Question about Pride Jazzy 1103 Ultra Standard Power Chair
Not Charging When plugged into the wall to charge, I used to hear a humming noise which told me it was charging. The humming is gone. I know the cord is good. I'm not getting a charge. Jazzy 1103 Ultra
  • Estragon May 11, 2010
    What does the ammeter read when you are plugged in?
  • 103 Answers
Probably the charger has gone bad. You can look on Pridemobility.com for a dealer in your area.
Posted on May 26, 2009
My panasonic Hc-v100 camcorder is not charging when plugged in to USB cable - cursor light is not flashing and battery is running down
you DON'T charge the camcorder with the usb cord,you only move files between cam and computer,you need a power cord that plugs into the wall,see pic, LETO 2A AC Power Charger Adapter USB Cord For Panasonic HC V100 HC V500 HC...
ihave the same camcorder,
Mar 24, 2015 | Video Cameras
After connecting the charger cord and plugging it into the wall socket, is the iPhone to be turned off or turned on?
If you turn it off, it will charge faster. I've done both. This morning my charge was very low. Then I noticed the plug became out of the socket. Try it both ways,see what happens. If you are charging with it on, have you closed all your apps? Double press the on/off button on the bottom front. Any open apps will appear half size. Place your finger on the app, and slide it UP and "OFF" the unit. Turn it off, try charging. Be sure your plugs are all the way in. If you try it turned off, the unit will briefly show your current charge, then turn itself off.
Sep 22, 2014 | Apple iPhone 5c
My phone will not take a charge or power up
Confirm that the charging port is working (it may have cable connection issue, and have to be place in a certain position to charge), If the port is fine, then figure if battery is bad.. If charging port is bad, its a relatively easy and cheap fix.
May 29, 2014 | HTC Vivid
Charging Problem
Have someone you know check the voltage at the end of the adapter cord.
Feb 09, 2014 | Nikon COOLPIX S3300
Hello,my laptop didn't get started it is charging
How do you know it is charging? What does it do when you hit the power button?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 30, 2012 | Computers & Internet
I'm borrowing a Jet 3 Ultra from the local Am. Legion for my Mom to use. They know nothing about it except they were told it had a new battery. I plug it in and all the LED's light up with the...
The batteries need charging and when you plug in the charger and the power is on the lights wil flash indicating that the charger is plugged in. Now look at the rear of the chair near where the charger cord plugs into the chair and you should see a voltmeter. With the charger plugged in the voltmeter will indicate about 5-6 amps and after charging overnight the voltmeter should be reading 0 amps. If when you plug in the charger cord and the voltmeter indicates 0 amps then I would suspect that the charger is not working or that the fuse is blown in the charger circuit. The only way to see if the batteries charge would be to borrow or find an offboard charger that will plug into the charger port located under the front of the joystick and after charging for 10-12 hours see if the battery level lights show full charge Hope this helps
Jun 25, 2011 | Pride Used Mobility Jet 3 Power Wheel...
Have a Sunrise Aspire chair w/new batterie, charged by the repairman. Want to keep it charged regularly (not let it run down). DO I NEED TO TOTALLY DISCONNECT THE POWER HOOKUPS IN THE BACK when I...
You do not need to unplug the large 9 pin beau plug in the rear or the smaller 3 pin molex plug when you charge the chair. Do not unplug them or you will not charge the chair.
Use your charging cord as you describe "plug it into the front, plug it into the wall and charge, then unplug the charger cord and GO". Hope this helps.
Jan 05, 2011 | Quickie Wheelchairs Quickie Aspire Power...
Why is it making a humming noise
If it is humming ONLY when you connect it for charging and does not hum when you have no load on it...it has too much initial load and the humming is caused by an output current overload.
I don't know what you are trying to charge....if you are VERY careful and you can monitor the output current load....you may be able to get a charge....BUT BE VERY CAREFUL!
Mar 09, 2010 | Schumacher & Fast Charge Starter Charger
Ipod doesnt work
I think I know just the problem. The connection cord that came with the wall outlet charger can only be used for charging. You have to have the original apple cord in order for the computer to recognize it.
I had the same problem.
Sep 20, 2009 | Apple iPod touch
My usb
I had the same problem - you need to install the latest Blackberry USB driver software on the PC/laptop you are trying to charge it with. They should be on the CD you got with the Blackberry (you don't need to install all the software if you don't want to - just the USB drivers). This enables the USB ports to allow enough power to charge the device when it's connected.
If you don't have the CD, do a quick Google for "Blackberry USB driver" and download the most up-to-date ones you can find.
Nov 04, 2008 | RIM BlackBerry Pearl 8100
Pride Jazzy 1103 Ultra Standard Power Chair  Logo
224 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
