When I switch the TV on, it appears as though it is going to start i.e the green light comes on, then after about 10 seconds it switches itself off and the standby light flashes red. It started a few days ago and would turn on after a few tries and now finally won't respond. Just keeps doing what I stated above.
I found another website (not interactive) that issued this solution: "The problem is three caps. Remove the back of the Plasma. Change the cap 2663, 2664 both 100µ/25V and 2662,1000µ/25V. After you have changed them your TV will work again."
Does this sound right? Where do you find these parts? And how easy is it to replace myself.
Phillips offered no advice when called except to unplug TV and plug back in, which I already did three times with no change. They then said to call a serviceman (thanks for the great tip Phillips.)
I appreciate any help if it is possible to resolve this problem myself.
-   I have the exact same problem and i got 2 years ago and i have the same problem as you do. A service man told me that it could be some timer effect and it needs to be changed.-   Guest
Solution #1
posted on Oct 23, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hi I had exactly the same problem, bought the above parts off ebay. The above solution worked and tv back to normal. the soldering is a bit tricky and there is a lot of screws holding the back on!
sound has gone off on my wharfedale lcd2610af1 started to cut out when watching it then went off...
(More)
sound has gone off on my wharfedale lcd2610af1 started to cut out when watching it then went off altogether
our plasma sony bravia suddenly blackout but still with sound, tried to turn it off and on but it...
(More)
our plasma sony bravia suddenly blackout but still with sound, tried to turn it off and on but it still the same, can you help me what to do with problem
