No error message but copier light doesn't come or number of copies doesn't work
I have an AR-200 sharp copier when in sim it prints and copies and feed are all good. in normal operation the machine rcognizes where everything is but you can add with the copies number button or wont print single copy and copy light does not come on
    Sniper:
  • 67 Answers
Let it run eventually the toner lite will come on, sharp copiers will run an extended period trying to add toner to the developer. developer is 70% iron filings and 30% toner as it uses the toner it cycles more in to stay at the proper level.
Posted on Apr 15, 2009
Sharp ar 5320 hwo to repair u4 200
check the duplexer which is what is used by the copier to print on the other side of the copy
Aug 07, 2014 | Sharp AR-5320 Black and White Copier
System error (f2-04) for Sharp Copier, model AR-M201
It is copy lamp error.
1- check the copy lamp on with sim.
2- replace the power unit.
3- replace the inverter.
4- replace the mcu pwb.
Jul 01, 2012 | Sharp Office Equipment & Supplies
Printer message error H2.
Fuser problem, Check to make sure fuser installed and connected. Use Sim 14 to reset. Hold the light expouser key until all lights flash and - - shows on display then enter 14 and press the copy button. Machine should restart.
Aug 30, 2010 | Sharp AR-5316 Advanced Digital Imager...
My Sharp AR-M160 will print but not copy. No problem buttons are lit up but just dont work.
have you got the machine on print mode
if you find the button that says print copy fax on it press it until the light is on copy...
hope this helps
Jun 18, 2010 | Sharp AR-M160 Black and White Copier
It display
Check the white area of document glass and clean it or the copy lamp is not lighting.
Nov 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
H2 Error Message on AR M205 Sharp Copier
hi..there is a problem in the thermistor,thats why you
get the error code as H2.
check this out..
thank u..
kindly rate my response..
Jun 23, 2009 | Sharp AR-M205 Copier
Sharp AR-5316 F5 ERROR
check the exsposure lamp this error relates to damaged or blown lamp also you check this when you turn th ecopier on you should see it self test at hte start up if there is no light it has blown or connections are bad
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
U2-40
Push P * C* in quick succession to enter simulation mode. Once there, enter 16 on the keypad. push the print button (like making a copy). Push 1 for yes then print button again. push the CA button. Copier should reboot and run fine for you.
Apr 01, 2009 | Sharp AR-M237 Copier
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
Feb 01, 2009 | Sharp AR-275 Copier
Sharp AR-M160 , printing problem with OS: Windows 2000
Is the cable and the computer the same? sounds to me as if your not using a bidirectional cable
Apr 18, 2008 | Sharp AR-M160 Laser Printer
69 people viewed this question
jasbo
jasbo
