Question about Directv (R10) DTV Receiver / 70-Hours Video Recorder
Can't play back recordings
All recordings are there as they should be. Everything works fine until I press SELECT to play. Then it just goes straight to the channel I was watching
Pchaple,
We just discovered the same problem and we called Dish Network. After pushing to go deeper and try harder to solve the problem the customer service agent had us go to the system info screen. On that screen she asked the color of box "f", which was green, and that told her that the unit was defective. They are replacing the unit. I hope this helps. As for getting your recordings back, I think they are toast.
Posted on Apr 17, 2009
Why does my mixer freeze up?
Mixer brand and model? Are you recording on a DAW? Give us more info, so we can help you. If you're recording on a DAW, try to uninstall the drivers and install again, that should work...
Nov 24, 2014 | Music
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
How to put my own voice on answering maching?
Open the menu with the phone in standby.
Select Ans. Setup, then Record Greeting.
Press MENU/SELECT to start recording.
Wait until the system says "Record greeting" before speaking.
Press Menu/Selectto stop recording.
The system plays back your new greeting.
To keep the greeting, press End.
To re-record it, press Menu/select.
Hopfully this works for you
Jul 05, 2011 | Uniden DECT 6.0 Cordless Telephone...
Hi......... I have a Toppro Mpeg4 HD Recorder..Model No. TPR2000. Everything is set up OK and I can put in the programmes I want to record. I see it recording so all that is fine. However, the manual says...
Press menu button, use the right arrow button to select the multimedia folder (the yellow one). In the multimedia menu use the down arrow to select RECORDINGS then press OK. The "Rec Service List " will appear. Highlight the program you want to watch using the up/down arrows then press OK.
Apr 25, 2011 | Televison & Video
How can i delete the memos i recorded?
A.To ERASE
1st select the folder of deleting file(by pressing FOLDER button).
2nd press and hold " ERASE" button,
3rd within 10 second select the item you want to erase by rotating "PLAY/STOP SEL" wheel,
4th within 10 second press "ERASE" button. selected item is erased.
if this method will not work, then , the item is locked. To remove the lock folow below step B
B.TO UNLOCK
1st select the folder containg the item ( by pressing FOLDER button)
2nd press MODE button until " LOCK" or " UNLOCK" flashes
3rd within 10 seconds select the item by turning "PLAY/STOP SEL" wheel
4th within 10 seconds press the same " PLAY/STOP SEL ' wheel
item will unlock
then for deleting folow method A
below link is user manual
user manual panasonic RR-QR240
best of luck keep smiling
Jan 14, 2011 | Panasonic RR-QR240 Handheld Digital Voice...
How do I record my own voice? I want to start recording my bass guitar lessons and playing them back afterward at home
Step 1: Go to the main menu.
Step 2: Press the >> Button until you select recording mode.
Step 3: Press the modekey to enter recording mode.
Step 4: Press the Play Key to begin.
--Taken from the Manual.
Oct 27, 2009 | Delstar DS-3512 MP3 Player
Recording
I'm going to venture a guess that what might have happened is you changed the mode of recording. VCRs record in either short play, or long play, or even super long play. As the length of playtime goes up, the quality goes down, because for short play, a 6 hr tape will record only two, whereas a 12 hour tape will record four hours. More information is stored on the tape, so the quality of picture and sound increase, but a longer movie could be cut off. You can adjust the play-length with the sp/slp buttons on your remote control.
Jul 19, 2009 | Toshiba W522 VHS VCR
How do you record outgoing message?
RECORD AN ANNOUNCEMENT
1 Prepare your announcement. Each
announcement can be up to 4 minutes long.
2 Press A.
3 Press and release S until you see
the letter of the announcement you want
to record (A, B, or O).
4 Press R. Begin speaking after you
hear the beep. Speak in a normal tone
of voice, about 9 inches from the
microphone.
5 Press S. The system plays your new
announcement. To hear the announcement
again, press P.
6 Repeat Steps 3 to 5 to record another
announcement, or press S.
To assign an announcement to play:
SELECT ANNOUNCEMENT CALLERS HEAR
1 Press and release F until the screen
displays ANNC.
2 Press and release S until the screen
displays the announcement you want
callers to hear (A, B, or O). If you
select AO, you must record an announcement,
as instructed in “Record an
Announcement.”
3 Press S to return to the message display
Jul 02, 2009 | Lands Phones
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Sanyo digital camera model- vpc5500
Playing Back Movie Clips
You can play back the recorded movie clips on the LCD monitor screen. However, the
sound recorded with movie clips can only be played back on a computer.
1. Press the button.
2. Use the four-way controller (����) to go
through the images until the movie clip you
want to play back is displayed.
�� To view the previous image, press the
four-way controller (��).
�� To view the next image, press the
3. Press the button to start playing back
the movie clips.
�� To pause or resume movie playback, press the button again.
Dec 25, 2007 | Cameras
Directv (R10) DTV Receiver / 70-Hours Video Recorder Logo
247 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
