Question about RCA 25202RE3 Corded Phone
Line 2 stays lit with red light - RCA 25202RE3 Corded Phone
I think that just means that you do not have a 2-line connection to the phone. Either your cord is a 1-line cord or your 2-line cord is plugged into the wrong jack on the back of the phone,
Posted on May 11, 2009
6 light 2 spot light low volt moon Raysystem trouble making a connection on 4They clip onto line fine wont stay lit Is there a way to clip the lights to the low voltage line better so they stay lit.
Not sure what you are needing here but if its a poor connection, try soldering the wiring or using correct spade and socket connectors.
May 25, 2015 | Cars & Trucks
Tip
I have a standing pilot that wont stay lit.
If you have a standing pilot that wont stay lit and you have to keep relighting it, it can only be a couple of things that will do this.<br /> 1. Try tighting the thermocouple at the gas valve. (this is a thin copper line that goes from the gas valve and goes to the pilot light.)<br /> 2. Make sure that the tip of the thermocouple is in the pilot light flame.<br /> 3. Make sure that the thermocouple is clean.<br /> <br /> if you have done these and it still doesnt stay lit, buy a new thermocouple.
on Mar 14, 2011 | Heating & Cooling
Pilot will not light after repeated attemps. Shut main gas line off as book suggested. Re-lit burners and then oven pilot. Pilot only stays lit if holding red pilot button
90% chance your thermocouple is bad.
This should work: http://www.partstown.com/southbend_range/sou1196078
10% chance your red push button safety valve is bad. If it is really hard to push in I would recommend changing that as well.
Jan 27, 2014 | Southbend 4603AA-2TR LP - 60-in Range w/...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a readyheater model 65-85 the flame will not stay lit im thinking thermal couple is there a way to test this part? or could it be another problem?
If your pilot light will not stay lit when you release pilot light button then chances are that your thermocouple is bad. Make sure that the tip of thermocouple is directly in line with pilot light. Tip of thermocouple should be cherry red if it is properly placed. If pilot will not stay lit then replace it. If you aren't sure about placement of thermocouple you can heat thermocouple with a seperate heat source. If you do this and pilot light stays lit then reposition thermocouple in pilot flame. If it still won't keep pilot burning then replace thermocouple. Hope this helps. Thanks.
Nov 19, 2010 | Reddy Heater-30-55,000 BTU Variable
So much static I can not hear properly
The line that stays lit for line 2 is just the way it is.. not a problem. If you only have one phone line and a two line phone you will always have the one (non working line 2 ) lit.
Have you replaced the cord to the handset? Many times it is a bad cord that causes static.
May 11, 2010 | RCA ViSYS 2-Line Speakerphone
We have the AT&T 2 line digital answering system #1872.
Unfortunately, there is no way to turn that light off. I had the same situation and researched, called help lines and even had the phone company out to check. The light will stay on. but there is no service to it.
Feb 20, 2009 | Lucent 1872 Corded Phone
RCA executive series
No ringer could well be a setting and light on 2nd line means their is No 2nd line and most 2 to 4 lines phones at least require 2 active lines for the system to work correctly
Mar 30, 2008 | RCA 25202RE3 Corded Phone
Line 1 stays lit
do you have your phone plug, inserted into line 2?
Aug 31, 2007 | RCA 25202RE3 Corded Phone
RCA 25202RE3 Corded Phone Logo
440 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
