Question about Microsoft Xbox 360 Arcade
Audio no video
I have audio but no video except wavy purple lines on my xbox 360 all the lights are normal not red i have tried a different tv same thing i have tried different av cable same thing can you help
    Scholar:
  • 133 Answers
Hi.
I've seen this problem too many times. There isn't anything you can do that doesn't require you to open up the 360.
If this 360 is out of warranty, You can either purchase an extended warranty from a place like https://www.newcorp.com/
Or search online for the Xbox360 Reflow Solution.
This means, you will have to reflow the VGA chip, which is causing your XBOX360 to act this way.
Posted on Apr 14, 2009
What is up with my 360 when ever i play it for about 30min it shows green fuzzy lines down the screen of my tv and purple fuzzy lines down my tv screen and after those two happen sometimes it will have red...
well definitely video issues of some sort. if you have a second video cable (or hdmi cable if your unit supports that) give that a try.
*assuming that doesn't work Unfortunately it sounds more likely that it's an issue with the video card inside the xbox. this may be repairable by a professional.
if you have it under warranty i would contact microsoft for a replacement/repair https://myservice.xbox.com/en-US/Pages/Welcome.aspx or call Toll free: (800) 4MY-XBOX
~best of luck!
Mar 13, 2011 | Microsoft Xbox 360 Console
Turn on console--red screen with wavy black lines
First check your audio/video cable connection to console and then to tv, make sure connection is tight on console and that color coding matches tv (if you're using rca or composite inputs). If those are all good you may need to get a new cable. First try unplugging system and try again, notice the small led light on your power supply, it should be green if it's orange or red you have a faulty power supply
Jan 16, 2011 | Microsoft Xbox 360 Console
Turn on console--red screen on tv with wavy black lines
First with your power supply plugged in look at the led light on it. If it is working fine it will be green, if it's faulty it will be red or orange and will need to be replaced. Also try unplugging audio/video cable from console to tv, make sure your color codes match your tv inputs. If your tv has multiple input ports try another port to see it that works (you may have a burned out port in your tv). When you change to the other port and it still doesn't work you may have a faulty cable and would need to replace it.
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
Freezing, no audio/video/red circle
ONE THING YOUR CORDS ARE WACKED OUT AND THE COLOR DISTORTION SIMPLE NOT YOUR XBOX IT IS YOUR TV
Aug 17, 2009 | Microsoft Xbox 360 Console
Xbox 360 is showing purple lines on tv screen.
Hi...
Pull out the video cable from both ends.
Re-attach and try again
Let me know
Jan 18, 2009 | Microsoft Xbox 360 Console
One red flashing light on 360 and error code E73
which light is it? (xbox hd facing up)
anyway.
http://forums.xbox-scene.com/index.php?showtopic=484726
Dec 15, 2008 | Microsoft Xbox 360 Console
Got sound, but no picture for my XB360
well if there is no red light on your xbox 360 all is fine its the video cord i suggess you buy a new one thanks nick
Jul 05, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
My xbox 360 is not displaying any picture just sound
its overheating but will give u red light eventually try googling X-Clamp fix i fixed many with same problem
Mar 21, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Arcade Logo
132 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
