Question about HP PSC 2175 All-In-One InkJet Printer
Printer Driver The drivers on this machine are not here
    Problem Solver:
  • 9 Answers
GO TO HERE: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=90809&lc=en&cc=us&dlc=en&submit.y=8&submit.x=6&lang=en&cc=us
Posted on Sep 14, 2007
SOURCE:
Canon ip4500 problematic with win 64bit - seeking solution
Go to a 64-bit machine on the network and copy the 64-bit driver files to the machine
From the 64-bit machine, open Windows Explorer and browse to the 32-bit server
Open the Printers dialog seen via Windows Explorer.
From the Menu bar, select File > Server Properties, select the Drivers tab and click the Add button.
In the Add Driver Wizard, tick the x64 Processor checkbox, and untick the x86 checkbox.
Click Next, then click Have Disk and browse to the 64-bit driver on the local 64-bit machine.
Complete the Add Driver Wizard.
for more help visit CBR Tech Solutions
Dec 07, 2012 | Canon Pixma iP4500 InkJet Printer
Do we need CD installer if we will use this machine as computer network printer
It depends, you will need the drivers either from the CD or from a folder on a network share no matter how you setup the printer when you're printing directly to the printer.
But if you attach one Windows machine to it and then share it, the computer will install the driver automatically when you attach to the shared printer on that machine as long as the operating systems share the same driver.
Furthermore, you can also install the driver for other operating systems in the printer properties.
May 13, 2010 | Ricoh Aficio 1018D Copier
I have a toshiba e-studio 352 as a network printer on a win 7 system, I am able to scan from the printer to the pc, but when I try to print on the printer nothing happens. I did ping the printer and the...
try following
- download the newest printer driver from http://www.copiers.toshiba.com/support/index.jsp
- uninstall current driver
- delete port if it is still present
- restart the machine
- start setup (choose XPS printer driver and PCL printer driver)
- setup should offer the machine with IP automatically, if not enter IP manually
- print test page
- it should be working if not let me know, write in comment what happened
regards
Feb 24, 2010 | Toshiba e-STUDIO166 Printer
Tm-t88iv epson made prnter driver for win 2003 server r2 std
Epson POS driver will not install on a Win2K3 machine due to the InstallShield Wizard w/c checks if your running XP/2K or not.
Download the driver from EPSON POS site & extract the contents first on an XP machine.(Installing the driver will create a C:\Epson folder where ACTUAL driver is extracted).
Dec 24, 2008 | Epson TM-T88IV Label Printer
Print problem from network
Try installing the drivers that came on the CD with the printer.
Do the following on the machine connected to the printer:
  • Uninstall all previous drivers from Add/Remove programs (if any exist)
  • Go to Printers in the control panel and from the File menu choose Server Properties
  • Select the current printer driver and hit the Remove button
  • Turn off and unplug the printer
  • Restart your machine
  • Install the drivers that came with the printer from the CD
    Note: Do not unplug the printer till asked by the installer
  • Try to print a test page from the same machine
On the client machines, do the following:
  • Delete the printer
  • Delete the printer driver from the Server Properties window as above
  • Use the Add Printer wizard to add the printer
  • It will automatically install the drivers on the client machine
If the driver could not be removed, try resetting the Printer Spooler service:
To do that
  • Open Control Panel -> Administrative Tasks -> Services
  • Find the Printer Spooler service
  • Right click and Stop
  • Right click and Start
Good luck :)
Oct 27, 2008 | HP LaserJet 1018 Printer
WIndow vista have driver?
I have had the same issue, Try this on an xp machine with driver loaded for dc1250 share this printer and then on the vista machine brouse the network and double click the shared printer on the xp machine and the driver should load and vista will print using the xp machine as a print server.
Les
Jul 23, 2008 | Xerox DocuColor 12 Printer
Brother HL 5140
In Windows XP Pro...
Go to printers and faxes window. File-Server Properties. From dialog go to drivers then select the problem driver and pick Replace button. Select Yes to replace driver.
This has worked to solve the problem on the printer server machine but not on the other machines using the printer as a shared printer.
May 20, 2008 | Brother HL 5140 Laser Printer
HP PSC 2175 All-In-One InkJet Printer Logo
27 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
