Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
I've a wurlitzer 1015 and can i connect an ext. pick-up player??
I've a wurlitzer 1015 and I will connect a external pick- up player to it.
Can i connect it to the amplifier ??
    Champion:
  • Wurlitzer Expert
  • 211 Answers
.You can if you ue a "background music adaptor" which allows a second source of music to be played through the amp.
Dave F.
Posted on Jun 25, 2009
Hook up ex. speakes
The external speakers come off the tabs on the left of the amp marked Ext Speakers. 8ohm 40 watts.
Dec 21, 2015 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 one more time 50 CD player, it is reading error 0008 checked k7 switch, and arm making good contact. Just picks up cd puts it on tray then goes back to carousel continuously. Pulled bot
If it isn't K7 actuating bracket, or actually K7 microswitch it is a problem with the Selection and Credit Computer. It was a fault with some transistors on that board which showed that fault (if it really isn't K7). You can get them mended at www.wurlitzer.co.uk
Dec 28, 2014 | Wurlitzer Jukebox 1015 One More Time...
I have a 1015 Wurlitzer 1015 Jukebox 100 CD player. The problem just started in that the carriage picks up the cd, swings it over to the turntable, won't release the cd, returns it back to the carriage and...
Switch K7. It clicks and stops the motor when the gripper puts the CD back. Either the bracket which clicks it has come loose or the switch doesn't work anymore. (and it's a PIG to change!) K7 is labelled and is the far side of the gripper gears.
Sep 18, 2013 | Wurlitzer Jukebox 1015 One More Time...
How do I replace the column GE tubes on a 1015 Wurlitzer?
HI,
Here i have added picture of Wurlitzer 1015 rear side picture. from this picture you can identify which side you have to remove to see the tubes. In th picture you can see the tubes. two out put tubes. one rectifier and two pre amp tubes(black).
Wurlitzer 1015
Jul 24, 2012 | Wurlitzer Jukebox 1015 One More Time...
I HAVE A WURLITZER 1015 JUKEBOX ,WHEN I PICK A CD IT JUST PICKS UP THE CD PUTS IT ON THE PLAYER AND RETURNS IT TO THE TRAY AND KEEPS DOING THE SAME THING OVER AND OVER
This can be caused by several different factors....If you will email me, I'll give you my phone number so I can help you further troubleshoot your problem. Please email tech@wurlitzer-ohio.com.
Mar 11, 2011 | Wurlitzer Jukebox 1015 One More Time...
My wurlitzer 1015 cd jukebok carosel continually
There's a little light like a torch bulb light called the "light gate lamp" which you should be able to see shining at 6 oclock on the edge of the record carousel. It is on the lip where the serated toothed edge of the carousel passes through a small upright bracket. If you can't see it shining then that's your problem. Have a look in the original documentation and it shows a diagram how to change it.
Dave.
May 22, 2010 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer arm keeps running
check the white plastic actuator next to the gear box, it is probably broken and not actuating the microswitch underneath it, these often fail, it may look ok,, but it actually is loose and the set screw on top of it is not clamping it to the rod.
Aug 18, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
253 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
phil
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
