Question about Audiovox CDM8610VM
Singer 4525 merritt tension knob fell apart
I need to know how to reassemble my tension knob. singer merritt 4525
  • Anonymous May 12, 2009
    Sure hope you get the answer. Mine did too and I can't spend the $100 to send it to the repair man!
Assembly instructions for Singer Merritt 4525
The service manual for that machine can probably show you, and I would make sure and get the parts list as well. I just checked Sewing Parts Online, and it was not listed, but if you send an email to them (they give the address at the top of the page), they can and will purchase it for you. Usually takes about 2 weeks. However, I just saw a used one in nice shape on eBay for $72.99 and $27 shipping in the original box, so you might consider just buying another one. I also noticed that a new tension assembly is being sold for $18.95 including shipping, and if you write to them, they may include replacement instructions. Just do a search on Singer 4525 on ebay--they have all kinds of bobbins, foot pedals, and parts for it.
Jul 09, 2014 | Singer Sewing Machines
Where can I find a tension assembly for merritt 9606
There is one for sale on eBay right now for $12.99. http://www.ebay.com/itm/Singer-Merritt-Sewing-Machine-Replacement-Tension-Assembly-Model-2404-/151468509588?pt=LH_DefaultDomain_0&hash=item23443a0994
Jun 30, 2014 | Singer 20U73
Merritt 9618
You will find the parts list most helpful, because it will show you with drawings where each part is supposed to go. Go to the Singer site, and type "parts chart" in the Search box, then select Sewing Machines and the 9 - 900 series. Scroll down; it's towards the bottom.
Jun 26, 2014 | Singer Sewing Machines
Singer Merritt 4525 tension assembly falls out; how do I fix it?
Should be a screw on the body to tighten up near the unit
Oct 06, 2013 | Singer Sewing Machines
I need to access motor on singer merritt 4525 when pedal is pushed motor just hums.
Remember to have the take up lever down when you start to sew and make sure there is not one piece of thread stuck in the raceway, to access the motor if you have to will mean seperating the body and it is not easy
Sep 27, 2013 | White Sewing 979
How do you thread a singer merritt 1872?
Wow, one of the few Singer machines that doesn't have a free download manual. Hmmm..... Ok looked up a photo of your machine. It's pretty easy.
1. raise your presser foot.
2. Put thread on spool pin.
3. draw thread over to and under from behind of the pre-tension disc at top
4. Draw thread down from the right and under the tension dial to seat the thread into the tension discs and flex that spring a little.
5. Through the take up lever.
6. Down through the thread guide.
7. Down through the needle bar thread guide.
8. Through the needle.
Hope that helps.
Aug 20, 2012 | Singer Sewing Machines
Singer Merritt 3015 Tension
the tension dial may be going out & need to be replaced at a sewing machine repair shop
May 20, 2012 | Singer Sewing Machines
Why does my singer merritt 4525 jam in the bobbin area?
how do you install a bobbin basket on a singer merritt 4525
Oct 04, 2009 | Singer Sewing Machines
Audiovox CDM8610VM Logo
277 people viewed this question
Top Audiovox Cell Phones Experts
svicari124
svicari124
Level 1 Expert
Laxman Bisht
Laxman Bisht
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
