Question about Konica Minolta bizhub C450P Laser Printer
Error code when copying... C6103 on Bizhub C451
  • 210 Answers
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
Posted on Aug 23, 2009
    Problem Solver:
  • 9 Answers
C6103 is an intermediate document jam. Replace the automatic docement feed lift motor. there is a mod kit for that particular part
Posted on Jul 11, 2009
How can I solve colour registration error in konica minolta Bizhub c 451 printer. Thank you, Uchenna.
run registration procedure in service mode. any p codes check the black image unit as is the reference for color registration
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 18, 2017 | Konica Minolta Bizhub C451 Copy-print-scan
My machine bizhub c451 display error code p6,p7, p9,p16, p21
Registration errors. Have tech come out clean IDC sensors and replace black i/u
Feb 05, 2017 | Konica Minolta Bizhub C451 Copy-print-scan
How can I correct error code c3822 on bizhub C451
1. Turn OFF the main power switch (Inside front cover). Ensure sub power switch is on located right side of the control panel)
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly. If the code come back do NOT reset have a tech come out replace the fuser unit, it can catch on fire that will ruin a Christmas Day!!!!!
Nov 08, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
Customer has C451 bizhub that has unresponsive control panel except it will make ONE copy after hard reboot. Then no buttons work, particularly the Utility/Counter button. Can't get in to service mo
Hi
The bizhub C451 is a Konica-Minolta machine and I have found a webpage here:
Error Codes Konica Minolta bizhub C451
that details the error codes that can occur on your machine. I know that this may not be of much use as you don't appear to have any error codes appearing. However, there is also a link at the top of the page from which you can get a copy of the Service Manual which will probably have a lot more detail in it and may answer your question.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 28, 2014 | Office Equipment & Supplies
How to reset error code c0105 on konica c451?
C0105 Tray 3/4 feeder transportation
motor turning at
abnormal timing
The lock signal remains LOW for a predetermined
continuous period of time while the
motor remains stationary.
1) Check the M25 connector for proper connection
and correct as necessary.
2) Check the connector of M25 for proper
drive coupling and correct as necessary.
3) M25 operation check
4) Change M25
5) Change PFTDB
6) Change PRCB
Jul 17, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
Errore Trouble code C-C172
Refer to Konica Minolta Bizhub C451 Printer/Scanner/Finisher's User Manual or Call Service Center.
May 01, 2014 | Konica Minolta Bizhub C451...
Error Code C6103 on Konica MInolta BizHub 451C
I believe a C610 has to do with the scanner unit of the copier....
Apr 14, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta bizhub C450P Laser Printer Logo
3,383 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
