Question about Philips 51PP9303H Rear Projection Television
Philips 51pp9303h/17 dptv345 chassis no audio or video
This tv has no audio or video. I have replaced the two stk392-120 ic's and it still does it. The kit includes 12 one watt resistors which the tv does not have. The tv makes a chirping sound i believe from the power supply board. Can anyone help me?
  • 3 more comments
  • andthehorseu Apr 14, 2009
    I changed the convergence ic's. It is impossible to change the 1 watt resistors when my tv doesn't have them. Whoever put the kits together obviously doesn't know what resistors the tv's have. Mine has 5 or 6 watt resistors and there is about 6 of them not twelve.
  • andthehorseu Apr 21, 2009
    This tv doesn't have a HOT. I have a service manual in pdf format. It's just difficult to read on my monitor because it's so wide. I think i'm going to just have to check the voltages until i find the problem. With so many people having the same problem with this tv, i figured someone was bound to know the problem and save me a lot of time.
  • andthehorseu Apr 22, 2009
    This tv does not have a HOT. It has 2 FET on the power supply board and 1 on the ssb that make up the horizontal output. This is what philips told me and i have the service manual for it also. I'm going to have to go through and check the voltages. It just difficult because the manual is in pdf.
  • andthehorseu Apr 24, 2009
    To Nobody295, you're an idiot! You have no idea what you're talking about. There are no 1 watt resistors. This tv doesn't have your "traditional" HOT nor are they with the HV generator. The horizontal output on this tv is made up of 2 FET on the power supply board and 1 FET and a TOP246Y ic on the main board.
    I would be more than happy to email anyone who thinks they know everything a copy of the schematic. I have repaired several projection tv's and never been stumped by one before like this one has me. I spent all last night checking the voltages and they were all correct.
    President:
  • Philips Master
  • 1,779 Answers
First- What have you checked ( voltages) It sounds from the chirping that the set is in HV shut down. I would probably check the HV Horiz Output transistor for a short. If it is shorted you can disconnect the collector and the short will be removed then the B+ will come up briefly as you monitor it. There has been many cases of the Blue CRT cracking and shorting out the mentioned transistor. If you have never worked on this chassis before I don't think you and I can repair it over the net, unless your a tech also. You can also take a flashlight and look into the blue crt closely for a crack line. It will be noticeable. If it is I suggest not repairing it because I doubt if you'll find the tube. If the tube is not cracked then there are more voltages and resistance checks to determine where the short is. I know this sounds complicated but I'm a tech not just a Q/A person. Let me know if I can help any further.
Posted on Apr 21, 2009
  • Jim Krause Apr 21, 2009
    I'm sorry Sir. But yes it does, I worked for Philips for 14yrs. and every Analog tv ever made has a Horizontal Output and with yours it also has a High Voltage Horizontal Output. After your done checking voltages and scoping the power supply, let me know what you come up with so I can give you a hand, it will be my pleasure.
You hot is part of the HV Generator. One piece. must change the whole generator. The resistors are there, if you dont know where to put them, you have no business trying to monkey with a $2000 tv when electronics veterans like myself put food on our tables by repairng sets. Another point, if you are not trained on proper ESD handleing precautions, your only going to damage more chips and you will end up paying more for a real tech to fix it, IF THEY WILL EVEN TOUCH IT AFTER YOU HAVE BEEN IN IT.
Posted on Apr 24, 2009
    Novelist:
  • 159 Answers
The STK's were replaced because a problem in the convergence. This problem (convergence) in most cases allows you to turn on the set just the screen looks out of geometry (by the way the resistors are critical parts that fail together with the IC's. To get the tv back on is needed a check up in the power supply and other areas related to high voltage power supply.
Posted on Apr 14, 2009
Magnavox tv model 51mp392h/17 words on the bottom are double one set is red other set is green
Thats caused by failed convergence ICs and the 6.8 ohm resistors. You can get the repair kit called the DPTV305 -DPTV345 & MAG01 chassis convergence repair kit which fits your model. The kit has the components and the CD with repair instructions and its available at the following link top of the page. http://tvrepairworld.com/phillips__magnavox_repair_kits
Apr 09, 2013 | Philips Magnavox 51MP392H Rear Projection...
I have a big magnavox tv that all of a sudden the picture went out with only sound. I tried everything possible from changing cables and calling my cable company to see if the problem was there but no
Your flyback has failed most likely...bad new is they are nearly impossible to find, This is a known issue on most of the models below. The site Tv Repair Kits can sometimes get replacements - but its not often.
This repair kit is known to work on Magnavox TV sets with the following Chassis/Model Numbers.
DPTV305 , DPTV305F , DPTV310 , DPTV315 , DPTV330 , DPTV330F , DPTV335 , DPTV340 , DPTV345, MAG01
Model Numbers
( 43PP9202/17 43PP920217 43PP9202/17F 43PP9202/84 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920201 50PP920217 50PP920284 50PP920284F 50PP920217F 51MP392H/17 51MP3964H/17 51PP9303H/17 51PP9363H17 51PW9303/17F 51PW936317F 55PP9352/17 50PP920217F 51MP392H17 51MP3964H17 51PP9303H17 51PP9363H17 51PW930317F 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F 60PW938317F 43PP9202/17 43PP9202/17F 43PP9202/84 43PP920217 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920217F 51PP9303H/17 51PP9363H17 51PW9303/17F 50PP920201 50PP920217 50PP920284 50PP920284F 51PP9303H17 51PW930317F 51PW936317F 55PP9352/17 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F )
Mar 29, 2012 | Philips Televison & Video
Repair man said my philips tv model #51pp9303h/17 needs coupler.
Tries Shopjimmy.com,Partstore.som,or Ebay.com.These Websites have refurbish old and new tv parts.
Dec 28, 2009 | Televison & Video
Replacing STK-392-120 ICs on Philips TV
Ok, I can tell you not to remove the circuit board--best way with this set is to put the entire chassis--all three circuit boards in the"SERVICE" POSITION.
LET ME KNOW IF YOU WANT TO KNOW HOW TO DO THIS---YOU ARE RIGHT--YOU TRY TO REMOVE THE BOARD WITH THE CHIPS--SEVERAL OR ALL THE PLUGS ARE NOT MARKED WITH NUMBERS--THERE IS A SIMPLE WAY TO DO THIS.
LET ME KNOW AND i WILL ASSIST YOU.
Oct 13, 2009 | Philips 51PP9303H Rear Projection...
Volume but no picture
19a7683.gif Ecollier2012
Rank:guru_s.gif Guru
Rating: 91%, 89 votes
e7c2b53.pngI have worked on dozens of the DPTVXXX models recently all with audio but no video. In every set the HVG was the problem.
If you are not sure how to find/repair/replace the HVG yourself goto http://www.TvRepairKits.com to get their how to guide that includes the part numbers, suppliers, instructions, etc.
Its an easy do-it-yourself fix.
Jan 28, 2009 | Philips 51PP9303H Rear Projection...
Philips Projection HDTV 51pp9303h/17
Number is on your STKs in TV Two big black ICs STK392-110s 150s, use 180s For Parts Electronix 1-800-223-3205 As for sound replace microboard has #P on it.
Jan 01, 2009 | Philips 55PW9363 55" Rear Projection...
Convergence trouble philips mod 51pp9303h/17
You can get a convergence kit with a photo instuction guide from www.TvRepairKits.com. The kit is for your exact model and includes the 6.8 ohm resistors.
Dec 07, 2008 | Philips 55PW9363 55" Rear Projection...
Need Parts Number For Flyback In Philips W/S TV Model # 51PP9303H/17
If you are not sure how to find/repair/replace the HVG yourself goto www.TvRepairKits.com to get their how to guide that includes the part numbers, suppliers, instructions, etc.
Oct 16, 2008 | Philips 51PP9303H Rear Projection...
My Philips DPTV345 Model# 51pp9303h/17 has a foggy picture. I have reset the convergence and still foggy.
need to replsce the coolant in the CRTs ( picture tubes) very common problem with that model. You can get a kit caalled the Phillips CRT coolant change at the following link which contains the proper coolant along with an instruction CD which shows how to do the replacement .Its under the repair kit category. Heres the link.
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Philips Televison & Video
STK392-120 you will need to replace both of them
Mar 17, 2008 | Televison & Video
Televison & Video Logo
482 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
