Question about Humidifiers
Wiring Honeywell TrueIAQ w/ a non-powered Honeywell humidifier
I have installed a Honeywell HE265DG115 by-pass humidifier that has a digital control and a remote outdoor sensor. It is wired per the Honeywell Owner's guide, and it does not work. I have had my heater svc. tech, and his friend who is a HVAC contractor try to get it to work. None of us have been successful. My thermostat is new, a Honeywell TH6000, and it is wired back to a Thermo Pride warm air heater with A.C.
I have a wiring diagram that is in .jpg format that is a better illustration than trying to discribe it in less than 1000 words. I tried to attach it to this box but was unsuccessful.
I would appreciate any assistance any can offer. Thank You
    Sergeant:
    Champion:
  • 232 Answers
The soliniod requires 24v to open so if you dont have the power then its not wire properly. Are you using a current sensing relay to allow the humidifier to only come on whe the fan is operatin? if you do have 24v on solinoid and its not opening then you got a bad solinoid. sometimes the humidistat will be a universal, for a power humidifier . A bypass requires external power and the humidistat will need to be switched to BYPASS to regonize this
Posted on Sep 13, 2009
Were do I mount the mounting plate above or below
above so you are not steaming the coil which could solidify dust on coil.
Oct 20, 2013 | Honeywell HM512DG115 TrueSTEAM 12-gallon...
Scale build up on heating element
Try white vinegar instead. The same type of scale builds up in drip coffee makers. Most recommend white vinegar to remove the scale that builds up over time. The added bonus is it costs less and is completely safe. If your unit is a water over paper media humidifier, you would be much easier to replace the paper media.
Sep 12, 2012 | Honeywell HM509DG115 120V TrueSTEAM...
Can the humidifier's housing for a Honeywell model HE265 By-Pass Humidifier be installed on the return air duct, or must the housing for this model always be installed on the hot-air supply duct just above...
Hello Which came first the chicken or the egg?The unit will operate perfectly in the supply OR return as I have installed in both.If there is more room & easy service access put it in there.
Sep 14, 2010 | Honeywell Humidifiers
Humiditstat control
Hello harley,Easiest way do is Replace thermostat with a model that has humitistat functiion.Honeywell has a nice one.Adding a seprate control is complicated & sometimes cant be done at all
Mar 31, 2010 | Honeywell Power Humidifier: Furnace...
I have a carrier furnace, humidifier valve popped fuse
hook up the new transformer to the white (common) from the blower motor, and the lead from the blower motor hooked up to the heat term on the board. (just cut the wires and wire nut all three together)
Nov 18, 2009 | Honeywell HE360A1027 Whole House...
I have a Honeywell HE360A Humidifier and everything is installed now I am trying to wire it. The wiring diagram is very vague. Does anyone know how to correctly wire this? I have the humidifier, a...
Peice of cake: You run the white to sail switch the to common 2. Yrun thr re to humistat switch then to the white on the control board or conact us www.airenergyexperts.net
Jan 31, 2009 | Honeywell HE360A1027 Whole House...
Humidistat installation question
I suppose you are looking at the do-it-yourself model. Depending on the wire that is run up to you Regular Thermostat from your furnace. You may have to run a seperate line for the Humidistat. A digital thermostat that does Humidity and Temperature is recommended. Or you could just place a Humidistat near the furnace room. A wiring diagram will come with the Humidifier discribing the different ways to wire it.
Jan 09, 2009 | Honeywell Power Humidifier: Furnace...
HE120 By-pass humidifer - Sponge Drum not rotating!!
Model HE908A drum is turning but we get no condensation
Dec 25, 2007 | Honeywell HE120 Humidifier
Humidifiers Logo
441 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
