Question about OfficeMax 0M96431 Shredder
Shredder won't shred
when i empty my office max shredder, the catch bin is not triggering the sensor to let the shredder know it's in place, thus, it won't shred. any help?
    Scholar:
  • 192 Answers
They may be a compression switch on the lip where it sets on the bucket. This it to prevent it from running while its off its buckette. If this is not all the way in it wont run. Look for that clean any safty switch or buttons you find.
Slap it with your tax booklet and call me in the morning. Good luck DFD
Posted on Apr 16, 2009
My shredder worked fine but now when I turn on it does not stop running and does not shred paper ?
Most shredders will have a shred and a reverse setting. Is it running in reverse? Has the bin been emptied? With the power off, you can remove the bin and manually pull excess shredded paper jammed in the cutting heads -watch out, sharp metal . Once cleared run single sheets for the first minute to help clear rollers.
Jan 05, 2015 | Shredder Office Equipment & Supplies
Embassy shredder open door light won't go off after emptying bin. Therefore no shredding
The shredder probably has some kind of switch or sensor that detects that the bin is in its correct installed position. The interlock may be broken or blocked by paper shreds. An inspection inside the bin recess may reveal the cause so that it can be corrected.
Oct 19, 2014 | Office Equipment & Supplies
Why is the fellowes blade still rotating even when there is no paper?
It is possible that a small shred of paper is lodged at the sensor underneath the cutting blade.
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers or use canned air and blow the edges of the blades.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse.
    • 3 Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Fellowes Intellishred PS-79Ci Shredder
Fellows powershread keeps turning off - says bin is full when its empty
a known problem on these models. however, first make sure the sensors are clean and not covered with paper dust. they are located above top of basket with one on right and one on left side of basket. alos, if you have shredded paper hanging down, that will trigger sensors also. if everything looks good, you'll have to have sensors replaced.
hth,
razors
Jun 29, 2011 | Fellowes Powershred 220CC Shredder
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
Office max shredder, says bin full but its not, only half full
I had the same problem. I found that the sensor on the shredder is light sensitive. The viewing window in the bin was letting too much light in and was triggering the bin full light to turn on. I covered the window with a piece of paper and then restarted the shredder.It worked fine after that.
Feb 08, 2010 | OfficeMax 0M96431 Shredder
SHREDDER INDICATOR KEEPS COMING ON WHILE SHREDDING
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Nov 11, 2009 | Fellowes DM15C Shredder
Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Apr 25, 2008 | Office Depot Ativa DQ60M Shredder
No Power!
Check and make sure the paper catch bin is locked into place.
IF the shredder doesn't see that the bin is in place, the shredder will appear dead for safetly reasons.
There is a possibility that the control board was cracked but the only way to check that, is to take it apart and check.
Good luck.
Jan 06, 2008 | Tech Solution TS-4500 Shredder
OfficeMax 0M96431 Shredder Logo
281 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Steve
 Bob Buchholz
Bob Buchholz
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
