!!
141 people viewed this question
k24674
jasbo
jasbo
