FixYa.com
Tags:
Motorola AXU4100  2-Way Radio
Shuts for no reason
posted by batman07 on Sep 13, 2007
Lately our radios shut off for no reason. the volume knob is on but no screen or sound. completely off
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Sep 14, 2007
Helpful (85)
Bushwacker
Rank:Master Master
Rating: 81%, 11 votes
Check the battery first..... alot of times a person will put a battery in a chager and let it sit. They will think the battery is fully charged but it may not be...
In those battery packs there are a bunch of smaller batteries all tied together. Alot of times these commercial raios will run off of around 7 volts ( check the battery). The battery will only charge up to 7 volts if all the cells inside the battery are good.
What I'm saying is for you to charge the battery up fully..... check the voltage listed on the battery then use a volt meter to check the voltage after the battery is fully charged.
When a battery has just finished being charged usually it will be overcharged.... a 7.5 volt battery will be up around 8.5 volts for example.
So check the battery right after its charged... expect it to be overcharged. If it seems OK, put it in the raio and key the radio for a bit to try and use up some battery power.... then check it again and see if it has dropped drastically.
Your problem has to do with power... the first link in the power chain is the battery... check that out... then go to where the battery makes contact with the radio and make sure thats good.... inside the radio there will be a fuse but if thats blown you will get nothing... then the power goes to the switch.
Battery... contacts...fuse... switch... that how the power initially gets into the radio.
Most of these problems are battery related so I would check that first. If the battery does not have enough power when you transmit with the radio the radio will shut down.... turn off. If its not getting enough current the voltage will drop and once it gets low the radio shuts off. Usually with commercial stuff you will hear a "beep" when this happens.
Your problem might be power related... theres alot you can check.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Neto
Rank:Wiz Wiz
Rating: 82%, 114 votes
Check for any rust or corrotion on radio battery contact.
dirty bat. contact could produce this kind of syntoms.
What happend if the radio turn off by itself and you try to turn on again? does it turn on normaly?
Can you Help with these 2 Way Radios problems?
2 Way Radios
vertex standard vx-424-2-5
could you tell me if there is... Answer This...
2 Way Radios
microphone
where can i obtain a circuit... Answer This...
2 Way Radios
Vertex headset
I bought a headset made for a... Answer This...
2 Way Radios
VHF
Hi.. I am in need of the... Answer This...
2 Way Radios
cam timing
I need the timing setting for a... Answer This...
Repair Service
Find 2 Way Radio Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
