The start-up identifies IDE Channels, ie, Channel 0-WDC A313000 Hard Drive is the master, and identifies Channel 1-NEC CD-ROM 282 SM as the slave. When I look in the hardware profiles, Sony Proprietary is the CD-ROM. Then I get messages that the CD-ROM cannot be found, and it does not appear in My Computer on the Windows 98, version 4.01 Desktop. Why did the CD-ROM brand name change? How I do get the system to recognize the NEC CD-ROM 282 SM, which is plugged into the motherboard?
  • willat_bh Apr 14, 2009
    The PCChips A15G Motherboard has one (1) 40-pin IDE Channel, and four (4) Serial ATA (SATA) Headers for the new technology SATA devices. I have been advised that I can connect two (2) IDE Devices into one (1) IDE. The manufacturers of the IDE Devices illustrate the jumper protocols for slave, and or master designation by illustrating the placement of the jumper in the jumper block on each IDE Device. Tiger Direct will also, tell about the jumper placement in the jumper block in the rear of the device. It is usually located near the power connector (4-pin). The number of pins in the jumper blocks vary from 6-pins (NEC CD-ROM) to 10 pins (Western Digital Caviar (WDC) Hard Drive). The BIOS recognizes the WDC as master, and recognizes the NEC CD-ROM as slave. The hardware profile identifies the CD-ROM as Sony Proprietary.
    Scholar:
  • 58 Answers
Sounds like you may have been digging in there.
If you have a 2nd IDE cable, try putting the CD-ROM on that...in the 1st connector slot.
Posted on Apr 14, 2009
  • 4 more comments
  • M Nelson
    M Nelson Apr 14, 2009
    You should be able to see primary IDE and secondary IDE on the mother board. CD-ROM should go to the seconday IDE slot in the mother board. Try it and see if the BIOS recognizes it as a CD-ROM and not a slave.
  • M Nelson
    Also...did you mess with the jumpers on the CD-ROM? If you put the jumper in the wrong spot, the BIOS will not recognize the CD-ROM?
  • M Nelson
    Yea...the more I think about it, the more it seems like a jumper issue. Windows 98...ah yes...the good ole days...
  • M Nelson
    Any luck? Did you check the jumpers? Have you been inside the computer? hmm
  • M Nelson
    My bad...I thought you were using an old 98 machine and dealing with old IDE cables...not SATA sorry.
  • M Nelson
    btw you can connect 2 IDE devices with 1 IDE cable. You can not have more than 5 IDE devices on one old mother board.
    A common config is: Master and Slave on Channel 0, CD-ROM and DVD on channel 2, and floppy by itself. Just some fyi
Dont know where to plug in cd drive
You have to identify first what kind of interface your CD-ROM uses. This can either be IDE or SATA.
Note that for IDE interface, there is a master/slave/cs settings for the device. If you are using one cable to connect the hard disk and the CDROM,make sure that the settings for the hard disk is set to master and CDROM to slave. If the IDE cable you are using has a twist on it, then both device should be set to CS (Cable select)
For SATA, this is just point to point. Please check below link for more details.
http://it.flexinet.com.au/bits%20and%20pieces/HARDDRIVES.htm
Jan 07, 2011 | Intel (AXXSCD) Internal CD-ROM Drive
My WDC WD2500JS hard druive is getting noisy and slow. I am thinking of replaceing it before it dies and at the same time do a clean install of Win7. It is now XP. Can I make this drive a slave until I...
first up
uninstall a few unnecessary programs
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
second
yes you can make it a slave
you will have to change the setting in BIOS for master/slave aswell as the jumper settings
during the boot up process you will see on the screen for a short time press a certain key to enter set up press that key to enter set up
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
make sure the computers motherboard will support windows 7
wait until you get the new drive before before connecting your hard drives to master/slave
depending on the amount of drives your computer has you might have to change letters on all drives
naming of the hard drive you might be able to change the name opening windows explorer navigate to the drive then right click on the drive then select rename
Dec 15, 2010 | Western Digital 250GB WD RE SATAII...
Gigabyte-GA-8S648FX I updated my BIOS and my pc wont start, please hel'p bobonickelson@yahoo.co.uk
Ok, you have 2 x UDMA ATA 133/100/66 Bus Master IDE ports on that motherboard, so you can support 4 ide devices. It is important that you split your devices between the 2 available ide channels (each channel has a seperate ribbon cable). For example if you have 1 hard drive and 1 cd drive you'd want to place each on a seperate channel. If you have 2 hard drives and 1 cd drive it's best to place each hard drive on a seperate channel and the cd drive on the same channel as one of the hard drives. You have to make sure the jumper settings on the drives are correct (1 master and 1 slave) when placing 2 drives on the same channel for example. Most likely your jumper settings are not correct and are causing this problem. The jumpers are located on the rear of the drive near where the power cable is plugged into the drive. Most hard drives have the jumper setting printed on the hard drive. Once the jumpers are correct you should be ok.
Jul 05, 2010 | Gigabyte GA-8S648FX Motherboard
Reinstalling the original cd rom that came in the computer. do i need to change the jumper settings. it is a samsung sc-148
That depends upon the IDE cable you are attaching the CD ROM to.
There are two IDE cables attached to the motherboard, on IDE 1 connector/cable will be your boot hard drive (C drive) and this will be jumpered to Master and you can attach the CD ROM drive to this cable and set the jumper on the CD drive as Slave.
On IDE 2 connector/cable if there are no drives attached to this cable then the CD ROM drive can be jumpered as Master or Slave..
If there is another drive on the same IDE 2 cable then look at the jumper on that drive, if it is jumpered to Master then the CD drive needs to be jumpered to Slave. If the existing drive is jumpered as Slave then the CD drive needs to be jumpered as Master.
Both drives on the same IDE cable cannot be jumpered with the same setting.
Nov 30, 2009 | Computers & Internet
My PC refuses to boot up
If you have IDE rather than SATA drives -
You should have your hard drive as master and 1 CD drive as slave on one IDE channel, with the other 2 CD drives on the other IDE channel, one set to master and one set to slave.
So, pull the CD drives out and check the master/slave jumpers on the back of them.
Apr 10, 2009 | Teac CD-Rewritable W28E CD-RW Burner
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
I still cant figure it out....no sound...
Uninstall Previous Sound Drivers & Install new one. I am online now & can help you out with remote assistance.
Aug 06, 2008 | Computers & Internet
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
Gigabyte 8S648FX-RZ Motherboard has problems running multiple IDE devices
May 03, 2008 | Computers & Internet
Computers & Internet Logo
169 people viewed this question
David Payne
David Payne
