Question about Philips 43PP9202 43" Rear Projection Television
TV cycles on and off but never fully turns on
When turned on the power button flashes red. The three crt's flash every 3 seconds or so but never fully turn on. It's like the TV resets itself every three seconds and just keeps cycling. I downloaded the service manual. Voltage from the AC input board is the correct 5V and the standby line goes low when the power is turned on to the unit. The service manual mentioned that I should measure 130V DC off of a connector from the Full Power supply panel. but this is where the problem shows up. I get 130V it goes to 0 and then back to 130 and continues to cycle. I measure at one side of one of the main transformers on the power supply panel and get ~150DC constant, but when I measure on the other side of the transformer I see the cycling problem. Does this sound like a bad transformer, or could it be one of the large value capacitors on the board?
Any suggestions would be greatly appreciated.
  • dave_call May 20, 2009
    Update. To anyone wondering, the problem was a short in one of the convergence modules that would continuously shut down the tv. I replaced both modules and the picture came up but with ghosting and the convergence really out of wack especially around the edges. I looked at the resistors around the convergence modules and found two that were open. I'll be replacing those tonight, but I'm thinking this is going to fix the problem.
Tv POwers on shows a picture then picture goes and audio stays on
Posted on Apr 14, 2009
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Power button flashes three times pause it does
problem solved with an inhouse repair man
Dec 16, 2009 | RCA Scenium D34W20 34" TV
Sony Projection Stand by indicator flashing red
Ur FBT,Fly Back Transformer high voltage is dead, the black block of plastic with a red wire with cap hook to a CRT(Tv Tube).
Sep 14, 2009 | Sony KP-46S25 TV
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Aug 30, 2008 | Fujitsu Televison & Video
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
TV wont turn on?!
What type of tv is this ? If it is a GE or RCA you might have a bad flyback transformer.
Feb 22, 2008 | Televison & Video
Philips magnavox 25TS56
Same problem. The power button does not work. The volume and channel buttons turn the tv on. the tv then shuts its self off 15 seconds later. the red light blinks in second intervals while this happens.
Sep 16, 2006 | Philips Magnavox MS3252S 32" TV
Philips 43PP9202 43" Rear Projection Television Logo
136 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
