Question about Microwave Ovens
Sparks in microwave
Microwave sparks and makes crackling noise when I try to melt butter chocolate anything fatty. This panansonic is only about a year old. I do not have anything metal in the oven when trying to do this.
  • 140 Answers
SOURCE: GE microwave -crackles and sparks as if metal inside
The problem you are having is that the magnetron that does the heating is shorting out and it needs to be replaced before it damages the inside covering of the microwave. www.mwoparts.com is a good source for magnetrons or other similar sites. To replace is easy enough. Taking the cover off with the power off, you will find it behind and on the top right side of the control panel. It is held in place normally with just 4 screws and two wires with terminals attached to it. So removing and replacing is pretty straightforward. Just be sure all the power is off until you have everything back in place. Good luck.
Posted on Jan 23, 2009
EwingElect
  • 276 Answers
SOURCE: Paint damaged in side microwave oven
1) How is the cavity damaged? Is it just peeling paint, or is it rust? If it's rust then the microwave could be dangerous.
2) The antenna cap usually has a small hole in the centre, but if there are any other holes in it the magnetron itself could be damaged, and holes caused by the magnetrin arcing.
Posted on Mar 25, 2009
breddi2
  • 126 Answers
SOURCE: Microwave pops and sparks when running. Nothing
in the top of unit is a round cover and damage is coming from here. This is serious and needs to be checked out. the cover contains a stirrer that moves waves around<<circulates them>> in this cavity probably paint is thin and allowing waves to penetrate metal of cabinet. Call manufacturer and see if there is anything they will do for you before taking it upon yourself to either get repairman or get rid of unit.stirrer is probably damaged and cabinet burned from waves.
Posted on Apr 26, 2009
  • 240 Answers
SOURCE: Turned microwave on this morning ,sudden crackle,then nothing.
Sounds like something has shorted out-blown. Unless it is a very expensive model it won't be worth fixing and is not something you should attempt yourself anyway. If under guarantee then get it repaired via the guarantee arrangements. No harm in checking the plug is wired properly but as the light and timer are working it is very doubtful it is a connection problem. I think you need to buy a new microwave!
Posted on Oct 03, 2009
Testimonial: "Thank you ...sort of guessed the 'solution' . Great service thank you ."
SOURCE: There was a crackling sound and a spark
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Posted on Feb 18, 2010
Testimonial: "Thanks for the prompt response! We are off to buy a new one (not GE). "
Is it normal for a microwave to make crackling noises when standing and not in use but plugged in ?
A microwave in standby mode should not crackle. There might be a slight humming sound from a transformer, but that should be all the noise it makes. You could have a transformer or control panel component that is failing.
Oct 28, 2016 | In Microwave Ovens
My kitchen aid microwave makes a loud crackling noise every once in awhild
Is it a carousel (turning platter)? if it is, than it is probably dirt on the platter support wheels and the platter support groove/track on the bottom of the oven, clean the glass plate, the support wheels, and the bottom groove as well, if you want to make sure the crackling comes from the carousel system, take it all out (support and platter) than place a glass of water in the oven and start it, if there are no crackling noise than my theory is correct, if the noise is still there than have it checked by a professional technician...
Sep 17, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I am looking for the recipe for the chocolate fountain. What is the ratio of chocolate chips to oil?
You can buy special chocolate fountain chocolate to use, or you can just use standard milk / dark chocolate chips and add 1/2 a cup of good vegetable or coconut oil for every pound (16 Oz) of chocolate.
There are many different variations on the recipe and you can Google CHOCOLATE FOUNTAIN RECIPE to get an idea of the many different options which include adding cream or liqueur.
Basically you just want to melt your chocolate on the stove in a double boiler if possible.
If you use a microwave, then carefully heat only on low power and stir after every minute.
Pour the melted chocolate into the fountain base and turn on the fountain for a few minutes. Then shut it off for a minute to allow it to vent any air and restart.
You can always add a little more oil to the recipe if the chocolate does not flow properly.
Good luck and enjoy.
Apr 23, 2011 | Microwave Ovens
My microwave is making a cracking sound like if it had metal in it but i took everything out and its still making the cracking sound. What could be causing this sounds if microwave is empty?
A contaminated wave guide cover will crackle and spark.
They should be periodically checked, cleaned or replaced.
Contact Maytag for replacement parts.
Hope this fixes your noise.
Nov 27, 2010 | Maytag MMV5207AAS Microwave Oven
My microwave oven heats, but makes strange crackling noises. Is it allright to keep using the unit?
No. Please have it checkd as it is dangerous to let the high voltage jump along side the magnetron. This will eventually result in the failure of the magnetron with a possible damage to the circuits.
So open and check if there is any foreign particles/insects struck within , Is the insulation damaged or remove the magnetron and clean the uni , clean the cabin specially if food haas accidently got spurted inside, dry the whole unit after cleaning before you fix back the magnetron.
The microwave must now work without crackling or else if the spark is seem near the magnetron , it must be replaced.
Hope this advice helps.
Aug 27, 2010 | Microwave Ovens
I have a sharp carosel and tried to microwave bitter chocolate in it like many times before... it arched... I contacted Baker Chocolate and they said to put it in a bowl on a plate - did this many times;...
NEVER put anything metal in the microwave. If your chocolate was in aluminum foil no wonder it arced. That is very hard on the microwave.
If the metal were in PERFECT contact, then it would not arc, however that condition is unlikely. Just touching doesn't count... If it was welded and could not touch other metal or the walls, you MIIGHT get away with it.
When Baker told you to put it in a bowl, that MEANS the bare chocolate.
ALSO NEVER put bowls that have metalic trim as the trim will arc to itself.
Dec 27, 2009 | Sharp Microwave Ovens
HOW DO I ROAST A CHICKEN IN A AC925CHS
Search the internet for “roast chicken recipe for microwave”
Here is one just in case you don’t find one:
Microwave Roast Chicken
3 lbs. chicken
1 tsp. salt
4 tbsp. butter or margarine
1 tsp. paprika
Instructions
Melt butter in a custard cup in microwave. Mix paprika into melted butter. Wash chicken (reserve giblets, these are best cooked conventionally). Sprinkle inside of chicken with salt. Cover ends of legs, tail, and wings with small pieces of saran wrap or wax paper. Place trivet on inverted saucer or small casserole lid in 12 x 7 inch baking dish. Place chicken breast side down on saucers. Brush with butter. Cover with waxed paper. Cook 12 minutes. Remove wax paper or saran warp from legs, tail, and wings. Turn chicken breast side up and brush with butter. Cover with wax paper and cook 12 minutes more or until meat thermometer registers 180 degrees (temperature will increase to 195 degrees during standing).
DO NOT USE MEAT THERMOMETER IN OVEN WHEN COOKING!! Remove chicken from oven; cover with aluminum foil and let stand 15 to 20 minutes before carving. Note: For other weights of chicken, allow 8 minutes cooking time per pound.
Jan 09, 2009 | GE JVM1860 Microwave Oven
Microwave Ovens Logo
297 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
