Copier does not copy
Copier ImageClass MF6500 series gies through process but copies come out blank. Can someone help
  • 135 Answers
Your laser shutter is not opening properly i have fixed so many of these if you are technically inclined you can try yourself but you have to take machine almost completly apart, better for a PROFESSIONAL to attempt.
Posted on Apr 19, 2009
Tip
Canon Imageclass MF6500 Series Copier with Blank Copies Prints Problem
This tip works on all Canon Imageclass 6500 series machines including the MF6500 MF6530 MF6531 MF6540 MF6550 MF6560 MF6580 MF6590 and MF6595.
First of all if you are experiencing blank copies and or prints the best thing to do is try a different toner cartridge. In rare cases the black copies/prints CAN be caused by a defective cartridge. In MOST cases it is caused by a broken or detatched laser shutter lever or arm. When a toner cartridge is inserted and the door closed, a small plastic arm opens the laser shutter. If this arm is broken or has become disconnected then the shutter is not opened. This blocks the laser from writing the copy or print image onto the drum and this results in no print being applied to the paper. If the arm is broken you CAN open the laser shutter manually and block it open. What you need to do it open the cartridge access door, remove the cartridge and look for a 1/2 inch wide slot running from left to right in the metal frame that is in the back upper section where the cartridge goes. The plastic arm that operates the black plastic shutter is on the right side. If broken you can manually lift up the shutter and "block" it open using something like a folded up scrap of paper. I know it sounds strange but I have used this repair on several of my customers machines and they have all worked fine since. If you can not find or effect the repair yourself at least you will know where to point the service person when they come out to look at it.
Good Luck and Thank You for using Fixya.
on Nov 02, 2010 | Office Equipment & Supplies
The toner was low, so I changed it. however, when I try to copy with a new toner it is still blank.
I have a tip posted here at Fixya that addresses the blank copies issue with the Canon 6500 series. The link is posted below. I think you may find it very helpful. If so please return here and let me know that it helped.
Thanks,
WheatlandServices
http://www.fixya.com/support/r6672478-canon_imageclass_mf6500_series_copier
Nov 11, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
How to get copy count for Canon Imageclass MF6500?
Tell it to print a "self-test" page. Some of the printed output will be the copy-count.
Jul 22, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
CANON MF6550 COPIES ARE COMING OUT BLANK
The Canon MF6000 series devices have a bad problem of the scanner shutter not opening. It will cause blank copies. Replace or remove shutter. Usually done by technician. Call Canon, you may get it fixed for free.
May 22, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
CANON COPIER IMAGECLASS MF6500
It needs a new image processor, hope its still under warranty. The part retail is around $400.00 I just ordered one for someone today!
Jun 15, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Canon ImageClass MF6500 Message on machine ''Download Standby''
My Xerox copy centre C123 shows error code 124-315
and the message says to Switch off the machine and turn it on
Feb 16, 2009 | Canon Office Equipment & Supplies
I have a cannon print mf6500 and i have a littleproblem , i want to reset it to have the defaul setting .
Check the manual:
Or this link:
http://static.compusa.com/pdf/canon-imageCLASS-MF6500-Series-ScannerDriverGuide.pdf
Jan 23, 2009 | Office Equipment & Supplies
Printing blank pages
open the door and look for a unit that has some small hair like wires, are they intact or is one missing /broken???
Oct 30, 2008 | Canon imageCLASS MF6550 Monochrome Laser...
91 people viewed this question
jasbo
jasbo
